587,608 active members*
3,541 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Adjusting Gecko 540 Trimpots on CNCRP 2448 (NEMA 23) RP drive Engaged or Not Engaged
    Mar 2013
    13
    Re-posting this with a "Need Help!" prefix.
    I am reading through Gecko's set up info regarding the Trimpots on the G540.
    What would be easiest for me (as I am a one man show today) would be to disengage the RP drives (and the Screw on the Z), run each motor using Mach3 (holding down the appropriate arrow keys) while turning the various Trimpots on the Gecko board. This way I don't have to worry about crashing the machine into itself, while i am listening and adjusting for that "Sweet Spot" Gecko mentions.
    Wondering 2 things:
    1. Is this a viable way to adjust the Trimpots or do the motors have to be "Under Load".
    2. Do I still have to worry about shorting out the Gecko board with my screw driver (I don't have a plastic one handy) or did Gecko update the boards design to fix this (they make no mention of it in the directions I have).
    Thanks for any advice on this.
    Paul
    Jun 2004
    6618
    You can make a plastic screw driver. I have used a typical jewelers screwdriver on other Gecko's, but those pots are not as deep as the 540 ones are. There is a chance that you will poke something you shouldn't. If you cannot, then at least cover the shaft of your screw driver so that it will not contact the side of the aluminum housing when poking around inside.
    Turn your jog rate down to a very low percentage. Very low. You can still hear the sound. This would be a good time to learn how to use the MIDI input on the second screen. Once you know a few standard parameters, it can be very beneficial.
    Actually adjusting it takes less time than getting the screw driver into the slot. Mine were at a good spot pretty much. I went to both extents and then right back to about where I started.
    You can do it under load or not. You can do it while the parts are sitting on the bench. It is a set by ear thing.
    Lee
    Mar 2013
    13
    Thanks for the advice Lee, it is appreciated.
    Paul
  1. Replies: 0
    Last Post: 04-07-2013, 01:03 AM
  2. motor spinning but not engaged?
    By snailFury in forum Stepper Motors / Drives
    Last Post: 01-28-2013, 05:45 AM
  3. motor spinning but not engaged?
    By snailFury in forum CNC Machine Related Electronics
  4. feed rate when cutter fully engaged?
    By fer_mayrl in forum Visual Mill
    Last Post: 11-08-2007, 10:58 AM
  5. EX 02 Safety Limit Switch Engaged FANUC 11 SERIES ON NTC MACHINE
    By Epik in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-27-2005, 11:20 PM
