587,997 active members*
2,006 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Advanced Motion Control Drives - Need Help
Results 1 to 4 of 4
    Dec 2009
    41
    I am trying to use some Advanced Motion Control B25A20AC drives with a +/- 10 V input signal on a 3 axis mill. I am looking for advise on which mode to operate them in as well any hook up tips. Anybody an AMC user?
    Dec 2003
    24220
    I have been using them for many years with Galil and Acroloop motion cards, using the ±10vdc control and I use them in Torque or current mode.
    Hook up depends on what your controller is, they have enable input and alarm out, if you want to use this feature.
    They recommend Pot1 fully CCW and Pot3 fully CW in Torque mode.
    They have a Technical Engineering section on their site, it is a bit harder to find since they remodeled the site.
    Al.
    Albert E.
    Dec 2009
    41
    My drives only have one pot.
    Dec 2003
    24220
    Quote Originally Posted by ktmrider View Post
    I would guess that you bought these used?
    The only ones I have come across with one or no pot's have been pre set up for OEM's by AMC.
    If this is the case, you may have to try them out and see how they react?
    Al.
    Albert E.
  1. Replies: 5
    Last Post: 05-31-2019, 05:16 PM
  2. G08 Advanced Preview Control
    By ggborgen in forum G-Code Programing
    Last Post: 08-06-2010, 08:10 AM
  3. Replies: 0
    Last Post: 07-16-2009, 02:50 AM
  4. AI Advanced preview control
    By qmas99 in forum Fanuc
    Last Post: 09-22-2008, 02:49 AM
  5. advanced motion servo drives
    By cueshark in forum Servo Motors / Drives
    Last Post: 01-16-2007, 04:42 AM
