603,358 active members*
3,206 visitors online*
    Mar 2008
    9
    adding rotary to tm-2
    Hey guys
    First time on the site. Already have learned a few new things..
    I do need some help. I have a tm-2 that came from the factory without the 4th axis pre wire. I bought a used brushless 210 rotary table and need it up and running. I beleave I can find a servo amp and cables to make this work.
    There are 2 wires i beleave i need. A short wire that feeds info to the amp from a computer board above ,and the wire assembly going out of the amp to power the servo, this wire is attatched to the machine with a female pin connector facing outside. the 210 already has the long wire with the male pin connector on it ready to go.
    I am assuming I can get these wires from haas.
    My main question is. Do I have to pay to set setup my parameters to accept the new hardwear? Or can these be changed by myself for free? And what parameters will I need to change?
    I called the techline and asked, I got some cockey guy on the phone that pretty much told me I need to spend $2100 in new haas parts to make my 210 table work. Then they will tell me how to set my parameters up.
    thanks for any help
    dave
    Feb 2007
    205
    Your going to need a code from Haas to turn the 4th axis on ... call your local dealer and see what they have to tell you .. and the cost is
    4AXBLMM 4th-Axis Drive and Wiring only, for brushless-type rotary tables $2,095.00 suggested retail
    HRT210-CNCB 210 mm (8.27") Servo Rotary Table
    $7,995.00 suggested retail (this is what you bought used)
    Mar 2008
    9
    thanx hail.
    If I get a seperate servo control box used, I assume I will not need buy anything from haas to make it work?
  1. adding a 4th axis?
    By airbrush in forum Uncategorised WoodWorking Machines
    Last Post: 10-12-2007, 11:00 PM
  2. Adding a fan to the X3
    By Antonyong in forum Benchtop Machines
    Last Post: 04-26-2007, 05:19 AM
  3. adding a stop
    By planescott in forum BobCad-Cam
    Last Post: 04-26-2007, 01:56 AM
  4. Adding a Joystick.
    By on7tim7 in forum Mach Mill
    Last Post: 01-10-2006, 08:33 PM
  5. Adding a 4th
    By Shizzlemah in forum Fadal
    Last Post: 12-02-2005, 12:16 AM
