603,943 active members*
2,998 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Adjust backlash when rigid tapping with a rotary tool in lathe
    Jun 2008
    113
    Hello.
    Does anyone know the parameter(s) for adjusting backlash when rigid tapping using a rotary tool? 18i-TB
    Thank you!!
    Dec 2012
    410
    Re: Adjust backlash when rigid tapping with a rotary tool in lathe
    Parameters for Rigid Tapping: 5200 - 5382, Fanuc Parameter Manual B-63530E.
    Download attachment for the pdf-manual.
    If nothing works buy one of these, in my case it's a FAHRION ER25 collet with 8mm axial compensation:
    FAHRION 4285E-CET25-GB, cost +/- €85,-
    Attachment 364504
    Use a 96-98% of the infeed and 100% for the reverse-feed.
    Example M5x0.8, If G84 or G184 not working.
    G00 G90 X100. Z5.
    S1000 M24 ( live-tool - 1000rpm )
    G01 G98 Z-15. F776 ( 97% --- 0.97x(1000x0.8)=776 mm/min )
    M25 ( stop )
    G04X0.5 ( dwell )
    S1000 M23 ( live-tool - 1000 rpm )
    G01 G98 Z5. F800 ( 100% --- 1000x0.8=800 mm/min )
    Regards.
  1. Replies: 0
    Last Post: 04-27-2016, 02:47 PM
  2. Rigid tapping with Lathe post processor?
    By Hood in forum BobCad-Cam
    Last Post: 02-08-2015, 11:16 PM
  3. g184 rigid tapping okuma lathe
    By pwanamaker in forum Okuma
    Last Post: 12-19-2012, 08:20 PM
  4. Tool Load Monitoring During Rigid Tapping
    By abhthree in forum Fanuc
    Last Post: 11-03-2011, 09:16 PM
  5. rigid tapping on Hitachi-Seiki HT-23J Lathe
    By jbird68 in forum G-Code Programing
    Last Post: 09-21-2007, 02:02 PM
