587,228 active members*
5,408 visitors online*
Page 1 of 2 12
Results 1 to 20 of 33
    bobcad guy Guest
    advanced rough
    anybody else noticed, that the advanced rough option, in pocketing wizard, when used in multiple depths of cut to get to a final depth, will rapid all the way to the last milled height between cuts? meaning, if you go 1 inch, with 4 passes of .25 deep, after it cuts the first .25 deep, it wil retract, rapid to the start point, and rapid z to -.25. huh?? has anyone ever seen a feature that rapids in, and stops within a tenth? and when i told them of the issue, they said its meant to save time. really? how bout the fact that i keep chipping endmills cause im rapiding to the floor. if ya really want to save time, dont retract and go back to the start point, start ramping in from the wherever you finished the last cut.
    Nov 2006
    227
    I have noticed it in other features as well. Even a simple drill cycle can be an issue. When drilling holes, a rapid to end point is really hard on tools!
    To get CNC code I am comfortable to place into production, I must edit every program.
    I must do this, no matter the software I use....
    I have not taken time yet to look at how the variable is carried... Is there a way to add an equation to the post?
    bobcad guy Guest
    Quote Originally Posted by JEST View Post
    this is the only pocket feature i noticed it in, i was seeing tool marks in a couple of spots over and over, a few very noticable, some not to bad, but it was a hidden surface, so it wasnt a huge issue. worst part was the support telling me thats the way it was meant to work, why have us enter a value in the feed plane, and another feed value in the "Z feedrate box in the tool page, if your gonna rapid right to the surface. this is obviously a "flaw"
    Mar 2007
    10
    I had this happen as well. When I ran the code in simulation, it even reported a tool crash. Only solution I could find was to manually edit out all the z rapids.
    bobcad guy Guest
    Quote Originally Posted by velocityxlrg View Post
    manually edit!!!!!!! but we have software. i try to find anyway i can to not manually edit, i want to make sure if i need to make a little change, i dont have to remeber i need to manually change this, and that, but not the other thing, efff that
    Jan 2012
    41
    Yeah, I've contacted bobcad with this issue and talked to the support team (after they charged me for tech support ...go figure) and was told that it was an operator error and I must have my z level off or my machine wasn't accurately reporting positioning. GJ BOBCAD blame someone else.
    Mar 2012
    1570
    I am trying to reproduce this issue with no luck. Here is the code I get doing a pocket that have 4 step to get to the bottom. I am using a pocket feature with advance pocket pattern.
    Code:
    (FIRST MACHINE SETUP - Machine Setup - 1)
    (PROGRAM NAME - BOBCAD1.NC)
    (POST -  BC_3X_MILL 3-AXIS GENERIC FANUC)
    (DATE - TUE. 05/07/2013)
    (TIME - 02:15PM)
    N01 G00 G17 G40 G49 G80 G20 G90
    (FIRST CUT - FIRST TOOL)
    (JOB 1  POCKET)
    (FEATURE POCKET)
    (TOOL #1 0.5 ENDMILL ROUGH)
    N02 T1 M06
    N03 G00 G90 G54 X0.2 Y0.2 S3880 M03
    N04 G00 G43 H1 D1 Z0.1 M08
    N05 G00
    N06 G01 Z-0.25 F44.6296 <<<<<<<<<<<  Feed move to Z
    N07 G01 X-0.2 F89.2592
    N08 G01 Y-0.2
    N09 G01 X0.2
    N10 G01 Y0.2
    N11 G01 Y0.45
    N12 G01 X-0.45
    N13 G01 Y-0.45
    N14 G01 X0.45
    N15 G01 Y0.45
    N16 G01 X0.2
    N17 G01 Y0.7
    N18 G01 X-0.7
    N19 G01 Y-0.7
    N20 G01 X0.7
    N21 G01 Y0.7
    N22 G01 X0.2
    N23 G01 Y0.95
    N24 G01 X-0.95
    N25 G01 Y-0.95
    N26 G01 X0.95
    N27 G01 Y0.95
    N28 G01 X0.2
    N29 G01 Y1.2
    N30 G01 X-1.2
    N31 G01 Y-1.2
    N32 G01 X1.2
    N33 G01 Y1.2
    N34 G01 X0.2
    N35 G00 Z0.1
    N36 G00 Y0.2
    N37 G00 Z-0.15
    N38 G01 Z-0.5 F44.6296 <<<<<<<<<<<<<<  Feed move to Z
    N39 G01 X-0.2 F89.2592
    N40 G01 Y-0.2
    N41 G01 X0.2
    N42 G01 Y0.2
    N43 G01 Y0.45
    N44 G01 X-0.45
    N45 G01 Y-0.45
    N46 G01 X0.45
    N47 G01 Y0.45
    N48 G01 X0.2
    N49 G01 Y0.7
    N50 G01 X-0.7
    N51 G01 Y-0.7
    N52 G01 X0.7
    N53 G01 Y0.7
    N54 G01 X0.2
    N55 G01 Y0.95
    N56 G01 X-0.95
    N57 G01 Y-0.95
    N58 G01 X0.95
    N59 G01 Y0.95
    N60 G01 X0.2
    N61 G01 Y1.2
    N62 G01 X-1.2
    N63 G01 Y-1.2
    N64 G01 X1.2
    N65 G01 Y1.2
    N66 G01 X0.2
    N67 G00 Z-0.15
    N68 G00 Z0.1
    N69 G00 Y0.2
    N70 G00 Z-0.4
    N71 G01 Z-0.75 F44.6296 <<<<<<<<<<<<<  Feed move to Z
    N72 G01 X-0.2 F89.2592
    N73 G01 Y-0.2
    N74 G01 X0.2
    N75 G01 Y0.2
    N76 G01 Y0.45
    N77 G01 X-0.45
    N78 G01 Y-0.45
    N79 G01 X0.45
    N80 G01 Y0.45
    N81 G01 X0.2
    N82 G01 Y0.7
    N83 G01 X-0.7
    N84 G01 Y-0.7
    N85 G01 X0.7
    N86 G01 Y0.7
    N87 G01 X0.2
    N88 G01 Y0.95
    N89 G01 X-0.95
    N90 G01 Y-0.95
    N91 G01 X0.95
    N92 G01 Y0.95
    N93 G01 X0.2
    N94 G01 Y1.2
    N95 G01 X-1.2
    N96 G01 Y-1.2
    N97 G01 X1.2
    N98 G01 Y1.2
    N99 G01 X0.2
    N100 G00 Z-0.4
    N101 G00 Z0.1
    N102 G00 Y0.2
    N103 G00 Z-0.65
    N104 G01 Z-1. F44.6296 <<<<<<<<<<<<<<<  Feed move to Z
    N105 G01 X-0.2 F89.2592
    N106 G01 Y-0.2
    N107 G01 X0.2
    N108 G01 Y0.2
    N109 G01 Y0.45
    N110 G01 X-0.45
    N111 G01 Y-0.45
    N112 G01 X0.45
    N113 G01 Y0.45
    N114 G01 X0.2
    N115 G01 Y0.7
    N116 G01 X-0.7
    N117 G01 Y-0.7
    N118 G01 X0.7
    N119 G01 Y0.7
    N120 G01 X0.2
    N121 G01 Y0.95
    N122 G01 X-0.95
    N123 G01 Y-0.95
    N124 G01 X0.95
    N125 G01 Y0.95
    N126 G01 X0.2
    N127 G01 Y1.2
    N128 G01 X-1.2
    N129 G01 Y-1.2
    N130 G01 X1.2
    N131 G01 Y1.2
    N132 G01 X0.2
    N133 G00 Z-0.65
    N134 G00 Z0.1
    N135 M09
    N136 M05
    N137 G00 G91 G28 Z0.
    N138 G00 G91 G28 Y0.
    N139 G90
    N140 T1 M06
    N141 M02
    (END OF FILE)
    (END OF PROGRAM)
    N142 M30
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    Here is the same file with the adaptive tool path for the pocket:
    Code:
    (TIME - 02:23PM)
    (JOB 1  POCKET)
    (FEATURE POCKET)
    N02 T1 M06
    N03 G00 G90 G54 X-0.1183 Y0.0064 S3880 M03
    N05 G00
    N06 G01 Z-0.25 F44.6296   <<<<<<<<<<<<<<<<<<<<<<<<<<<  Z Feed Move
    N07 G17 G03 X0.1132 Y0.0719 I0.125 J0. F89.2592
    N08 G17 G03 X0.0729 Y0.1226 I-0.2091 J-0.1248
    N09 G17 G03 X0.0463 Y0.1458 I-0.1884 J-0.1898
    N10 G17 G03 X0.0277 Y0.1589 I-0.1122 J-0.139
    N11 G17 G03 X-0.0161 Y0.1798 I-0.1261 J-0.2078
    N12 G17 G03 X-0.0409 Y0.1869 I-0.059 J-0.1599
    N13 G17 G03 X-0.0719 Y0.1915 I-0.0385 J-0.1511
    N14 G17 G03 X-0.1042 Y0.1916 I-0.0162 J-0.1609
    N15 G17 G03 X-0.1227 Y0.1891 I0.0156 J-0.1907
    N16 G17 G03 X-0.1886 Y0.1636 I0.0251 J-0.1625
    N17 G17 G03 X-0.2325 Y0.1267 I0.1375 J-0.2085
    N18 G01 X-0.2422 Y0.1158
    N19 G17 G03 X-0.2611 Y0.0876 I0.3169 J-0.2331
    N20 G17 G03 X-0.2757 Y0.0568 I0.4395 J-0.2281
    N21 G17 G03 X-0.2848 Y0.0288 I0.4884 J-0.1726
    N22 G17 G03 X-0.2898 Y0.0046 I6.551 J-1.3943
    N23 G01 X-0.2921 Y-0.0151
    N24 G01 X-0.2928 Y-0.0399
    N25 G01 X-0.2916 Y-0.0598
    N26 G17 G03 X-0.2869 Y-0.0893 I0.2682 J0.0279
    N27 G17 G03 X-0.2791 Y-0.1184 I0.1561 J0.0261
    N28 G17 G03 X-0.2705 Y-0.142 I0.2302 J0.0707
    N29 G17 G03 X-0.2596 Y-0.1648 I2.6951 J1.2685
    N30 G01 X-0.2522 Y-0.1781
    N31 G17 G03 X-0.2151 Y-0.2262 I0.241 J0.1477
    N32 G17 G03 X-0.1431 Y-0.2824 I0.2491 J0.2448
    N33 G17 G03 X-0.1253 Y-0.2925 I0.3567 J0.6078
    N34 G17 G03 X-0.0777 Y-0.3115 I0.2127 J0.463
    N35 G01 X-0.0528 Y-0.318
    N36 G17 G02 X-0.0428 Y-0.3202 I-0.0281 J-0.1555
    N37 G17 G03 X-0.0122 Y-0.3247 I0.5747 J3.8199
    N38 G01 X0.0136 Y-0.3261
    N39 G17 G03 X0.0394 Y-0.3253 I-0.0027 J0.5093
    N40 G01 X0.06 Y-0.3233
    N41 G01 X0.0855 Y-0.319
    N42 G17 G02 X0.1056 Y-0.3139 I0.2344 J-0.8799
    N43 G17 G03 X0.1349 Y-0.3037 I-0.0816 J0.2832
    N44 G17 G03 X0.154 Y-0.2956 I-0.0804 J0.2154
    N45 G17 G03 X0.1724 Y-0.286 I-0.121 J0.2553
    N46 G17 G03 X0.186 Y-0.2784 I-0.0605 J0.1241
    N47 G17 G03 X0.2034 Y-0.2672 I-0.1073 J0.1851
    N48 G17 G03 X0.2433 Y-0.2339 I-0.2093 J0.291
    N49 G17 G03 X0.2544 Y-0.223 I-0.0791 J0.0916
    N50 G17 G03 X0.2784 Y-0.1957 I-0.1714 J0.1754
    N51 G17 G03 X0.2936 Y-0.1745 I-0.1201 J0.1024
    N52 G17 G03 X0.3246 Y-0.1143 I-0.3699 J0.2281
    N53 G17 G03 X0.3374 Y-0.0746 I-0.5271 J0.1922
    N54 G17 G03 X0.3457 Y-0.0284 I-0.3439 J0.0858
    N55 G17 G03 X0.3478 Y-0.0024 I-0.3582 J0.0419
    N56 G17 G03 X0.3461 Y0.0446 I-0.3421 J0.0107
    N57 G17 G03 X0.3426 Y0.0705 I-0.194 J-0.013
    N58 G17 G03 X0.3397 Y0.0859 I-0.1352 J-0.0171
    N59 G17 G02 X0.3363 Y0.1013 I0.4939 J0.1185
    N60 G17 G03 X0.3254 Y0.1363 I-0.3981 J-0.1041
    N61 G17 G03 X0.3179 Y0.156 I-0.1971 J-0.0638
    N62 G17 G03 X0.3024 Y0.1895 I-0.2174 J-0.0806
    N63 G01 X0.295 Y0.2036
    N64 G17 G03 X0.275 Y0.235 I-0.6641 J-0.401
    N65 G17 G03 X0.2523 Y0.265 I-0.235 J-0.1545
    N66 G17 G03 X0.2312 Y0.2897 I-0.192 J-0.1423
    N67 G17 G03 X0.195 Y0.323 I-0.2555 J-0.2419
    N68 G17 G03 X0.1865 Y0.3302 I-0.0548 J-0.0555
    N69 G17 G03 X0.169 Y0.3438 I-0.1286 J-0.1479
    N70 G17 G03 X0.1553 Y0.3537 I-0.087 J-0.1058
    N71 G17 G03 X0.1364 Y0.3659 I-0.1274 J-0.1764
    N72 G17 G03 X0.1217 Y0.3745 I-0.0834 J-0.1247
    N73 G17 G03 X0.1067 Y0.3827 I-0.0719 J-0.1154
    N74 G17 G03 X0.0859 Y0.3924 I-0.0656 J-0.1128
    N75 G17 G03 X0.0424 Y0.408 I-0.2621 J-0.6642
    N76 G17 G02 X0.0199 Y0.4147 I0.1919 J0.6808
    N77 G17 G03 X-0.0205 Y0.4226 I-0.3014 J-1.4314
    N78 G17 G03 X-0.0619 Y0.4266 I-0.1514 J-1.3734
    N79 G17 G03 X-0.0919 Y0.4265 I-0.0145 J-0.5171
    N80 G17 G03 X-0.1161 Y0.4257 I-0.0065 J-0.1698
    N81 G17 G03 X-0.1402 Y0.4232 I0.0079 J-0.1918
    N82 G17 G03 X-0.1702 Y0.4178 I0.0345 J-0.2796
    N83 G17 G03 X-0.2235 Y0.4029 I0.0884 J-0.4178
    N84 G17 G03 X-0.2467 Y0.3943 I0.0949 J-0.2912
    N85 G17 G03 X-0.2807 Y0.3787 I0.0818 J-0.2234
    N86 G17 G03 X-0.308 Y0.3634 I0.1354 J-0.2747
    N87 G17 G03 X-0.3241 Y0.3535 I0.0848 J-0.1557
    N88 G17 G03 X-0.3446 Y0.3388 I0.1529 J-0.234
    N89 G17 G03 X-0.3549 Y0.3313 I0.0432 J-0.0703
    N90 G17 G03 X-0.3928 Y0.2975 I0.1827 J-0.2431
    N91 G17 G02 X-0.4063 Y0.2839 I-4.0757 J4.0233
    N92 G01 X-0.4192 Y0.2695
    N93 G17 G03 X-0.4847 Y0.1665 I0.3493 J-0.2944
    N94 G17 G03 X-0.5024 Y0.1245 I0.5336 J-0.2507
    N95 G17 G03 X-0.5068 Y0.1122 I0.1478 J-0.0592
    N96 G17 G03 X-0.513 Y0.0936 I0.1516 J-0.0608
    N97 G17 G03 X-0.5182 Y0.0746 I0.1267 J-0.0447
    N98 G17 G03 X-0.5251 Y0.0425 I1.2581 J-0.2883
    N99 G17 G02 X-0.5274 Y0.0295 I-0.1688 J0.0228
    N100 G17 G03 X-0.5311 Y-0.0098 I0.6106 J-0.0787
    N101 G17 G03 X-0.5321 Y-0.0296 I0.1555 J-0.0173
    N102 G17 G03 X-0.5322 Y-0.0494 I0.3056 J-0.0115
    N103 G17 G03 X-0.5315 Y-0.0759 I0.17 J-0.0091
    N104 G17 G03 X-0.5272 Y-0.1155 I0.3394 J0.0175
    N105 G17 G02 X-0.5253 Y-0.1287 I-0.2199 J-0.0374
    N106 G17 G02 X-0.5202 Y-0.1548 I-1.3025 J-0.2678
    N107 G17 G02 X-0.5136 Y-0.1806 I-3.1403 J-0.8169
    N108 G17 G03 X-0.5036 Y-0.2125 I1.0693 J0.3182
    N109 G01 X-0.4942 Y-0.2376
    N110 G17 G02 X-0.4861 Y-0.256 I-0.5356 J-0.245
    N111 G17 G03 X-0.4642 Y-0.2974 I0.7466 J0.368
    N112 G17 G02 X-0.4504 Y-0.3205 I-0.6891 J-0.4288
    N113 G17 G03 X-0.4311 Y-0.3479 I0.5469 J0.3637
    N114 G17 G03 X-0.4189 Y-0.364 I0.1625 J0.1104
    N115 G17 G02 X-0.3973 Y-0.3898 I-16.1 J-13.5114
    N116 G17 G03 X-0.3738 Y-0.414 I0.342 J0.3092
    N117 G17 G03 X-0.3643 Y-0.4235 I0.0695 J0.0597
    N118 G17 G03 X-0.3122 Y-0.4664 I0.2784 J0.2849
    N119 G17 G03 X-0.3013 Y-0.4745 I0.0614 J0.0711
    N120 G17 G03 X-0.2846 Y-0.4861 I0.1186 J0.1533
    N121 G17 G03 X-0.2617 Y-0.5006 I0.2095 J0.3071
    N122 G17 G03 X-0.2258 Y-0.5198 I0.274 J0.4693
    N123 G17 G03 X-0.1884 Y-0.536 I0.4011 J0.8721
    N124 G17 G02 X-0.1694 Y-0.5433 I-0.2739 J-0.7399
    N125 G17 G02 X-0.1501 Y-0.5501 I-0.1452 J-0.4455
    N126 G17 G02 X-0.1306 Y-0.5563 I-0.0856 J-0.303
    N127 G17 G03 X-0.0706 Y-0.5689 I0.2752 J1.1604
    N128 G17 G02 X-0.0504 Y-0.5722 I-0.0423 J-0.3185
    N129 G17 G03 X-0.0096 Y-0.5757 I0.2447 J2.6537
    N130 G17 G02 X0.004 Y-0.5764 I-0.0014 J-0.1586
    N131 G01 X0.0314 Y-0.5763
    N132 G17 G03 X0.0723 Y-0.5735 I-0.0736 J1.3605
    N133 G17 G03 X0.0926 Y-0.5711 I-0.014 J0.2102
    N134 G17 G03 X0.1129 Y-0.5679 I-0.106 J0.722
    N135 G17 G03 X0.1331 Y-0.5642 I-0.0185 J0.1597
    N136 G17 G03 X0.1664 Y-0.5565 I-0.0606 J0.337
    N137 G17 G03 X0.1926 Y-0.5487 I-0.0833 J0.3282
    N138 G17 G03 X0.2438 Y-0.5293 I-0.1558 J0.4882
    N139 G17 G03 X0.2687 Y-0.5179 I-0.1452 J0.3488
    N140 G17 G03 X0.2931 Y-0.5054 I-0.1716 J0.3674
    N141 G17 G03 X0.317 Y-0.492 I-0.1103 J0.223
    N142 G17 G03 X0.3345 Y-0.4812 I-0.0968 J0.1776
    N143 G17 G03 X0.3627 Y-0.4618 I-2.7896 J4.0805
    N144 G17 G03 X0.3949 Y-0.4361 I-1.0407 J1.3381
    N145 G17 G03 X0.4201 Y-0.4128 I-0.3849 J0.4413
    N146 G17 G03 X0.4348 Y-0.3983 I-0.1297 J0.1464
    N147 G17 G03 X0.4622 Y-0.3676 I-0.3182 J0.3105
    N148 G17 G03 X0.4753 Y-0.3517 I-0.1333 J0.1234
    N149 G17 G03 X0.5105 Y-0.3009 I-0.355 J0.2845
    N150 G01 X0.521 Y-0.2832
    N151 G17 G03 X0.528 Y-0.2713 I-0.0934 J0.0631
    N152 G17 G03 X0.538 Y-0.2533 I-0.1717 J0.1069
    N153 G17 G03 X0.5474 Y-0.2349 I-0.1578 J0.0922
    N154 G17 G03 X0.5561 Y-0.2161 I-0.1744 J0.0924
    N155 G17 G03 X0.5641 Y-0.1971 I-0.1796 J0.0871
    N156 G17 G03 X0.5733 Y-0.1711 I-0.2194 J0.0923
    N157 G17 G03 X0.5918 Y-0.0976 I-0.7397 J0.2254
    N158 G17 G03 X0.5944 Y-0.084 I-0.1947 J0.0433
    N159 G17 G03 X0.5983 Y-0.0567 I-0.2319 J0.0473
    N160 G01 X0.601 Y-0.0292
    N161 G17 G02 X0.6021 Y-0.0155 I0.334 J-0.0181
    N162 G17 G03 X0.6027 Y0.0329 I-2.9941 J0.0622
    N163 G17 G03 X0.6002 Y0.0673 I-0.6619 J-0.0302
    N164 G17 G03 X0.5973 Y0.0948 I-0.2746 J-0.0151
    N165 G17 G03 X0.5953 Y0.1085 I-0.3917 J-0.0508
    N166 G17 G03 X0.5918 Y0.1289 I-0.1674 J-0.018
    N167 G01 X0.5877 Y0.1493
    N168 G17 G03 X0.5728 Y0.2026 I-0.6104 J-0.1425
    N169 G17 G03 X0.5642 Y0.229 I-0.2246 J-0.058
    N170 G17 G03 X0.5545 Y0.255 I-0.2562 J-0.0816
    N171 G17 G03 X0.5436 Y0.2806 I-0.2933 J-0.1097
    N172 G17 G03 X0.5316 Y0.3057 I-0.2599 J-0.1089
    N173 G17 G03 X0.5185 Y0.3303 I-0.2406 J-0.1113
    N174 G17 G03 X0.5009 Y0.3605 I-0.2569 J-0.1302
    N175 G17 G03 X0.4898 Y0.3783 I-0.1777 J-0.0987
    N176 G17 G03 X0.4696 Y0.4069 I-8.5775 J-6.0245
    N177 G17 G02 X0.4569 Y0.4238 I0.2502 J0.2018
    N178 G17 G03 X0.4342 Y0.4507 I-0.5803 J-0.4653
    N179 G17 G03 X0.4201 Y0.4665 I-0.1615 J-0.13
    N180 G17 G03 X0.4052 Y0.4817 I-1.1281 J-1.0914
    N181 G17 G03 X0.3692 Y0.5158 I-0.2607 J-0.2393
    N182 G17 G03 X0.3585 Y0.5253 I-0.0806 J-0.0799
    N183 G17 G03 X0.3248 Y0.5517 I-0.2322 J-0.261
    N184 G17 G02 X0.3014 Y0.5683 I0.4797 J0.7044
    N185 G01 X0.2834 Y0.5801
    N186 G17 G03 X0.2202 Y0.6146 I-0.3235 J-0.5185
    N187 G17 G03 X0.2072 Y0.6211 I-0.0507 J-0.0844
    N188 G01 X0.1941 Y0.6277
    N189 G17 G02 X0.1741 Y0.6366 I0.1482 J0.3558
    N190 G17 G02 X0.1606 Y0.6421 I0.0781 J0.2123
    N191 G17 G02 X0.14 Y0.6497 I0.1191 J0.3559
    N192 G17 G02 X0.1192 Y0.657 I0.097 J0.3102
    N193 G17 G02 X0.1052 Y0.6614 I0.0403 J0.1544
    N194 G17 G03 X0.0405 Y0.6755 I-0.2798 J-1.1208
    N195 G17 G02 X0.0186 Y0.6794 I0.1793 J1.0844
    N196 G17 G02 X0.0039 Y0.6816 I0.0297 J0.249
    N197 G17 G03 X-0.0405 Y0.6852 I-0.2664 J-2.9859
    N198 G17 G02 X-0.0629 Y0.6865 I0.0349 J0.8298
    N199 G17 G03 X-0.1151 Y0.6854 I-0.011 J-0.7208
    N200 G17 G03 X-0.1302 Y0.6847 I-0.0028 J-0.107
    N201 G17 G03 X-0.1526 Y0.6826 I0.032 J-0.4672
    N202 G01 X-0.1677 Y0.6816
    N203 G17 G03 X-0.1975 Y0.6769 I0.095 J-0.7029
    N204 G17 G03 X-0.2198 Y0.6727 I0.0208 J-0.174
    N205 G17 G03 X-0.2568 Y0.6641 I0.0709 J-0.3886
    N206 G01 X-0.2714 Y0.66
    N207 G17 G03 X-0.2933 Y0.6536 I0.0347 J-0.1593
    N208 G17 G03 X-0.3223 Y0.6439 I0.094 J-0.3287
    N209 G17 G03 X-0.3508 Y0.6328 I0.1404 J-0.4015
    N210 G17 G03 X-0.3718 Y0.6234 I0.1153 J-0.2875
    N211 G17 G03 X-0.4198 Y0.5992 I0.2676 J-0.5892
    N212 G17 G03 X-0.4465 Y0.5836 I0.1468 J-0.2833
    N213 G17 G03 X-0.4661 Y0.5712 I0.1201 J-0.2114
    N214 G17 G02 X-0.4791 Y0.5629 I-0.0804 J0.1106
    N215 G17 G03 X-0.5042 Y0.5446 I0.3433 J-0.4957
    N216 G17 G03 X-0.5345 Y0.5203 I0.1932 J-0.2729
    N217 G01 X-0.5522 Y0.505
    N218 G17 G03 X-0.5802 Y0.478 I5.9927 J-6.23
    N219 G17 G03 X-0.6067 Y0.4493 I1.0147 J-0.9628
    N220 G17 G03 X-0.632 Y0.4193 I0.2831 J-0.2646
    N221 G01 X-0.6511 Y0.3944
    N222 G17 G03 X-0.6775 Y0.3553 I0.5063 J-0.3695
    N223 G01 X-0.6863 Y0.3421
    N224 G17 G02 X-0.6945 Y0.3286 I-0.4584 J0.2688
    N225 G17 G03 X-0.7203 Y0.2796 I0.7248 J-0.4133
    N226 G17 G03 X-0.766 Y0.153 I0.6755 J-0.3156
    N227 G17 G03 X-0.7821 Y0.083 I0.9882 J-0.2628
    N228 G17 G02 X-0.7863 Y0.0593 I-0.5844 J0.0936
    N229 G17 G02 X-0.7888 Y0.0435 I-0.2055 J0.0232
    N230 G17 G03 X-0.7926 Y-0.0044 I0.8035 J-0.0883
    N231 G17 G03 X-0.794 Y-0.0285 I0.2479 J-0.0264
    N232 G17 G03 X-0.7946 Y-0.0446 I0.1163 J-0.0123
    N233 G17 G03 X-0.7941 Y-0.0687 I0.6285 J0.0004
    N234 G17 G03 X-0.7928 Y-0.1009 I0.2518 J-0.0064
    N235 G01 X-0.7908 Y-0.125
    N236 G17 G02 X-0.7893 Y-0.141 I-0.1636 J-0.0241
    N237 G17 G02 X-0.7846 Y-0.173 I-3.9309 J-0.5874
    N238 G17 G02 X-0.7767 Y-0.2126 I-4.2414 J-0.8708
    N239 G17 G03 X-0.7594 Y-0.2749 I0.6723 J0.1529
    N240 G17 G03 X-0.7519 Y-0.298 I0.2534 J0.069
    N241 G17 G03 X-0.7174 Y-0.3801 I0.6339 J0.2183
    N242 G01 X-0.7102 Y-0.3946
    N243 G17 G03 X-0.699 Y-0.4163 I0.1661 J0.0715
    N244 G17 G03 X-0.6914 Y-0.4307 I0.1264 J0.0583
    N245 G17 G03 X-0.6611 Y-0.4788 I0.6892 J0.3998
    N246 G17 G03 X-0.6472 Y-0.4989 I0.273 J0.1733
    N247 G17 G03 X-0.628 Y-0.5252 I0.2639 J0.1738
    N248 G17 G03 X-0.6181 Y-0.5382 I0.1072 J0.0708
    N249 G17 G03 X-0.6024 Y-0.5569 I0.4234 J0.3411
    N250 G17 G03 X-0.575 Y-0.5871 I0.2744 J0.22
    N251 G17 G03 X-0.5401 Y-0.6214 I0.3926 J0.3651
    N252 G17 G03 X-0.5095 Y-0.6486 I0.2685 J0.2717
    N253 G17 G03 X-0.4711 Y-0.679 I0.3004 J0.3395
    N254 G17 G02 X-0.4446 Y-0.6983 I-1.2124 J-1.6987
    N255 G17 G03 X-0.403 Y-0.7244 I0.3813 J0.5594
    N256 G17 G03 X-0.389 Y-0.733 I0.076 J0.1092
    N257 G17 G03 X-0.3457 Y-0.7563 I0.2685 J0.4451
    N258 G17 G03 X-0.3084 Y-0.7732 I0.311 J0.6382
    N259 G17 G03 X-0.2934 Y-0.78 I0.0585 J0.1094
    N260 G17 G03 X-0.2782 Y-0.7864 I0.0566 J0.1133
    N261 G17 G03 X-0.2553 Y-0.7955 I0.0911 J0.1942
    N262 G17 G03 X-0.2398 Y-0.8011 I0.0573 J0.1364
    N263 G17 G03 X-0.2242 Y-0.8062 I0.0518 J0.131
    N264 G01 X-0.2086 Y-0.8113
    N265 G17 G02 X-0.1927 Y-0.8159 I-0.0549 J-0.219
    N266 G17 G02 X-0.1689 Y-0.8224 I-0.0832 J-0.3501
    N267 G17 G02 X-0.1529 Y-0.8262 I-0.0322 J-0.1708
    N268 G17 G03 X-0.0878 Y-0.8366 I0.2605 J1.4224
    N269 G17 G03 X-0.0468 Y-0.8411 I0.215 J1.7627
    N270 G17 G03 X0.0108 Y-0.8434 I0.1074 J2.0432
    N271 G17 G02 X0.0273 Y-0.8436 I0.0048 J-0.2593
    N272 G17 G03 X0.0603 Y-0.8424 I-0.002 J0.5135
    N273 G17 G03 X0.085 Y-0.841 I-0.0072 J0.3557
    N274 G17 G03 X0.1097 Y-0.8389 I-0.0051 J0.2039
    N275 G17 G03 X0.1425 Y-0.835 I-0.7833 J6.7314
    N276 G17 G03 X0.175 Y-0.8292 I-0.1712 J1.0458
    N277 G17 G03 X0.1993 Y-0.8244 I-0.0329 J0.2312
    N278 G17 G03 X0.2154 Y-0.8206 I-0.2115 J0.9484
    N279 G17 G03 X0.2395 Y-0.8147 I-0.0421 J0.221
    N280 G17 G03 X0.2869 Y-0.8001 I-0.1615 J0.6106
    N281 G17 G03 X0.3103 Y-0.7921 I-0.0578 J0.2076
    N282 G17 G03 X0.3564 Y-0.7737 I-0.1958 J0.5555
    N283 G17 G03 X0.4657 Y-0.7152 I-0.3367 J0.7604
    N284 G17 G03 X0.5138 Y-0.683 I-0.537 J0.8548
    N285 G17 G03 X0.5337 Y-0.6682 I-0.1838 J0.2692
    N286 G17 G03 X0.547 Y-0.6583 I-0.0761 J0.1157
    N287 G17 G03 X0.5788 Y-0.6318 I-1.184 J1.4536
    N288 G17 G03 X0.6207 Y-0.5918 I-0.6126 J0.6836
    N289 G17 G03 X0.6325 Y-0.5801 I-0.102 J0.1149
    N290 G17 G03 X0.6813 Y-0.5238 I-0.5689 J0.5424
    N291 G17 G03 X0.6919 Y-0.511 I-0.0995 J0.0925
    N292 G17 G03 X0.721 Y-0.4707 I-0.3984 J0.3186
    N293 G17 G03 X0.7436 Y-0.4359 I-0.8392 J0.5697
    N294 G17 G03 X0.7601 Y-0.4072 I-1.2202 J0.7199
    N295 G17 G03 X0.7722 Y-0.3854 I-0.2088 J0.1306
    N296 G17 G03 X0.7908 Y-0.3483 I-0.4731 J0.2607
    N297 G17 G03 X0.8187 Y-0.2791 I-0.7359 J0.3368
    N298 G17 G03 X0.8276 Y-0.2558 I-0.1825 J0.0834
    N299 G17 G03 X0.833 Y-0.2401 I-0.1355 J0.0551
    N300 G17 G03 X0.8381 Y-0.2243 I-0.1416 J0.0539
    N301 G01 X0.8431 Y-0.2084
    N302 G17 G02 X0.8476 Y-0.1924 I0.2319 J-0.0557
    N303 G17 G03 X0.8662 Y-0.086 I-0.945 J0.2198
    N304 G17 G03 X0.8691 Y-0.0612 I-0.3137 J0.0497
    N305 G17 G03 X0.8711 Y-0.0363 I-0.2323 J0.0315
    N306 G17 G03 X0.8728 Y0.0136 I-8.3889 J0.3131
    N307 G17 G02 X0.873 Y0.0303 I0.2414 J0.0057
    N308 G17 G03 X0.8705 Y0.0802 I-1.0732 J-0.0286
    N309 G17 G03 X0.865 Y0.1299 I-1.0809 J-0.0944
    N310 G17 G03 X0.8615 Y0.1546 I-0.2334 J-0.0202
    N311 G17 G02 X0.8574 Y0.1793 I1.4974 J0.2644
    N312 G17 G03 X0.8503 Y0.2118 I-0.9978 J-0.2003
    N313 G17 G03 X0.8426 Y0.2443 I-0.3308 J-0.0612
    N314 G17 G03 X0.8382 Y0.2604 I-0.6203 J-0.1615
    N315 G17 G03 X0.8312 Y0.2844 I-0.2102 J-0.0478
    N316 G17 G03 X0.8148 Y0.3317 I-0.5842 J-0.1765
    N317 G17 G03 X0.8059 Y0.3552 I-0.2635 J-0.0871
    N318 G17 G03 X0.7963 Y0.3783 I-0.2656 J-0.0962
    N319 G17 G03 X0.7634 Y0.446 I-0.7591 J-0.3275
    N320 G17 G03 X0.7515 Y0.4682 I-0.1738 J-0.0784
    N321 G17 G03 X0.7391 Y0.4901 I-0.2192 J-0.1107
    N322 G17 G02 X0.7305 Y0.5046 I0.2659 J0.1663
    N323 G01 X0.7214 Y0.5186
    N324 G17 G03 X0.7124 Y0.5329 I-0.1127 J-0.0609
    N325 G17 G03 X0.6779 Y0.5806 I-0.9501 J-0.6512
    N326 G17 G03 X0.6622 Y0.6004 I-0.4089 J-0.308
    N327 G17 G03 X0.6461 Y0.6199 I-0.206 J-0.1532
    N328 G17 G03 X0.6179 Y0.6513 I-0.7859 J-0.6767
    N329 G17 G03 X0.5886 Y0.6818 I-0.289 J-0.2497
    N330 G17 G03 X0.5512 Y0.7163 I-0.4106 J-0.4066
    N331 G17 G03 X0.5253 Y0.7382 I-0.2833 J-0.3079
    N332 G17 G02 X0.5056 Y0.7545 I1.0945 J1.3493
    N333 G17 G02 X0.4716 Y0.7802 I1.3007 J1.756
    N334 G17 G03 X0.429 Y0.8085 I-0.4658 J-0.6559
    N335 G17 G03 X0.4145 Y0.8177 I-0.1059 J-0.1491
    N336 G17 G03 X0.3775 Y0.8392 I-0.2794 J-0.4402
    N337 G17 G03 X0.3625 Y0.8476 I-0.0716 J-0.1101
    N338 G17 G03 X0.3006 Y0.8775 I-0.3019 J-0.5458
    N339 G17 G03 X0.2686 Y0.8904 I-0.4778 J-1.1409
    N340 G17 G03 X0.2446 Y0.9002 I-0.1014 J-0.2121
    N341 G17 G03 X0.2283 Y0.9062 I-0.061 J-0.14
    N342 G17 G03 X0.212 Y0.9119 I-0.0597 J-0.147
    N343 G17 G03 X0.1872 Y0.92 I-0.0964 J-0.2533
    N344 G17 G03 X0.1705 Y0.9248 I-0.0605 J-0.1773
    N345 G17 G03 X0.1538 Y0.9293 I-0.0564 J-0.177
    N346 G17 G03 X0.1284 Y0.9357 I-0.0795 J-0.2594
    N347 G17 G03 X0.1114 Y0.9395 I-0.0472 J-0.1725
    N348 G17 G03 X0.0943 Y0.943 I-0.0394 J-0.1505
    N349 G17 G03 X0.0772 Y0.9462 I-0.0344 J-0.1367
    N350 G17 G02 X0.06 Y0.9492 I0.0235 J0.1838
    N351 G17 G03 X-0.0183 Y0.957 I-0.238 J-1.9936
    N352 G17 G02 X-0.0358 Y0.9581 I0.0079 J0.257
    N353 G17 G03 X-0.0885 Y0.9584 I-0.0332 J-1.1819
    N354 G17 G03 X-0.1149 Y0.9579 I-0.0048 J-0.4187
    N355 G17 G03 X-0.1325 Y0.9574 I-0.005 J-0.1385
    N356 G01 X-0.1677 Y0.9549
    N357 G17 G02 X-0.1853 Y0.9535 I-0.0258 J0.2102
    N358 G17 G03 X-0.2203 Y0.9487 I0.209 J-1.6591
    N359 G17 G03 X-0.2466 Y0.9445 I0.027 J-0.2547
    N360 G17 G02 X-0.2727 Y0.9397 I-0.3255 J1.6977
    N361 G17 G02 X-0.316 Y0.9297 I-0.766 J3.22
    N362 G17 G03 X-0.3502 Y0.9201 I0.6385 J-2.3341
    N363 G17 G03 X-0.3758 Y0.9125 I0.0628 J-0.2585
    N364 G17 G03 X-0.3927 Y0.9069 I0.1033 J-0.3402
    N365 G17 G03 X-0.4098 Y0.9014 I0.0323 J-0.1295
    N366 G17 G02 X-0.4266 Y0.8954 I-0.1307 J0.3373
    N367 G17 G03 X-0.4842 Y0.8708 I0.2949 J-0.7707
    N368 G17 G03 X-0.5085 Y0.8595 I0.076 J-0.1953
    N369 G17 G03 X-0.5326 Y0.8473 I0.0991 J-0.2258
    N370 G17 G03 X-0.5642 Y0.8302 I0.1558 J-0.3247
    N371 G17 G03 X-0.5874 Y0.8164 I0.1548 J-0.2884
    N372 G17 G03 X-0.6103 Y0.802 I0.1394 J-0.2469
    N373 G17 G03 X-0.6328 Y0.787 I0.1222 J-0.2082
    N374 G17 G03 X-0.6478 Y0.7769 I0.0728 J-0.1238
    N375 G17 G03 X-0.6906 Y0.7437 I0.5697 J-0.7789
    N376 G17 G03 X-0.7115 Y0.7264 I0.1881 J-0.2481
    N377 G17 G03 X-0.7254 Y0.7148 I0.0926 J-0.1248
    N378 G17 G03 X-0.7453 Y0.6963 I0.8718 J-0.9628
    N379 G17 G03 X-0.765 Y0.6775 I0.231 J-0.2598
    N380 G17 G03 X-0.7781 Y0.6648 I0.0996 J-0.1163
    N381 G17 G03 X-0.7967 Y0.645 I0.4501 J-0.4424
    N382 G17 G03 X-0.8152 Y0.6249 I0.2285 J-0.2283
    N383 G17 G02 X-0.833 Y0.6042 I-0.4849 J0.4
    N384 G17 G03 X-0.8556 Y0.5755 I0.7338 J-0.5998
    N385 G17 G03 X-0.8668 Y0.5611 I0.134 J-0.1162
    N386 G17 G03 X-0.8877 Y0.5312 I0.4063 J-0.3068
    N387 G17 G02 X-0.8981 Y0.5162 I-0.8795 J0.5968
    N388 G17 G03 X-0.9267 Y0.4693 I0.8356 J-0.5407
    N389 G17 G03 X-0.9359 Y0.4535 I0.172 J-0.1116
    N390 G17 G03 X-0.9611 Y0.4046 I0.5423 J-0.3095
    N391 G17 G02 X-0.9693 Y0.3882 I-0.4317 J0.2068
    N392 G17 G02 X-0.9771 Y0.3715 I-0.9614 J0.4386
    N393 G17 G03 X-1.0042 Y0.3032 I0.8464 J-0.3758
    N394 G17 G03 X-1.0108 Y0.286 I0.1227 J-0.057
    N395 G17 G03 X-1.017 Y0.2686 I0.1335 J-0.0573
    N396 G17 G03 X-1.0228 Y0.2511 I0.1456 J-0.0578
    N397 G17 G03 X-1.0282 Y0.2334 I0.155 J-0.0573
    N398 G17 G03 X-1.036 Y0.2068 I0.27 J-0.0935
    N399 G17 G03 X-1.0406 Y0.1889 I0.1885 J-0.058
    N400 G17 G03 X-1.0449 Y0.1709 I0.18 J-0.0521
    N401 G17 G03 X-1.0489 Y0.1528 I0.1755 J-0.0478
    N402 G17 G03 X-1.0525 Y0.1347 I0.159 J-0.0412
    N403 G17 G03 X-1.0558 Y0.1164 I0.144 J-0.0356
    N404 G01 X-1.0595 Y0.0982
    N405 G17 G03 X-1.0666 Y0.0244 I1.9968 J-0.2276
    N406 G17 G02 X-1.0684 Y-0.0035 I-0.8532 J0.0418
    N407 G17 G02 X-1.0693 Y-0.022 I-0.2034 J0.0011
    N408 G17 G03 X-1.0688 Y-0.0685 I1.2 J-0.0093
    N409 G17 G03 X-1.0672 Y-0.1057 I0.392 J-0.0019
    N410 G17 G02 X-1.0643 Y-0.1428 I-4.2268 J-0.3439
    N411 G17 G02 X-1.0627 Y-0.1614 I-0.181 J-0.025
    N412 G17 G03 X-1.0575 Y-0.1983 I1.3074 J0.1648
    N413 G17 G03 X-1.0548 Y-0.2167 I0.1662 J0.0153
    N414 G17 G03 X-1.0495 Y-0.2442 I2.1424 J0.3962
    N415 G17 G03 X-1.0438 Y-0.2716 I0.2852 J0.0456
    N416 G17 G02 X-1.0373 Y-0.2988 I-4.3123 J-1.0415
    N417 G17 G02 X-1.0249 Y-0.3439 I-5.9004 J-1.6497
    N418 G17 G03 X-1.0162 Y-0.3705 I1.2896 J0.405
    N419 G17 G03 X-1.0105 Y-0.3883 I0.1589 J0.0415
    N420 G17 G02 X-1.0042 Y-0.406 I-1.1488 J-0.4166
    N421 G17 G03 X-0.9904 Y-0.4407 I1.318 J0.5054
    N422 G17 G03 X-0.9835 Y-0.4581 I0.1421 J0.046
    N423 G17 G02 X-0.9762 Y-0.4754 I-0.3382 J-0.154
    N424 G17 G02 X-0.9643 Y-0.5008 I-1.5413 J-0.7347
    N425 G17 G03 X-0.8506 Y-0.6837 I0.9749 J0.479
    N426 G17 G03 X-0.8334 Y-0.706 I0.5301 J0.3923
    N427 G17 G03 X-0.8157 Y-0.728 I0.3013 J0.2247
    N428 G17 G03 X-0.8037 Y-0.7424 I0.1525 J0.1147
    N429 G17 G03 X-0.7848 Y-0.7633 I0.7543 J0.6635
    N430 G17 G03 X-0.7654 Y-0.7839 I0.2965 J0.2602
    N431 G17 G03 X-0.7524 Y-0.7975 I0.1345 J0.1152
    N432 G01 X-0.7253 Y-0.8236
    N433 G17 G03 X-0.6828 Y-0.8609 I1.0359 J1.1395
    N434 G01 X-0.6536 Y-0.8846
    N435 G17 G03 X-0.6309 Y-0.9015 I11.945 J15.9775
    N436 G17 G03 X-0.6081 Y-0.9183 I0.2313 J0.292
    N437 G17 G02 X-0.5849 Y-0.9344 I-0.3085 J-0.4689
    N438 G17 G03 X-0.5449 Y-0.9595 I0.4576 J0.6844
    N439 G17 G03 X-0.4875 Y-0.9922 I0.3459 J0.5405
    N440 G17 G03 X-0.4709 Y-1.0012 I0.0851 J0.1372
    N441 G17 G03 X-0.4455 Y-1.0139 I0.2137 J0.3966
    N442 G17 G03 X-0.3935 Y-1.0364 I0.3748 J0.7926
    N443 G17 G03 X-0.376 Y-1.0438 I0.0718 J0.1463
    N444 G17 G03 X-0.3584 Y-1.0507 I0.0794 J0.1767
    N445 G17 G03 X-0.3406 Y-1.0572 I0.0862 J0.2077
    N446 G17 G03 X-0.2592 Y-1.0822 I0.2752 J0.7519
    N447 G17 G03 X-0.1385 Y-1.1065 I0.3012 J1.1831
    N448 G17 G03 X-0.1104 Y-1.1106 I0.2787 J1.8172
    N449 G17 G02 X-0.0916 Y-1.1129 I-0.0378 J-0.3826
    N450 G17 G02 X-0.0727 Y-1.115 I-0.0198 J-0.2665
    N451 G17 G02 X-0.0538 Y-1.1168 I-0.0095 J-0.1973
    N452 G17 G03 X0.0126 Y-1.1191 I0.1558 J3.5551
    N453 G17 G02 X0.0316 Y-1.1194 I0.0057 J-0.2918
    N454 G17 G02 X0.0506 Y-1.1194 I0.0087 J-0.1884
    N455 G17 G03 X0.098 Y-1.1171 I-0.4767 J10.067
    N456 G17 G02 X0.1169 Y-1.1158 I0.0369 J-0.407
    N457 G17 G03 X0.1641 Y-1.1105 I-0.1446 J1.4846
    N458 G17 G03 X0.1924 Y-1.1067 I-0.022 J0.2736
    N459 G17 G02 X0.2205 Y-1.1022 I0.2453 J-1.4328
    N460 G17 G03 X0.2855 Y-1.0879 I-0.2302 J1.202
    N461 G17 G03 X0.3405 Y-1.0727 I-0.2207 J0.9049
    N462 G17 G03 X0.3677 Y-1.0642 I-0.0934 J0.3502
    N463 G01 X0.3857 Y-1.0581
    N464 G17 G03 X0.4127 Y-1.0487 I-0.077 J0.263
    N465 G17 G03 X0.4741 Y-1.0232 I-0.2853 J0.7742
    N466 G17 G03 X0.5425 Y-0.9899 I-0.3269 J0.7588
    N467 G17 G03 X0.5595 Y-0.9813 I-0.0608 J0.1409
    N468 G17 G02 X0.5763 Y-0.9723 I0.1334 J-0.2292
    N469 G17 G02 X0.6011 Y-0.958 I0.3184 J-0.5231
    N470 G17 G02 X0.6254 Y-0.9431 I0.3769 J-0.5877
    N471 G17 G02 X0.6494 Y-0.9275 I0.3905 J-0.5763
    N472 G17 G02 X0.673 Y-0.9114 I0.3681 J-0.5134
    N473 G17 G03 X0.7478 Y-0.8525 I-0.8515 J1.1586
    N474 G17 G03 X0.7972 Y-0.8076 I-0.6261 J0.7379
    N475 G17 G03 X0.8176 Y-0.7877 I-0.3258 J0.3534
    N476 G17 G03 X0.8377 Y-0.7673 I-0.2072 J0.2247
    N477 G17 G03 X0.8634 Y-0.7392 I-0.8722 J0.8257
    N478 G17 G03 X0.9059 Y-0.6877 I-0.8002 J0.7033
    N479 G17 G03 X0.9289 Y-0.6574 I-0.3947 J0.3232
    N480 G17 G02 X0.9402 Y-0.642 I0.5891 J-0.4213
    N481 G17 G03 X0.9819 Y-0.5781 I-1.1109 J0.7705
    N482 G17 G02 X0.9968 Y-0.5536 I0.456 J-0.2598
    N483 G17 G03 X1.024 Y-0.5033 I-0.8232 J0.4779
    N484 G17 G03 X1.0329 Y-0.4864 I-0.1424 J0.086
    N485 G17 G03 X1.0414 Y-0.4693 I-0.2157 J0.1175
    N486 G17 G03 X1.0712 Y-0.399 I-0.7781 J0.3717
    N487 G17 G02 X1.0784 Y-0.3813 I2.9211 J-1.176
    N488 G17 G02 X1.0851 Y-0.3634 I0.9389 J-0.339
    N489 G17 G03 X1.1293 Y-0.1974 I-1.01 J0.3578
    N490 G17 G03 X1.141 Y-0.1219 I-1.1694 J0.2202
    N491 G17 G03 X1.1433 Y-0.1029 I-0.3497 J0.0517
    N492 G17 G03 X1.1453 Y-0.0839 I-0.2521 J0.0368
    N493 G17 G03 X1.1471 Y-0.0649 I-0.204 J0.0291
    N494 G17 G03 X1.1492 Y-0.0362 I-0.2598 J0.033
    N495 G17 G03 X1.1503 Y0.0211 I-1.3434 J0.0541
    N496 G17 G03 X1.1503 Y0.0403 I-0.2298 J0.0097
    N497 G17 G03 X1.1501 Y0.0594 I-0.1647 J0.0083
    N498 G17 G03 X1.1471 Y0.1072 I-1.5393 J-0.0734
    N499 G17 G03 X1.1447 Y0.1358 I-0.3061 J-0.0117
    N500 G17 G03 X1.1412 Y0.1643 I-1.5065 J-0.1664
    N501 G17 G03 X1.1374 Y0.1928 I-0.3142 J-0.0282
    N502 G17 G02 X1.1327 Y0.2211 I2.1437 J0.368
    N503 G17 G02 X1.1296 Y0.24 I0.2033 J0.0434
    N504 G17 G03 X1.1194 Y0.2868 I-17.8364 J-3.8449
    N505 G17 G03 X1.1122 Y0.3146 I-2.5696 J-0.6558
    N506 G17 G03 X1.1047 Y0.3424 I-0.295 J-0.0645
    N507 G17 G03 X1.0991 Y0.3608 I-0.6587 J-0.1897
    N508 G17 G03 X1.0936 Y0.3791 I-0.1566 J-0.0367
    N509 G17 G03 X1.0776 Y0.4243 I-0.8013 J-0.2594
    N510 G17 G03 X1.0601 Y0.469 I-0.6206 J-0.2164
    N511 G17 G03 X1.053 Y0.4868 I-0.1518 J-0.0504
    N512 G17 G02 X1.0454 Y0.5045 I0.3786 J0.1729
    N513 G17 G02 X1.0332 Y0.5306 I5.4576 J2.5639
    N514 G17 G03 X1.002 Y0.5902 I-1.1545 J-0.5679
    N515 G17 G03 X0.9927 Y0.607 I-0.295 J-0.1521
    N516 G17 G03 X0.9633 Y0.6567 I-0.7799 J-0.4283
    N517 G17 G03 X0.9314 Y0.7048 I-0.8662 J-0.5388
    N518 G17 G03 X0.9146 Y0.7284 I-0.4229 J-0.2835
    N519 G17 G03 X0.8973 Y0.7516 I-0.3356 J-0.2313
    N520 G17 G03 X0.8794 Y0.7744 I-0.2425 J-0.1723
    N521 G17 G03 X0.8674 Y0.7895 I-0.1358 J-0.0953
    N522 G17 G03 X0.8225 Y0.8402 I-2.0206 J-1.7474
    N523 G17 G03 X0.7817 Y0.8814 I-0.9536 J-0.9039
    N524 G17 G03 X0.7607 Y0.9015 I-0.2812 J-0.2722
    N525 G17 G03 X0.7467 Y0.9149 I-0.1353 J-0.1276
    N526 G17 G02 X0.7177 Y0.9408 I13.9122 J15.6367
    N527 G17 G03 X0.6951 Y0.9591 I-12.6165 J-15.4903
    N528 G17 G03 X0.6723 Y0.9774 I-0.2397 J-0.2759
    N529 G17 G02 X0.6491 Y0.9951 I0.6453 J0.8707
    N530 G17 G02 X0.6174 Y1.0177 I1.1446 J1.6385
    N531 G17 G03 X0.5848 Y1.0391 I-0.7651 J-1.1265
    N532 G17 G03 X0.5685 Y1.0499 I-0.0982 J-0.1304
    N533 G17 G03 X0.535 Y1.07 I-0.2973 J-0.4584
    N534 G17 G03 X0.5181 Y1.0798 I-0.1365 J-0.2161
    N535 G17 G03 X0.4749 Y1.1028 I-0.3383 J-0.5823
    N536 G17 G03 X0.4573 Y1.1113 I-0.052 J-0.0854
    N537 G17 G03 X0.4606 Y1.1099 I-0.4506 J-1.1049
    N538 G01 X0.4483 Y1.1253
    N539 G01 X0.4447 Y1.1446
    N540 G01 X0.4429 Y1.1642
    N541 G01 X0.4327 Y1.181
    N542 G01 X0.4167 Y1.1926
    N543 G01 X0.3979 Y1.1983
    N544 G01 X0.3948 Y1.2
    N545 G01 X-0.747
    N546 G17 G03 X-0.8022 Y1.1791 I0.2837 J-0.8307
    N547 G01 X-0.8376 Y1.1619
    N548 G17 G03 X-0.8891 Y1.1329 I0.3099 J-0.6104
    N549 G17 G03 X-0.9544 Y1.0891 I0.7897 J-1.2484
    N550 G17 G03 X-0.9857 Y1.0652 I0.4448 J-0.6141
    N551 G17 G03 X-1.0737 Y0.9864 I0.8716 J-1.0613
    N552 G01 X-1.1013 Y0.9583
    N553 G01 X-1.1147 Y0.9439
    N554 G01 X-1.1534 Y0.8993
    N555 G01 X-1.1659 Y0.8841
    N556 G01 X-1.1898 Y0.8528
    N557 G01 X-1.1972 Y0.8346
    N558 G01 X-1.2 Y0.8293
    N559 G01 Y-0.7258
    N560 G01 X-1.1868 Y-0.7629
    N561 G17 G03 X-1.1547 Y-0.8347 I0.6131 J0.2305
    N562 G01 X-1.1359 Y-0.8693
    N563 G17 G03 X-1.1156 Y-0.903 I0.6587 J0.3755
    N564 G17 G03 X-1.0707 Y-0.9677 I1.236 J0.809
    N565 G17 G03 X-1.0203 Y-1.0281 I0.6211 J0.4673
    N566 G01 X-1.0076 Y-1.0432
    N567 G01 X-0.9804 Y-1.0717
    N568 G01 X-0.9664 Y-1.0855
    N569 G01 X-0.9231 Y-1.1256
    N570 G01 X-0.9082 Y-1.1386
    N571 G17 G03 X-0.8465 Y-1.1874 I0.947 J1.1337
    N572 G17 G02 X-0.8214 Y-1.2 I-0.1923 J-0.4131
    N573 G01 X0.7337
    N574 G17 G03 X0.8074 Y-1.1725 I-0.1919 J0.6262
    N575 G01 X0.8431 Y-1.1559
    N576 G17 G03 X0.895 Y-1.1277 I-0.3004 J0.6151
    N577 G01 X0.9283 Y-1.1068
    N578 G17 G03 X0.9923 Y-1.0609 I-0.6152 J0.9261
    N579 G01 X1.0076 Y-1.0485
    N580 G01 X1.0522 Y-1.0098
    N581 G01 X1.0666 Y-0.9964
    N582 G17 G03 X1.1482 Y-0.911 I-0.9514 J0.9904
    N583 G01 X1.1609 Y-0.896
    N584 G01 X1.1853 Y-0.8651
    N585 G01 X1.2 Y-0.8386
    N586 G01 Y0.7559
    N587 G01 X1.1868 Y0.7929
    N588 G01 X1.1796 Y0.8113
    N589 G01 X1.163 Y0.847
    N590 G17 G03 X1.1448 Y0.8819 I-0.6808 J-0.3338
    N591 G01 X1.1249 Y0.9159
    N592 G01 X1.103 Y0.9486
    N593 G01 X1.0915 Y0.9646
    N594 G17 G03 X1.0169 Y1.0561 I-1.1007 J-0.8212
    N595 G17 G03 X0.9617 Y1.1122 I-0.8197 J-0.7512
    N596 G01 X0.9178 Y1.1516
    N597 G01 X0.9027 Y1.1643
    N598 G01 X0.8718 Y1.1887
    N599 G01 X0.8538 Y1.1967
    N600 G01 X0.8477 Y1.2
    N601 G01 X0.3752
    N602 G01 X0.3687 Y1.1995 Z-0.2499
    N603 G01 X0.3624 Y1.1978 Z-0.2497
    N604 G01 X0.3564 Y1.1952 Z-0.2495
    N605 G01 X0.3509 Y1.1916 Z-0.2492
    N606 G01 X0.3461 Y1.1871 Z-0.2487
    N607 G01 X0.3421 Y1.1819 Z-0.2477
    N608 G01 X0.339 Y1.1761 Z-0.2455
    N609 G01 X0.337 Y1.1699 Z-0.2402
    N610 G01 X0.336 Y1.1634 Z-0.2348
    N611 G01 X0.336 Y1.1569 Z-0.2326
    N612 G01 X0.3372 Y1.1504 Z-0.2317
    N613 G01 X0.3394 Y1.1443 Z-0.2311
    N614 G01 X0.3426 Y1.1386 Z-0.2308
    N615 G01 X0.3468 Y1.1335 Z-0.2306
    N616 G01 X0.3517 Y1.1291 Z-0.2304
    N617 G01 X0.3572 Y1.1256 Z-0.2303
    N618 G01 X1.1426 Y0.7209
    N619 G01 X1.1488 Y0.7183 Z-0.2305
    N620 G01 X1.1553 Y0.7168 Z-0.2307
    N621 G01 X1.162 Y0.7165 Z-0.2311
    N622 G01 X1.1687 Y0.7173 Z-0.2319
    N623 G01 X1.1751 Y0.7192 Z-0.2338
    N624 G01 X1.1811 Y0.7222 Z-0.2402
    N625 G01 X1.1865 Y0.7262 Z-0.2465
    N626 G01 X1.1912 Y0.731 Z-0.2484
    N627 G01 X1.195 Y0.7366 Z-0.2492
    N628 G01 X1.1977 Y0.7427 Z-0.2496
    N629 G01 X1.1994 Y0.7492 Z-0.2498
    N630 G01 X1.2 Y0.7559 Z-0.25
    N631 G01 Y1.1299
    N632 G17 G03 X1.1857 Y1.1665 I-0.3506 J-0.1161
    N633 G01 X1.1746 Y1.1828
    N634 G01 X1.1581 Y1.1936
    N635 G01 X1.1391 Y1.1987
    N636 G01 X1.1366 Y1.2
    N637 G01 X0.8413
    N638 G01 X0.8347 Y1.1994 Z-0.2499
    N639 G01 X0.8283 Y1.1978 Z-0.2498
    N640 G01 X0.8222 Y1.195 Z-0.2496
    N641 G01 X0.8167 Y1.1913 Z-0.2493
    N642 G01 X0.8119 Y1.1867 Z-0.249
    N643 G01 X0.8079 Y1.1814 Z-0.2484
    N644 G01 X0.8049 Y1.1755 Z-0.2474
    N645 G01 X0.8029 Y1.1691 Z-0.2451
    N646 G01 X0.802 Y1.1625 Z-0.2402
    N647 G01 X0.8023 Y1.1559 Z-0.2352
    N648 G01 X0.8036 Y1.1494 Z-0.233
    N649 G01 X0.8061 Y1.1432 Z-0.2319
    N650 G01 X0.8095 Y1.1375 Z-0.2313
    N651 G01 X0.8139 Y1.1324 Z-0.231
    N652 G01 X0.819 Y1.1282 Z-0.2307
    N653 G01 X0.8248 Y1.1249 Z-0.2306
    N654 G01 X0.831 Y1.1226 Z-0.2304
    N655 G01 X0.8376 Y1.1214 Z-0.2303
    N656 G01 X1.1569 Y1.0907
    N657 G01 X1.1634 Y1.0906 Z-0.2305
    N658 G01 X1.1699 Y1.0916 Z-0.2309
    N659 G01 X1.1761 Y1.0937 Z-0.2315
    N660 G01 X1.1819 Y1.0967 Z-0.2333
    N661 G01 X1.1871 Y1.1007 Z-0.2402
    N662 G01 X1.1916 Y1.1055 Z-0.247
    N663 G01 X1.1952 Y1.111 Z-0.2488
    N664 G01 X1.1978 Y1.117 Z-0.2494
    N665 G01 X1.1995 Y1.1233 Z-0.2498
    N666 G01 X1.2 Y1.1299 Z-0.25
    N667 G17 G03 X1.1998 Y1.1551 I-0.6238 J0.008
    N668 G17 G03 X1.1508 Y1.2 I-0.0491 J-0.0044
    N669 G01 X1.1311
    N670 G01 X0.5051 Z-0.2303
    N671 G01 X-0.121
    N672 G01 X-0.747 Z-0.25
    N673 G01 X-1.1013
    N674 G17 G03 X-1.1569 Y1.1802 I0.2015 J-0.6542
    N675 G01 X-1.1748 Y1.1719
    N676 G01 X-1.1886 Y1.1579
    N677 G01 X-1.1966 Y1.1399
    N678 G01 X-1.2 Y1.1337
    N679 G01 Y0.8187
    N680 G01 X-1.1995 Y0.8122 Z-0.2499
    N681 G01 X-1.1979 Y0.806 Z-0.2498
    N682 G01 X-1.1953 Y0.8 Z-0.2496
    N683 G01 X-1.1917 Y0.7946 Z-0.2493
    N684 G01 X-1.1873 Y0.7898 Z-0.249
    N685 G01 X-1.1822 Y0.7858 Z-0.2484
    N686 G01 X-1.1765 Y0.7827 Z-0.2474
    N687 G01 X-1.1704 Y0.7806 Z-0.2451
    N688 G01 X-1.164 Y0.7795 Z-0.2402
    N689 G01 X-1.1575 Z-0.2352
    N690 G01 X-1.1511 Y0.7805 Z-0.233
    N691 G01 X-1.145 Y0.7826 Z-0.2319
    N692 G01 X-1.1392 Y0.7857 Z-0.2313
    N693 G01 X-1.1341 Y0.7896 Z-0.231
    N694 G01 X-1.1297 Y0.7944 Z-0.2307
    N695 G01 X-1.1261 Y0.7998 Z-0.2306
    N696 G01 X-1.1235 Y0.8057 Z-0.2304
    N697 G01 X-1.1218 Y0.812 Z-0.2303
    N698 G01 X-1.0625 Y1.1539
    N699 G01 X-1.0619 Y1.1607 Z-0.2305
    N700 G01 X-1.0626 Y1.1676 Z-0.2309
    N701 G01 X-1.0643 Y1.1742 Z-0.2315
    N702 G01 X-1.0672 Y1.1804 Z-0.2333
    N703 G01 X-1.0712 Y1.186 Z-0.2402
    N704 G01 X-1.076 Y1.1908 Z-0.247
    N705 G01 X-1.0817 Y1.1947 Z-0.2488
    N706 G01 X-1.0879 Y1.1976 Z-0.2494
    N707 G01 X-1.0945 Y1.1994 Z-0.2498
    N708 G01 X-1.1013 Y1.2 Z-0.25
    N709 G01 X-1.1508
    N710 G17 G03 X-1.2 Y1.1508 I0.0001 J-0.0493
    N711 G01 Y1.1311
    N712 G01 Y-0.7258
    N713 G01 Y-1.0998
    N714 G01 X-1.1868 Y-1.1369
    N715 G17 G03 X-1.1702 Y-1.1726 I0.3427 J0.1376
    N716 G01 X-1.157 Y-1.1871
    N717 G17 G02 X-1.1317 Y-1.2 I-0.2479 J-0.5168
    N718 G01 X-0.8168
    N719 G01 X-0.81 Y-1.1994 Z-0.2499
    N720 G01 X-0.8033 Y-1.1976 Z-0.2497
    N721 G01 X-0.7971 Y-1.1947 Z-0.2495
    N722 G01 X-0.7915 Y-1.1908 Z-0.2493
    N723 G01 X-0.7866 Y-1.1859 Z-0.2488
    N724 G01 X-0.7827 Y-1.1803 Z-0.2481
    N725 G01 X-0.7798 Y-1.1741 Z-0.2467
    N726 G01 X-0.778 Y-1.1675 Z-0.2432
    N727 G01 X-0.7774 Y-1.1606 Z-0.2372
    N728 G01 X-0.778 Y-1.1538 Z-0.2337
    N729 G01 X-0.7798 Y-1.1472 Z-0.2322
    N730 G01 X-0.7827 Y-1.141 Z-0.2315
    N731 G01 X-0.7866 Y-1.1353 Z-0.231
    N732 G01 X-0.7915 Y-1.1305 Z-0.2308
    N733 G01 X-0.7971 Y-1.1265 Z-0.2306
    N734 G01 X-0.8033 Y-1.1236 Z-0.2304
    N735 G01 X-0.8099 Y-1.1219 Z-0.2303
    N736 G01 X-1.1538 Y-1.061
    N737 G01 X-1.16 Y-1.0604 Z-0.2305
    N738 G01 X-1.1662 Y-1.0608 Z-0.2308
    N739 G01 X-1.1723 Y-1.0622 Z-0.2313
    N740 G01 X-1.1781 Y-1.0645 Z-0.2324
    N741 G01 X-1.1835 Y-1.0677 Z-0.2359
    N742 G01 X-1.1882 Y-1.0717 Z-0.2444
    N743 G01 X-1.1923 Y-1.0765 Z-0.2479
    N744 G01 X-1.1956 Y-1.0818 Z-0.249
    N745 G01 X-1.198 Y-1.0875 Z-0.2495
    N746 G01 X-1.1995 Y-1.0936 Z-0.2498
    N747 G01 X-1.2 Y-1.0998 Z-0.25
    N748 G01 Y-1.1508
    N749 G17 G03 X-1.1508 Y-1.2 I0.0493 J0.0001
    N750 G01 X-1.1311
    N751 G01 X0.7337
    N752 G01 X1.1077
    N753 G17 G03 X1.145 Y-1.1874 I-0.2244 J0.7243
    N754 G01 X1.1631 Y-1.1796
    N755 G01 X1.1802 Y-1.1699
    N756 G01 X1.192 Y-1.1542
    N757 G01 X1.1981 Y-1.1354
    N758 G01 X1.2 Y-1.1319
    N759 G01 Y-0.8366
    N760 G01 X1.1995 Y-0.8302 Z-0.2499
    N761 G01 X1.1979 Y-0.8238 Z-0.2498
    N762 G01 X1.1952 Y-0.8179 Z-0.2496
    N763 G01 X1.1917 Y-0.8124 Z-0.2493
    N764 G01 X1.1873 Y-0.8077 Z-0.249
    N765 G01 X1.1821 Y-0.8037 Z-0.2484
    N766 G01 X1.1764 Y-0.8006 Z-0.2474
    N767 G01 X1.1702 Y-0.7985 Z-0.2451
    N768 G01 X1.1638 Y-0.7974 Z-0.2402
    N769 G01 X1.1573 Z-0.2352
    N770 G01 X1.1509 Y-0.7985 Z-0.233
    N771 G01 X1.1447 Y-0.8006 Z-0.2319
    N772 G01 X1.139 Y-0.8037 Z-0.2313
    N773 G01 X1.1339 Y-0.8077 Z-0.231
    N774 G01 X1.1295 Y-0.8125 Z-0.2307
    N775 G01 X1.1259 Y-0.818 Z-0.2306
    N776 G01 X1.1234 Y-0.824 Z-0.2304
    N777 G01 X1.1218 Y-0.8303 Z-0.2303
    N778 G01 X1.0688 Y-1.1543
    N779 G01 X1.0683 Y-1.1611 Z-0.2305
    N780 G01 X1.069 Y-1.1679 Z-0.2309
    N781 G01 X1.0708 Y-1.1744 Z-0.2315
    N782 G01 X1.0737 Y-1.1806 Z-0.2333
    N783 G01 X1.0777 Y-1.1861 Z-0.2402
    N784 G01 X1.0825 Y-1.1909 Z-0.247
    N785 G01 X1.0881 Y-1.1948 Z-0.2488
    N786 G01 X1.0943 Y-1.1977 Z-0.2494
    N787 G01 X1.1009 Y-1.1994 Z-0.2498
    N788 G01 X1.1077 Y-1.2 Z-0.25
    N789 G01 X1.1508
    N790 G17 G03 X1.2 Y-1.1508 I-0.0001 J0.0493
    N791 G01 Y-1.1311
    N792 G17 G03 X1.1885 Y-1.1033 I-0.0397 J-0.0001
    N793 G00 Z0.1
    N794 G00 X-0.1183 Y0.0064
    N795 G00 Z-0.15
    N796 G01 Z-0.5 F44.6296 <<<<<<<<<<<<<<<<<<<<<<<<  Z Feed Move
    N797 G17 G03 X0.1132 Y0.0719 I0.125 J0. F89.2592
    N798 G17 G03 X0.0729 Y0.1226 I-0.2091 J-0.1248
    N799 G17 G03 X0.0463 Y0.1458 I-0.1884 J-0.1898
    N800 G17 G03 X0.0277 Y0.1589 I-0.1122 J-0.139
    N801 G17 G03 X-0.0161 Y0.1798 I-0.1261 J-0.2078
    N802 G17 G03 X-0.0409 Y0.1869 I-0.059 J-0.1599
    N803 G17 G03 X-0.0719 Y0.1915 I-0.0385 J-0.1511
    N804 G17 G03 X-0.1042 Y0.1916 I-0.0162 J-0.1609
    N805 G17 G03 X-0.1227 Y0.1891 I0.0156 J-0.1907
    N806 G17 G03 X-0.1886 Y0.1636 I0.0251 J-0.1625
    N807 G17 G03 X-0.2325 Y0.1267 I0.1375 J-0.2085
    N808 G01 X-0.2422 Y0.1158
    N809 G17 G03 X-0.2611 Y0.0876 I0.3169 J-0.2331
    N810 G17 G03 X-0.2757 Y0.0568 I0.4395 J-0.2281
    N811 G17 G03 X-0.2848 Y0.0288 I0.4884 J-0.1726
    N812 G17 G03 X-0.2898 Y0.0046 I6.551 J-1.3943
    N813 G01 X-0.2921 Y-0.0151
    N814 G01 X-0.2928 Y-0.0399
    N815 G01 X-0.2916 Y-0.0598
    N816 G17 G03 X-0.2869 Y-0.0893 I0.2682 J0.0279
    N817 G17 G03 X-0.2791 Y-0.1184 I0.1561 J0.0261
    N818 G17 G03 X-0.2705 Y-0.142 I0.2302 J0.0707
    N819 G17 G03 X-0.2596 Y-0.1648 I2.6951 J1.2685
    N820 G01 X-0.2522 Y-0.1781
    N821 G17 G03 X-0.2151 Y-0.2262 I0.241 J0.1477
    N822 G17 G03 X-0.1431 Y-0.2824 I0.2491 J0.2448
    N823 G17 G03 X-0.1253 Y-0.2925 I0.3567 J0.6078
    N824 G17 G03 X-0.0777 Y-0.3115 I0.2127 J0.463
    N825 G01 X-0.0528 Y-0.318
    N826 G17 G02 X-0.0428 Y-0.3202 I-0.0281 J-0.1555
    N827 G17 G03 X-0.0122 Y-0.3247 I0.5747 J3.8199
    N828 G01 X0.0136 Y-0.3261
    N829 G17 G03 X0.0394 Y-0.3253 I-0.0027 J0.5093
    N830 G01 X0.06 Y-0.3233
    N831 G01 X0.0855 Y-0.319
    N832 G17 G02 X0.1056 Y-0.3139 I0.2344 J-0.8799
    N833 G17 G03 X0.1349 Y-0.3037 I-0.0816 J0.2832
    N834 G17 G03 X0.154 Y-0.2956 I-0.0804 J0.2154
    N835 G17 G03 X0.1724 Y-0.286 I-0.121 J0.2553
    N836 G17 G03 X0.186 Y-0.2784 I-0.0605 J0.1241
    N837 G17 G03 X0.2034 Y-0.2672 I-0.1073 J0.1851
    N838 G17 G03 X0.2433 Y-0.2339 I-0.2093 J0.291
    N839 G17 G03 X0.2544 Y-0.223 I-0.0791 J0.0916
    N840 G17 G03 X0.2784 Y-0.1957 I-0.1714 J0.1754
    N841 G17 G03 X0.2936 Y-0.1745 I-0.1201 J0.1024
    N842 G17 G03 X0.3246 Y-0.1143 I-0.3699 J0.2281
    N843 G17 G03 X0.3374 Y-0.0746 I-0.5271 J0.1922
    N844 G17 G03 X0.3457 Y-0.0284 I-0.3439 J0.0858
    N845 G17 G03 X0.3478 Y-0.0024 I-0.3582 J0.0419
    N846 G17 G03 X0.3461 Y0.0446 I-0.3421 J0.0107
    N847 G17 G03 X0.3426 Y0.0705 I-0.194 J-0.013
    N848 G17 G03 X0.3397 Y0.0859 I-0.1352 J-0.0171
    N849 G17 G02 X0.3363 Y0.1013 I0.4939 J0.1185
    N850 G17 G03 X0.3254 Y0.1363 I-0.3981 J-0.1041
    N851 G17 G03 X0.3179 Y0.156 I-0.1971 J-0.0638
    N852 G17 G03 X0.3024 Y0.1895 I-0.2174 J-0.0806
    N853 G01 X0.295 Y0.2036
    N854 G17 G03 X0.275 Y0.235 I-0.6641 J-0.401
    N855 G17 G03 X0.2523 Y0.265 I-0.235 J-0.1545
    N856 G17 G03 X0.2312 Y0.2897 I-0.192 J-0.1423
    N857 G17 G03 X0.195 Y0.323 I-0.2555 J-0.2419
    N858 G17 G03 X0.1865 Y0.3302 I-0.0548 J-0.0555
    N859 G17 G03 X0.169 Y0.3438 I-0.1286 J-0.1479
    N860 G17 G03 X0.1553 Y0.3537 I-0.087 J-0.1058
    N861 G17 G03 X0.1364 Y0.3659 I-0.1274 J-0.1764
    N862 G17 G03 X0.1217 Y0.3745 I-0.0834 J-0.1247
    N863 G17 G03 X0.1067 Y0.3827 I-0.0719 J-0.1154
    N864 G17 G03 X0.0859 Y0.3924 I-0.0656 J-0.1128
    N865 G17 G03 X0.0424 Y0.408 I-0.2621 J-0.6642
    N866 G17 G02 X0.0199 Y0.4147 I0.1919 J0.6808
    N867 G17 G03 X-0.0205 Y0.4226 I-0.3014 J-1.4314
    N868 G17 G03 X-0.0619 Y0.4266 I-0.1514 J-1.3734
    N869 G17 G03 X-0.0919 Y0.4265 I-0.0145 J-0.5171
    N870 G17 G03 X-0.1161 Y0.4257 I-0.0065 J-0.1698
    N871 G17 G03 X-0.1402 Y0.4232 I0.0079 J-0.1918
    N872 G17 G03 X-0.1702 Y0.4178 I0.0345 J-0.2796
    N873 G17 G03 X-0.2235 Y0.4029 I0.0884 J-0.4178
    N874 G17 G03 X-0.2467 Y0.3943 I0.0949 J-0.2912
    N875 G17 G03 X-0.2807 Y0.3787 I0.0818 J-0.2234
    N876 G17 G03 X-0.308 Y0.3634 I0.1354 J-0.2747
    N877 G17 G03 X-0.3241 Y0.3535 I0.0848 J-0.1557
    N878 G17 G03 X-0.3446 Y0.3388 I0.1529 J-0.234
    N879 G17 G03 X-0.3549 Y0.3313 I0.0432 J-0.0703
    N880 G17 G03 X-0.3928 Y0.2975 I0.1827 J-0.2431
    N881 G17 G02 X-0.4063 Y0.2839 I-4.0757 J4.0233
    N882 G01 X-0.4192 Y0.2695
    N883 G17 G03 X-0.4847 Y0.1665 I0.3493 J-0.2944
    N884 G17 G03 X-0.5024 Y0.1245 I0.5336 J-0.2507
    N885 G17 G03 X-0.5068 Y0.1122 I0.1478 J-0.0592
    N886 G17 G03 X-0.513 Y0.0936 I0.1516 J-0.0608
    N887 G17 G03 X-0.5182 Y0.0746 I0.1267 J-0.0447
    N888 G17 G03 X-0.5251 Y0.0425 I1.2581 J-0.2883
    N889 G17 G02 X-0.5274 Y0.0295 I-0.1688 J0.0228
    N890 G17 G03 X-0.5311 Y-0.0098 I0.6106 J-0.0787
    N891 G17 G03 X-0.5321 Y-0.0296 I0.1555 J-0.0173
    N892 G17 G03 X-0.5322 Y-0.0494 I0.3056 J-0.0115
    N893 G17 G03 X-0.5315 Y-0.0759 I0.17 J-0.0091
    N894 G17 G03 X-0.5272 Y-0.1155 I0.3394 J0.0175
    N895 G17 G02 X-0.5253 Y-0.1287 I-0.2199 J-0.0374
    N896 G17 G02 X-0.5202 Y-0.1548 I-1.3025 J-0.2678
    N897 G17 G02 X-0.5136 Y-0.1806 I-3.1403 J-0.8169
    N898 G17 G03 X-0.5036 Y-0.2125 I1.0693 J0.3182
    N899 G01 X-0.4942 Y-0.2376
    N900 G17 G02 X-0.4861 Y-0.256 I-0.5356 J-0.245
    N901 G17 G03 X-0.4642 Y-0.2974 I0.7466 J0.368
    N902 G17 G02 X-0.4504 Y-0.3205 I-0.6891 J-0.4288
    N903 G17 G03 X-0.4311 Y-0.3479 I0.5469 J0.3637
    N904 G17 G03 X-0.4189 Y-0.364 I0.1625 J0.1104
    N905 G17 G02 X-0.3973 Y-0.3898 I-16.1 J-13.5114
    N906 G17 G03 X-0.3738 Y-0.414 I0.342 J0.3092
    N907 G17 G03 X-0.3643 Y-0.4235 I0.0695 J0.0597
    N908 G17 G03 X-0.3122 Y-0.4664 I0.2784 J0.2849
    N909 G17 G03 X-0.3013 Y-0.4745 I0.0614 J0.0711
    N910 G17 G03 X-0.2846 Y-0.4861 I0.1186 J0.1533
    N911 G17 G03 X-0.2617 Y-0.5006 I0.2095 J0.3071
    N912 G17 G03 X-0.2258 Y-0.5198 I0.274 J0.4693
    N913 G17 G03 X-0.1884 Y-0.536 I0.4011 J0.8721
    N914 G17 G02 X-0.1694 Y-0.5433 I-0.2739 J-0.7399
    N915 G17 G02 X-0.1501 Y-0.5501 I-0.1452 J-0.4455
    N916 G17 G02 X-0.1306 Y-0.5563 I-0.0856 J-0.303
    N917 G17 G03 X-0.0706 Y-0.5689 I0.2752 J1.1604
    N918 G17 G02 X-0.0504 Y-0.5722 I-0.0423 J-0.3185
    N919 G17 G03 X-0.0096 Y-0.5757 I0.2447 J2.6537
    N920 G17 G02 X0.004 Y-0.5764 I-0.0014 J-0.1586
    N921 G01 X0.0314 Y-0.5763
    N922 G17 G03 X0.0723 Y-0.5735 I-0.0736 J1.3605
    N923 G17 G03 X0.0926 Y-0.5711 I-0.014 J0.2102
    N924 G17 G03 X0.1129 Y-0.5679 I-0.106 J0.722
    N925 G17 G03 X0.1331 Y-0.5642 I-0.0185 J0.1597
    N926 G17 G03 X0.1664 Y-0.5565 I-0.0606 J0.337
    N927 G17 G03 X0.1926 Y-0.5487 I-0.0833 J0.3282
    N928 G17 G03 X0.2438 Y-0.5293 I-0.1558 J0.4882
    N929 G17 G03 X0.2687 Y-0.5179 I-0.1452 J0.3488
    N930 G17 G03 X0.2931 Y-0.5054 I-0.1716 J0.3674
    N931 G17 G03 X0.317 Y-0.492 I-0.1103 J0.223
    N932 G17 G03 X0.3345 Y-0.4812 I-0.0968 J0.1776
    N933 G17 G03 X0.3627 Y-0.4618 I-2.7896 J4.0805
    N934 G17 G03 X0.3949 Y-0.4361 I-1.0407 J1.3381
    N935 G17 G03 X0.4201 Y-0.4128 I-0.3849 J0.4413
    N936 G17 G03 X0.4348 Y-0.3983 I-0.1297 J0.1464
    N937 G17 G03 X0.4622 Y-0.3676 I-0.3182 J0.3105
    N938 G17 G03 X0.4753 Y-0.3517 I-0.1333 J0.1234
    N939 G17 G03 X0.5105 Y-0.3009 I-0.355 J0.2845
    N940 G01 X0.521 Y-0.2832
    N941 G17 G03 X0.528 Y-0.2713 I-0.0934 J0.0631
    N942 G17 G03 X0.538 Y-0.2533 I-0.1717 J0.1069
    N943 G17 G03 X0.5474 Y-0.2349 I-0.1578 J0.0922
    N944 G17 G03 X0.5561 Y-0.2161 I-0.1744 J0.0924
    N945 G17 G03 X0.5641 Y-0.1971 I-0.1796 J0.0871
    N946 G17 G03 X0.5733 Y-0.1711 I-0.2194 J0.0923
    N947 G17 G03 X0.5918 Y-0.0976 I-0.7397 J0.2254
    N948 G17 G03 X0.5944 Y-0.084 I-0.1947 J0.0433
    N949 G17 G03 X0.5983 Y-0.0567 I-0.2319 J0.0473
    N950 G01 X0.601 Y-0.0292
    N951 G17 G02 X0.6021 Y-0.0155 I0.334 J-0.0181
    N952 G17 G03 X0.6027 Y0.0329 I-2.9941 J0.0622
    N953 G17 G03 X0.6002 Y0.0673 I-0.6619 J-0.0302
    N954 G17 G03 X0.5973 Y0.0948 I-0.2746 J-0.0151
    N955 G17 G03 X0.5953 Y0.1085 I-0.3917 J-0.0508
    N956 G17 G03 X0.5918 Y0.1289 I-0.1674 J-0.018
    N957 G01 X0.5877 Y0.1493
    N958 G17 G03 X0.5728 Y0.2026 I-0.6104 J-0.1425
    N959 G17 G03 X0.5642 Y0.229 I-0.2246 J-0.058
    N960 G17 G03 X0.5545 Y0.255 I-0.2562 J-0.0816
    N961 G17 G03 X0.5436 Y0.2806 I-0.2933 J-0.1097
    N962 G17 G03 X0.5316 Y0.3057 I-0.2599 J-0.1089
    N963 G17 G03 X0.5185 Y0.3303 I-0.2406 J-0.1113
    N964 G17 G03 X0.5009 Y0.3605 I-0.2569 J-0.1302
    N965 G17 G03 X0.4898 Y0.3783 I-0.1777 J-0.0987
    N966 G17 G03 X0.4696 Y0.4069 I-8.5775 J-6.0245
    N967 G17 G02 X0.4569 Y0.4238 I0.2502 J0.2018
    N968 G17 G03 X0.4342 Y0.4507 I-0.5803 J-0.4653
    N969 G17 G03 X0.4201 Y0.4665 I-0.1615 J-0.13
    N970 G17 G03 X0.4052 Y0.4817 I-1.1281 J-1.0914
    N971 G17 G03 X0.3692 Y0.5158 I-0.2607 J-0.2393
    N972 G17 G03 X0.3585 Y0.5253 I-0.0806 J-0.0799
    N973 G17 G03 X0.3248 Y0.5517 I-0.2322 J-0.261
    N974 G17 G02 X0.3014 Y0.5683 I0.4797 J0.7044
    N975 G01 X0.2834 Y0.5801
    N976 G17 G03 X0.2202 Y0.6146 I-0.3235 J-0.5185
    N977 G17 G03 X0.2072 Y0.6211 I-0.0507 J-0.0844
    N978 G01 X0.1941 Y0.6277
    N979 G17 G02 X0.1741 Y0.6366 I0.1482 J0.3558
    N980 G17 G02 X0.1606 Y0.6421 I0.0781 J0.2123
    N981 G17 G02 X0.14 Y0.6497 I0.1191 J0.3559
    N982 G17 G02 X0.1192 Y0.657 I0.097 J0.3102
    N983 G17 G02 X0.1052 Y0.6614 I0.0403 J0.1544
    N984 G17 G03 X0.0405 Y0.6755 I-0.2798 J-1.1208
    N985 G17 G02 X0.0186 Y0.6794 I0.1793 J1.0844
    N986 G17 G02 X0.0039 Y0.6816 I0.0297 J0.249
    N987 G17 G03 X-0.0405 Y0.6852 I-0.2664 J-2.9859
    N988 G17 G02 X-0.0629 Y0.6865 I0.0349 J0.8298
    N989 G17 G03 X-0.1151 Y0.6854 I-0.011 J-0.7208
    N990 G17 G03 X-0.1302 Y0.6847 I-0.0028 J-0.107
    N991 G17 G03 X-0.1526 Y0.6826 I0.032 J-0.4672
    N992 G01 X-0.1677 Y0.6816
    N993 G17 G03 X-0.1975 Y0.6769 I0.095 J-0.7029
    N994 G17 G03 X-0.2198 Y0.6727 I0.0208 J-0.174
    N995 G17 G03 X-0.2568 Y0.6641 I0.0709 J-0.3886
    N996 G01 X-0.2714 Y0.66
    N997 G17 G03 X-0.2933 Y0.6536 I0.0347 J-0.1593
    N998 G17 G03 X-0.3223 Y0.6439 I0.094 J-0.3287
    N999 G17 G03 X-0.3508 Y0.6328 I0.1404 J-0.4015
    N1000 G17 G03 X-0.3718 Y0.6234 I0.1153 J-0.2875
    N1001 G17 G03 X-0.4198 Y0.5992 I0.2676 J-0.5892
    N1002 G17 G03 X-0.4465 Y0.5836 I0.1468 J-0.2833
    N1003 G17 G03 X-0.4661 Y0.5712 I0.1201 J-0.2114
    N1004 G17 G02 X-0.4791 Y0.5629 I-0.0804 J0.1106
    N1005 G17 G03 X-0.5042 Y0.5446 I0.3433 J-0.4957
    N1006 G17 G03 X-0.5345 Y0.5203 I0.1932 J-0.2729
    N1007 G01 X-0.5522 Y0.505
    N1008 G17 G03 X-0.5802 Y0.478 I5.9927 J-6.23
    N1009 G17 G03 X-0.6067 Y0.4493 I1.0147 J-0.9628
    N1010 G17 G03 X-0.632 Y0.4193 I0.2831 J-0.2646
    N1011 G01 X-0.6511 Y0.3944
    N1012 G17 G03 X-0.6775 Y0.3553 I0.5063 J-0.3695
    N1013 G01 X-0.6863 Y0.3421
    N1014 G17 G02 X-0.6945 Y0.3286 I-0.4584 J0.2688
    N1015 G17 G03 X-0.7203 Y0.2796 I0.7248 J-0.4133
    N1016 G17 G03 X-0.766 Y0.153 I0.6755 J-0.3156
    N1017 G17 G03 X-0.7821 Y0.083 I0.9882 J-0.2628
    N1018 G17 G02 X-0.7863 Y0.0593 I-0.5844 J0.0936
    N1019 G17 G02 X-0.7888 Y0.0435 I-0.2055 J0.0232
    N1020 G17 G03 X-0.7926 Y-0.0044 I0.8035 J-0.0883
    N1021 G17 G03 X-0.794 Y-0.0285 I0.2479 J-0.0264
    N1022 G17 G03 X-0.7946 Y-0.0446 I0.1163 J-0.0123
    N1023 G17 G03 X-0.7941 Y-0.0687 I0.6285 J0.0004
    N1024 G17 G03 X-0.7928 Y-0.1009 I0.2518 J-0.0064
    N1025 G01 X-0.7908 Y-0.125
    N1026 G17 G02 X-0.7893 Y-0.141 I-0.1636 J-0.0241
    N1027 G17 G02 X-0.7846 Y-0.173 I-3.9309 J-0.5874
    N1028 G17 G02 X-0.7767 Y-0.2126 I-4.2414 J-0.8708
    N1029 G17 G03 X-0.7594 Y-0.2749 I0.6723 J0.1529
    N1030 G17 G03 X-0.7519 Y-0.298 I0.2534 J0.069
    N1031 G17 G03 X-0.7174 Y-0.3801 I0.6339 J0.2183
    N1032 G01 X-0.7102 Y-0.3946
    N1033 G17 G03 X-0.699 Y-0.4163 I0.1661 J0.0715
    N1034 G17 G03 X-0.6914 Y-0.4307 I0.1264 J0.0583
    N1035 G17 G03 X-0.6611 Y-0.4788 I0.6892 J0.3998
    N1036 G17 G03 X-0.6472 Y-0.4989 I0.273 J0.1733
    N1037 G17 G03 X-0.628 Y-0.5252 I0.2639 J0.1738
    N1038 G17 G03 X-0.6181 Y-0.5382 I0.1072 J0.0708
    N1039 G17 G03 X-0.6024 Y-0.5569 I0.4234 J0.3411
    N1040 G17 G03 X-0.575 Y-0.5871 I0.2744 J0.22
    N1041 G17 G03 X-0.5401 Y-0.6214 I0.3926 J0.3651
    N1042 G17 G03 X-0.5095 Y-0.6486 I0.2685 J0.2717
    N1043 G17 G03 X-0.4711 Y-0.679 I0.3004 J0.3395
    N1044 G17 G02 X-0.4446 Y-0.6983 I-1.2124 J-1.6987
    N1045 G17 G03 X-0.403 Y-0.7244 I0.3813 J0.5594
    N1046 G17 G03 X-0.389 Y-0.733 I0.076 J0.1092
    N1047 G17 G03 X-0.3457 Y-0.7563 I0.2685 J0.4451
    N1048 G17 G03 X-0.3084 Y-0.7732 I0.311 J0.6382
    N1049 G17 G03 X-0.2934 Y-0.78 I0.0585 J0.1094
    N1050 G17 G03 X-0.2782 Y-0.7864 I0.0566 J0.1133
    N1051 G17 G03 X-0.2553 Y-0.7955 I0.0911 J0.1942
    N1052 G17 G03 X-0.2398 Y-0.8011 I0.0573 J0.1364
    N1053 G17 G03 X-0.2242 Y-0.8062 I0.0518 J0.131
    N1054 G01 X-0.2086 Y-0.8113
    N1055 G17 G02 X-0.1927 Y-0.8159 I-0.0549 J-0.219
    N1056 G17 G02 X-0.1689 Y-0.8224 I-0.0832 J-0.3501
    N1057 G17 G02 X-0.1529 Y-0.8262 I-0.0322 J-0.1708
    N1058 G17 G03 X-0.0878 Y-0.8366 I0.2605 J1.4224
    N1059 G17 G03 X-0.0468 Y-0.8411 I0.215 J1.7627
    N1060 G17 G03 X0.0108 Y-0.8434 I0.1074 J2.0432
    N1061 G17 G02 X0.0273 Y-0.8436 I0.0048 J-0.2593
    N1062 G17 G03 X0.0603 Y-0.8424 I-0.002 J0.5135
    N1063 G17 G03 X0.085 Y-0.841 I-0.0072 J0.3557
    N1064 G17 G03 X0.1097 Y-0.8389 I-0.0051 J0.2039
    N1065 G17 G03 X0.1425 Y-0.835 I-0.7833 J6.7314
    N1066 G17 G03 X0.175 Y-0.8292 I-0.1712 J1.0458
    N1067 G17 G03 X0.1993 Y-0.8244 I-0.0329 J0.2312
    N1068 G17 G03 X0.2154 Y-0.8206 I-0.2115 J0.9484
    N1069 G17 G03 X0.2395 Y-0.8147 I-0.0421 J0.221
    N1070 G17 G03 X0.2869 Y-0.8001 I-0.1615 J0.6106
    N1071 G17 G03 X0.3103 Y-0.7921 I-0.0578 J0.2076
    N1072 G17 G03 X0.3564 Y-0.7737 I-0.1958 J0.5555
    N1073 G17 G03 X0.4657 Y-0.7152 I-0.3367 J0.7604
    N1074 G17 G03 X0.5138 Y-0.683 I-0.537 J0.8548
    N1075 G17 G03 X0.5337 Y-0.6682 I-0.1838 J0.2692
    N1076 G17 G03 X0.547 Y-0.6583 I-0.0761 J0.1157
    N1077 G17 G03 X0.5788 Y-0.6318 I-1.184 J1.4536
    N1078 G17 G03 X0.6207 Y-0.5918 I-0.6126 J0.6836
    N1079 G17 G03 X0.6325 Y-0.5801 I-0.102 J0.1149
    N1080 G17 G03 X0.6813 Y-0.5238 I-0.5689 J0.5424
    N1081 G17 G03 X0.6919 Y-0.511 I-0.0995 J0.0925
    N1082 G17 G03 X0.721 Y-0.4707 I-0.3984 J0.3186
    N1083 G17 G03 X0.7436 Y-0.4359 I-0.8392 J0.5697
    N1084 G17 G03 X0.7601 Y-0.4072 I-1.2202 J0.7199
    N1085 G17 G03 X0.7722 Y-0.3854 I-0.2088 J0.1306
    N1086 G17 G03 X0.7908 Y-0.3483 I-0.4731 J0.2607
    N1087 G17 G03 X0.8187 Y-0.2791 I-0.7359 J0.3368
    N1088 G17 G03 X0.8276 Y-0.2558 I-0.1825 J0.0834
    N1089 G17 G03 X0.833 Y-0.2401 I-0.1355 J0.0551
    N1090 G17 G03 X0.8381 Y-0.2243 I-0.1416 J0.0539
    N1091 G01 X0.8431 Y-0.2084
    N1092 G17 G02 X0.8476 Y-0.1924 I0.2319 J-0.0557
    N1093 G17 G03 X0.8662 Y-0.086 I-0.945 J0.2198
    N1094 G17 G03 X0.8691 Y-0.0612 I-0.3137 J0.0497
    N1095 G17 G03 X0.8711 Y-0.0363 I-0.2323 J0.0315
    N1096 G17 G03 X0.8728 Y0.0136 I-8.3889 J0.3131
    N1097 G17 G02 X0.873 Y0.0303 I0.2414 J0.0057
    N1098 G17 G03 X0.8705 Y0.0802 I-1.0732 J-0.0286
    N1099 G17 G03 X0.865 Y0.1299 I-1.0809 J-0.0944
    N1100 G17 G03 X0.8615 Y0.1546 I-0.2334 J-0.0202
    N1101 G17 G02 X0.8574 Y0.1793 I1.4974 J0.2644
    N1102 G17 G03 X0.8503 Y0.2118 I-0.9978 J-0.2003
    N1103 G17 G03 X0.8426 Y0.2443 I-0.3308 J-0.0612
    N1104 G17 G03 X0.8382 Y0.2604 I-0.6203 J-0.1615
    N1105 G17 G03 X0.8312 Y0.2844 I-0.2102 J-0.0478
    N1106 G17 G03 X0.8148 Y0.3317 I-0.5842 J-0.1765
    N1107 G17 G03 X0.8059 Y0.3552 I-0.2635 J-0.0871
    N1108 G17 G03 X0.7963 Y0.3783 I-0.2656 J-0.0962
    N1109 G17 G03 X0.7634 Y0.446 I-0.7591 J-0.3275
    N1110 G17 G03 X0.7515 Y0.4682 I-0.1738 J-0.0784
    N1111 G17 G03 X0.7391 Y0.4901 I-0.2192 J-0.1107
    N1112 G17 G02 X0.7305 Y0.5046 I0.2659 J0.1663
    N1113 G01 X0.7214 Y0.5186
    N1114 G17 G03 X0.7124 Y0.5329 I-0.1127 J-0.0609
    N1115 G17 G03 X0.6779 Y0.5806 I-0.9501 J-0.6512
    N1116 G17 G03 X0.6622 Y0.6004 I-0.4089 J-0.308
    N1117 G17 G03 X0.6461 Y0.6199 I-0.206 J-0.1532
    N1118 G17 G03 X0.6179 Y0.6513 I-0.7859 J-0.6767
    N1119 G17 G03 X0.5886 Y0.6818 I-0.289 J-0.2497
    N1120 G17 G03 X0.5512 Y0.7163 I-0.4106 J-0.4066
    N1121 G17 G03 X0.5253 Y0.7382 I-0.2833 J-0.3079
    N1122 G17 G02 X0.5056 Y0.7545 I1.0945 J1.3493
    N1123 G17 G02 X0.4716 Y0.7802 I1.3007 J1.756
    N1124 G17 G03 X0.429 Y0.8085 I-0.4658 J-0.6559
    N1125 G17 G03 X0.4145 Y0.8177 I-0.1059 J-0.1491
    N1126 G17 G03 X0.3775 Y0.8392 I-0.2794 J-0.4402
    N1127 G17 G03 X0.3625 Y0.8476 I-0.0716 J-0.1101
    N1128 G17 G03 X0.3006 Y0.8775 I-0.3019 J-0.5458
    N1129 G17 G03 X0.2686 Y0.8904 I-0.4778 J-1.1409
    N1130 G17 G03 X0.2446 Y0.9002 I-0.1014 J-0.2121
    N1131 G17 G03 X0.2283 Y0.9062 I-0.061 J-0.14
    N1132 G17 G03 X0.212 Y0.9119 I-0.0597 J-0.147
    N1133 G17 G03 X0.1872 Y0.92 I-0.0964 J-0.2533
    N1134 G17 G03 X0.1705 Y0.9248 I-0.0605 J-0.1773
    N1135 G17 G03 X0.1538 Y0.9293 I-0.0564 J-0.177
    N1136 G17 G03 X0.1284 Y0.9357 I-0.0795 J-0.2594
    N1137 G17 G03 X0.1114 Y0.9395 I-0.0472 J-0.1725
    N1138 G17 G03 X0.0943 Y0.943 I-0.0394 J-0.1505
    N1139 G17 G03 X0.0772 Y0.9462 I-0.0344 J-0.1367
    N1140 G17 G02 X0.06 Y0.9492 I0.0235 J0.1838
    N1141 G17 G03 X-0.0183 Y0.957 I-0.238 J-1.9936
    N1142 G17 G02 X-0.0358 Y0.9581 I0.0079 J0.257
    N1143 G17 G03 X-0.0885 Y0.9584 I-0.0332 J-1.1819
    N1144 G17 G03 X-0.1149 Y0.9579 I-0.0048 J-0.4187
    N1145 G17 G03 X-0.1325 Y0.9574 I-0.005 J-0.1385
    N1146 G01 X-0.1677 Y0.9549
    N1147 G17 G02 X-0.1853 Y0.9535 I-0.0258 J0.2102
    N1148 G17 G03 X-0.2203 Y0.9487 I0.209 J-1.6591
    N1149 G17 G03 X-0.2466 Y0.9445 I0.027 J-0.2547
    N1150 G17 G02 X-0.2727 Y0.9397 I-0.3255 J1.6977
    N1151 G17 G02 X-0.316 Y0.9297 I-0.766 J3.22
    N1152 G17 G03 X-0.3502 Y0.9201 I0.6385 J-2.3341
    N1153 G17 G03 X-0.3758 Y0.9125 I0.0628 J-0.2585
    N1154 G17 G03 X-0.3927 Y0.9069 I0.1033 J-0.3402
    N1155 G17 G03 X-0.4098 Y0.9014 I0.0323 J-0.1295
    N1156 G17 G02 X-0.4266 Y0.8954 I-0.1307 J0.3373
    N1157 G17 G03 X-0.4842 Y0.8708 I0.2949 J-0.7707
    N1158 G17 G03 X-0.5085 Y0.8595 I0.076 J-0.1953
    N1159 G17 G03 X-0.5326 Y0.8473 I0.0991 J-0.2258
    N1160 G17 G03 X-0.5642 Y0.8302 I0.1558 J-0.3247
    N1161 G17 G03 X-0.5874 Y0.8164 I0.1548 J-0.2884
    N1162 G17 G03 X-0.6103 Y0.802 I0.1394 J-0.2469
    N1163 G17 G03 X-0.6328 Y0.787 I0.1222 J-0.2082
    N1164 G17 G03 X-0.6478 Y0.7769 I0.0728 J-0.1238
    N1165 G17 G03 X-0.6906 Y0.7437 I0.5697 J-0.7789
    N1166 G17 G03 X-0.7115 Y0.7264 I0.1881 J-0.2481
    N1167 G17 G03 X-0.7254 Y0.7148 I0.0926 J-0.1248
    N1168 G17 G03 X-0.7453 Y0.6963 I0.8718 J-0.9628
    N1169 G17 G03 X-0.765 Y0.6775 I0.231 J-0.2598
    N1170 G17 G03 X-0.7781 Y0.6648 I0.0996 J-0.1163
    N1171 G17 G03 X-0.7967 Y0.645 I0.4501 J-0.4424
    N1172 G17 G03 X-0.8152 Y0.6249 I0.2285 J-0.2283
    N1173 G17 G02 X-0.833 Y0.6042 I-0.4849 J0.4
    N1174 G17 G03 X-0.8556 Y0.5755 I0.7338 J-0.5998
    N1175 G17 G03 X-0.8668 Y0.5611 I0.134 J-0.1162
    N1176 G17 G03 X-0.8877 Y0.5312 I0.4063 J-0.3068
    N1177 G17 G02 X-0.8981 Y0.5162 I-0.8795 J0.5968
    N1178 G17 G03 X-0.9267 Y0.4693 I0.8356 J-0.5407
    N1179 G17 G03 X-0.9359 Y0.4535 I0.172 J-0.1116
    N1180 G17 G03 X-0.9611 Y0.4046 I0.5423 J-0.3095
    N1181 G17 G02 X-0.9693 Y0.3882 I-0.4317 J0.2068
    N1182 G17 G02 X-0.9771 Y0.3715 I-0.9614 J0.4386
    N1183 G17 G03 X-1.0042 Y0.3032 I0.8464 J-0.3758
    N1184 G17 G03 X-1.0108 Y0.286 I0.1227 J-0.057
    N1185 G17 G03 X-1.017 Y0.2686 I0.1335 J-0.0573
    N1186 G17 G03 X-1.0228 Y0.2511 I0.1456 J-0.0578
    N1187 G17 G03 X-1.0282 Y0.2334 I0.155 J-0.0573
    N1188 G17 G03 X-1.036 Y0.2068 I0.27 J-0.0935
    N1189 G17 G03 X-1.0406 Y0.1889 I0.1885 J-0.058
    N1190 G17 G03 X-1.0449 Y0.1709 I0.18 J-0.0521
    N1191 G17 G03 X-1.0489 Y0.1528 I0.1755 J-0.0478
    N1192 G17 G03 X-1.0525 Y0.1347 I0.159 J-0.0412
    N1193 G17 G03 X-1.0558 Y0.1164 I0.144 J-0.0356
    N1194 G01 X-1.0595 Y0.0982
    N1195 G17 G03 X-1.0666 Y0.0244 I1.9968 J-0.2276
    N1196 G17 G02 X-1.0684 Y-0.0035 I-0.8532 J0.0418
    N1197 G17 G02 X-1.0693 Y-0.022 I-0.2034 J0.0011
    N1198 G17 G03 X-1.0688 Y-0.0685 I1.2 J-0.0093
    N1199 G17 G03 X-1.0672 Y-0.1057 I0.392 J-0.0019
    N1200 G17 G02 X-1.0643 Y-0.1428 I-4.2268 J-0.3439
    N1201 G17 G02 X-1.0627 Y-0.1614 I-0.181 J-0.025
    N1202 G17 G03 X-1.0575 Y-0.1983 I1.3074 J0.1648
    N1203 G17 G03 X-1.0548 Y-0.2167 I0.1662 J0.0153
    N1204 G17 G03 X-1.0495 Y-0.2442 I2.1424 J0.3962
    N1205 G17 G03 X-1.0438 Y-0.2716 I0.2852 J0.0456
    N1206 G17 G02 X-1.0373 Y-0.2988 I-4.3123 J-1.0415
    N1207 G17 G02 X-1.0249 Y-0.3439 I-5.9004 J-1.6497
    N1208 G17 G03 X-1.0162 Y-0.3705 I1.2896 J0.405
    N1209 G17 G03 X-1.0105 Y-0.3883 I0.1589 J0.0415
    N1210 G17 G02 X-1.0042 Y-0.406 I-1.1488 J-0.4166
    N1211 G17 G03 X-0.9904 Y-0.4407 I1.318 J0.5054
    N1212 G17 G03 X-0.9835 Y-0.4581 I0.1421 J0.046
    N1213 G17 G02 X-0.9762 Y-0.4754 I-0.3382 J-0.154
    N1214 G17 G02 X-0.9643 Y-0.5008 I-1.5413 J-0.7347
    N1215 G17 G03 X-0.8506 Y-0.6837 I0.9749 J0.479
    N1216 G17 G03 X-0.8334 Y-0.706 I0.5301 J0.3923
    N1217 G17 G03 X-0.8157 Y-0.728 I0.3013 J0.2247
    N1218 G17 G03 X-0.8037 Y-0.7424 I0.1525 J0.1147
    N1219 G17 G03 X-0.7848 Y-0.7633 I0.7543 J0.6635
    N1220 G17 G03 X-0.7654 Y-0.7839 I0.2965 J0.2602
    N1221 G17 G03 X-0.7524 Y-0.7975 I0.1345 J0.1152
    N1222 G01 X-0.7253 Y-0.8236
    N1223 G17 G03 X-0.6828 Y-0.8609 I1.0359 J1.1395
    N1224 G01 X-0.6536 Y-0.8846
    N1225 G17 G03 X-0.6309 Y-0.9015 I11.945 J15.9775
    N1226 G17 G03 X-0.6081 Y-0.9183 I0.2313 J0.292
    N1227 G17 G02 X-0.5849 Y-0.9344 I-0.3085 J-0.4689
    N1228 G17 G03 X-0.5449 Y-0.9595 I0.4576 J0.6844
    N1229 G17 G03 X-0.4875 Y-0.9922 I0.3459 J0.5405
    N1230 G17 G03 X-0.4709 Y-1.0012 I0.0851 J0.1372
    N1231 G17 G03 X-0.4455 Y-1.0139 I0.2137 J0.3966
    N1232 G17 G03 X-0.3935 Y-1.0364 I0.3748 J0.7926
    N1233 G17 G03 X-0.376 Y-1.0438 I0.0718 J0.1463
    N1234 G17 G03 X-0.3584 Y-1.0507 I0.0794 J0.1767
    N1235 G17 G03 X-0.3406 Y-1.0572 I0.0862 J0.2077
    N1236 G17 G03 X-0.2592 Y-1.0822 I0.2752 J0.7519
    N1237 G17 G03 X-0.1385 Y-1.1065 I0.3012 J1.1831
    N1238 G17 G03 X-0.1104 Y-1.1106 I0.2787 J1.8172
    N1239 G17 G02 X-0.0916 Y-1.1129 I-0.0378 J-0.3826
    N1240 G17 G02 X-0.0727 Y-1.115 I-0.0198 J-0.2665
    N1241 G17 G02 X-0.0538 Y-1.1168 I-0.0095 J-0.1973
    N1242 G17 G03 X0.0126 Y-1.1191 I0.1558 J3.5551
    N1243 G17 G02 X0.0316 Y-1.1194 I0.0057 J-0.2918
    N1244 G17 G02 X0.0506 Y-1.1194 I0.0087 J-0.1884
    N1245 G17 G03 X0.098 Y-1.1171 I-0.4767 J10.067
    N1246 G17 G02 X0.1169 Y-1.1158 I0.0369 J-0.407
    N1247 G17 G03 X0.1641 Y-1.1105 I-0.1446 J1.4846
    N1248 G17 G03 X0.1924 Y-1.1067 I-0.022 J0.2736
    N1249 G17 G02 X0.2205 Y-1.1022 I0.2453 J-1.4328
    N1250 G17 G03 X0.2855 Y-1.0879 I-0.2302 J1.202
    N1251 G17 G03 X0.3405 Y-1.0727 I-0.2207 J0.9049
    N1252 G17 G03 X0.3677 Y-1.0642 I-0.0934 J0.3502
    N1253 G01 X0.3857 Y-1.0581
    N1254 G17 G03 X0.4127 Y-1.0487 I-0.077 J0.263
    N1255 G17 G03 X0.4741 Y-1.0232 I-0.2853 J0.7742
    N1256 G17 G03 X0.5425 Y-0.9899 I-0.3269 J0.7588
    N1257 G17 G03 X0.5595 Y-0.9813 I-0.0608 J0.1409
    N1258 G17 G02 X0.5763 Y-0.9723 I0.1334 J-0.2292
    N1259 G17 G02 X0.6011 Y-0.958 I0.3184 J-0.5231
    N1260 G17 G02 X0.6254 Y-0.9431 I0.3769 J-0.5877
    N1261 G17 G02 X0.6494 Y-0.9275 I0.3905 J-0.5763
    N1262 G17 G02 X0.673 Y-0.9114 I0.3681 J-0.5134
    N1263 G17 G03 X0.7478 Y-0.8525 I-0.8515 J1.1586
    N1264 G17 G03 X0.7972 Y-0.8076 I-0.6261 J0.7379
    N1265 G17 G03 X0.8176 Y-0.7877 I-0.3258 J0.3534
    N1266 G17 G03 X0.8377 Y-0.7673 I-0.2072 J0.2247
    N1267 G17 G03 X0.8634 Y-0.7392 I-0.8722 J0.8257
    N1268 G17 G03 X0.9059 Y-0.6877 I-0.8002 J0.7033
    N1269 G17 G03 X0.9289 Y-0.6574 I-0.3947 J0.3232
    N1270 G17 G02 X0.9402 Y-0.642 I0.5891 J-0.4213
    N1271 G17 G03 X0.9819 Y-0.5781 I-1.1109 J0.7705
    N1272 G17 G02 X0.9968 Y-0.5536 I0.456 J-0.2598
    N1273 G17 G03 X1.024 Y-0.5033 I-0.8232 J0.4779
    N1274 G17 G03 X1.0329 Y-0.4864 I-0.1424 J0.086
    N1275 G17 G03 X1.0414 Y-0.4693 I-0.2157 J0.1175
    N1276 G17 G03 X1.0712 Y-0.399 I-0.7781 J0.3717
    N1277 G17 G02 X1.0784 Y-0.3813 I2.9211 J-1.176
    N1278 G17 G02 X1.0851 Y-0.3634 I0.9389 J-0.339
    N1279 G17 G03 X1.1293 Y-0.1974 I-1.01 J0.3578
    N1280 G17 G03 X1.141 Y-0.1219 I-1.1694 J0.2202
    N1281 G17 G03 X1.1433 Y-0.1029 I-0.3497 J0.0517
    N1282 G17 G03 X1.1453 Y-0.0839 I-0.2521 J0.0368
    N1283 G17 G03 X1.1471 Y-0.0649 I-0.204 J0.0291
    N1284 G17 G03 X1.1492 Y-0.0362 I-0.2598 J0.033
    N1285 G17 G03 X1.1503 Y0.0211 I-1.3434 J0.0541
    N1286 G17 G03 X1.1503 Y0.0403 I-0.2298 J0.0097
    N1287 G17 G03 X1.1501 Y0.0594 I-0.1647 J0.0083
    N1288 G17 G03 X1.1471 Y0.1072 I-1.5393 J-0.0734
    N1289 G17 G03 X1.1447 Y0.1358 I-0.3061 J-0.0117
    N1290 G17 G03 X1.1412 Y0.1643 I-1.5065 J-0.1664
    N1291 G17 G03 X1.1374 Y0.1928 I-0.3142 J-0.0282
    N1292 G17 G02 X1.1327 Y0.2211 I2.1437 J0.368
    N1293 G17 G02 X1.1296 Y0.24 I0.2033 J0.0434
    N1294 G17 G03 X1.1194 Y0.2868 I-17.8364 J-3.8449
    N1295 G17 G03 X1.1122 Y0.3146 I-2.5696 J-0.6558
    N1296 G17 G03 X1.1047 Y0.3424 I-0.295 J-0.0645
    N1297 G17 G03 X1.0991 Y0.3608 I-0.6587 J-0.1897
    N1298 G17 G03 X1.0936 Y0.3791 I-0.1566 J-0.0367
    N1299 G17 G03 X1.0776 Y0.4243 I-0.8013 J-0.2594
    N1300 G17 G03 X1.0601 Y0.469 I-0.6206 J-0.2164
    N1301 G17 G03 X1.053 Y0.4868 I-0.1518 J-0.0504
    N1302 G17 G02 X1.0454 Y0.5045 I0.3786 J0.1729
    N1303 G17 G02 X1.0332 Y0.5306 I5.4576 J2.5639
    N1304 G17 G03 X1.002 Y0.5902 I-1.1545 J-0.5679
    N1305 G17 G03 X0.9927 Y0.607 I-0.295 J-0.1521
    N1306 G17 G03 X0.9633 Y0.6567 I-0.7799 J-0.4283
    N1307 G17 G03 X0.9314 Y0.7048 I-0.8662 J-0.5388
    N1308 G17 G03 X0.9146 Y0.7284 I-0.4229 J-0.2835
    N1309 G17 G03 X0.8973 Y0.7516 I-0.3356 J-0.2313
    N1310 G17 G03 X0.8794 Y0.7744 I-0.2425 J-0.1723
    N1311 G17 G03 X0.8674 Y0.7895 I-0.1358 J-0.0953
    N1312 G17 G03 X0.8225 Y0.8402 I-2.0206 J-1.7474
    N1313 G17 G03 X0.7817 Y0.8814 I-0.9536 J-0.9039
    N1314 G17 G03 X0.7607 Y0.9015 I-0.2812 J-0.2722
    N1315 G17 G03 X0.7467 Y0.9149 I-0.1353 J-0.1276
    N1316 G17 G02 X0.7177 Y0.9408 I13.9122 J15.6367
    N1317 G17 G03 X0.6951 Y0.9591 I-12.6165 J-15.4903
    N1318 G17 G03 X0.6723 Y0.9774 I-0.2397 J-0.2759
    N1319 G17 G02 X0.6491 Y0.9951 I0.6453 J0.8707
    N1320 G17 G02 X0.6174 Y1.0177 I1.1446 J1.6385
    N1321 G17 G03 X0.5848 Y1.0391 I-0.7651 J-1.1265
    N1322 G17 G03 X0.5685 Y1.0499 I-0.0982 J-0.1304
    N1323 G17 G03 X0.535 Y1.07 I-0.2973 J-0.4584
    N1324 G17 G03 X0.5181 Y1.0798 I-0.1365 J-0.2161
    N1325 G17 G03 X0.4749 Y1.1028 I-0.3383 J-0.5823
    N1326 G17 G03 X0.4573 Y1.1113 I-0.052 J-0.0854
    N1327 G17 G03 X0.4606 Y1.1099 I-0.4506 J-1.1049
    N1328 G01 X0.4483 Y1.1253
    N1329 G01 X0.4447 Y1.1446
    N1330 G01 X0.4429 Y1.1642
    N1331 G01 X0.4327 Y1.181
    N1332 G01 X0.4167 Y1.1926
    N1333 G01 X0.3979 Y1.1983
    N1334 G01 X0.3948 Y1.2
    N1335 G01 X-0.747
    N1336 G17 G03 X-0.8022 Y1.1791 I0.2837 J-0.8307
    N1337 G01 X-0.8376 Y1.1619
    N1338 G17 G03 X-0.8891 Y1.1329 I0.3099 J-0.6104
    N1339 G17 G03 X-0.9544 Y1.0891 I0.7897 J-1.2484
    N1340 G17 G03 X-0.9857 Y1.0652 I0.4448 J-0.6141
    N1341 G17 G03 X-1.0737 Y0.9864 I0.8716 J-1.0613
    N1342 G01 X-1.1013 Y0.9583
    N1343 G01 X-1.1147 Y0.9439
    N1344 G01 X-1.1534 Y0.8993
    N1345 G01 X-1.1659 Y0.8841
    N1346 G01 X-1.1898 Y0.8528
    N1347 G01 X-1.1972 Y0.8346
    N1348 G01 X-1.2 Y0.8293
    N1349 G01 Y-0.7258
    N1350 G01 X-1.1868 Y-0.7629
    N1351 G17 G03 X-1.1547 Y-0.8347 I0.6131 J0.2305
    N1352 G01 X-1.1359 Y-0.8693
    N1353 G17 G03 X-1.1156 Y-0.903 I0.6587 J0.3755
    N1354 G17 G03 X-1.0707 Y-0.9677 I1.236 J0.809
    N1355 G17 G03 X-1.0203 Y-1.0281 I0.6211 J0.4673
    N1356 G01 X-1.0076 Y-1.0432
    N1357 G01 X-0.9804 Y-1.0717
    N1358 G01 X-0.9664 Y-1.0855
    N1359 G01 X-0.9231 Y-1.1256
    N1360 G01 X-0.9082 Y-1.1386
    N1361 G17 G03 X-0.8465 Y-1.1874 I0.947 J1.1337
    N1362 G17 G02 X-0.8214 Y-1.2 I-0.1923 J-0.4131
    N1363 G01 X0.7337
    N1364 G17 G03 X0.8074 Y-1.1725 I-0.1919 J0.6262
    N1365 G01 X0.8431 Y-1.1559
    N1366 G17 G03 X0.895 Y-1.1277 I-0.3004 J0.6151
    N1367 G01 X0.9283 Y-1.1068
    N1368 G17 G03 X0.9923 Y-1.0609 I-0.6152 J0.9261
    N1369 G01 X1.0076 Y-1.0485
    N1370 G01 X1.0522 Y-1.0098
    N1371 G01 X1.0666 Y-0.9964
    N1372 G17 G03 X1.1482 Y-0.911 I-0.9514 J0.9904
    N1373 G01 X1.1609 Y-0.896
    N1374 G01 X1.1853 Y-0.8651
    N1375 G01 X1.2 Y-0.8386
    N1376 G01 Y0.7559
    N1377 G01 X1.1868 Y0.7929
    N1378 G01 X1.1796 Y0.8113
    N1379 G01 X1.163 Y0.847
    N1380 G17 G03 X1.1448 Y0.8819 I-0.6808 J-0.3338
    N1381 G01 X1.1249 Y0.9159
    N1382 G01 X1.103 Y0.9486
    N1383 G01 X1.0915 Y0.9646
    N1384 G17 G03 X1.0169 Y1.0561 I-1.1007 J-0.8212
    N1385 G17 G03 X0.9617 Y1.1122 I-0.8197 J-0.7512
    N1386 G01 X0.9178 Y1.1516
    N1387 G01 X0.9027 Y1.1643
    N1388 G01 X0.8718 Y1.1887
    N1389 G01 X0.8538 Y1.1967
    N1390 G01 X0.8477 Y1.2
    N1391 G01 X0.3752
    N1392 G01 X0.3687 Y1.1995 Z-0.4999
    N1393 G01 X0.3624 Y1.1978 Z-0.4997
    N1394 G01 X0.3564 Y1.1952 Z-0.4995
    N1395 G01 X0.3509 Y1.1916 Z-0.4992
    N1396 G01 X0.3461 Y1.1871 Z-0.4987
    N1397 G01 X0.3421 Y1.1819 Z-0.4977
    N1398 G01 X0.339 Y1.1761 Z-0.4955
    N1399 G01 X0.337 Y1.1699 Z-0.4902
    N1400 G01 X0.336 Y1.1634 Z-0.4848
    N1401 G01 X0.336 Y1.1569 Z-0.4826
    N1402 G01 X0.3372 Y1.1504 Z-0.4817
    N1403 G01 X0.3394 Y1.1443 Z-0.4811
    N1404 G01 X0.3426 Y1.1386 Z-0.4808
    N1405 G01 X0.3468 Y1.1335 Z-0.4806
    N1406 G01 X0.3517 Y1.1291 Z-0.4804
    N1407 G01 X0.3572 Y1.1256 Z-0.4803
    N1408 G01 X1.1426 Y0.7209
    N1409 G01 X1.1488 Y0.7183 Z-0.4805
    N1410 G01 X1.1553 Y0.7168 Z-0.4807
    N1411 G01 X1.162 Y0.7165 Z-0.4811
    N1412 G01 X1.1687 Y0.7173 Z-0.4819
    N1413 G01 X1.1751 Y0.7192 Z-0.4838
    N1414 G01 X1.1811 Y0.7222 Z-0.4902
    N1415 G01 X1.1865 Y0.7262 Z-0.4965
    N1416 G01 X1.1912 Y0.731 Z-0.4984
    N1417 G01 X1.195 Y0.7366 Z-0.4992
    N1418 G01 X1.1977 Y0.7427 Z-0.4996
    N1419 G01 X1.1994 Y0.7492 Z-0.4998
    N1420 G01 X1.2 Y0.7559 Z-0.5
    N1421 G01 Y1.1299
    N1422 G17 G03 X1.1857 Y1.1665 I-0.3506 J-0.1161
    N1423 G01 X1.1746 Y1.1828
    N1424 G01 X1.1581 Y1.1936
    N1425 G01 X1.1391 Y1.1987
    N1426 G01 X1.1366 Y1.2
    N1427 G01 X0.8413
    N1428 G01 X0.8347 Y1.1994 Z-0.4999
    N1429 G01 X0.8283 Y1.1978 Z-0.4998
    N1430 G01 X0.8222 Y1.195 Z-0.4996
    N1431 G01 X0.8167 Y1.1913 Z-0.4993
    N1432 G01 X0.8119 Y1.1867 Z-0.499
    N1433 G01 X0.8079 Y1.1814 Z-0.4984
    N1434 G01 X0.8049 Y1.1755 Z-0.4974
    N1435 G01 X0.8029 Y1.1691 Z-0.4951
    N1436 G01 X0.802 Y1.1625 Z-0.4902
    N1437 G01 X0.8023 Y1.1559 Z-0.4852
    N1438 G01 X0.8036 Y1.1494 Z-0.483
    N1439 G01 X0.8061 Y1.1432 Z-0.4819
    N1440 G01 X0.8095 Y1.1375 Z-0.4813
    N1441 G01 X0.8139 Y1.1324 Z-0.481
    N1442 G01 X0.819 Y1.1282 Z-0.4807
    N1443 G01 X0.8248 Y1.1249 Z-0.4806
    N1444 G01 X0.831 Y1.1226 Z-0.4804
    N1445 G01 X0.8376 Y1.1214 Z-0.4803
    N1446 G01 X1.1569 Y1.0907
    N1447 G01 X1.1634 Y1.0906 Z-0.4805
    N1448 G01 X1.1699 Y1.0916 Z-0.4809
    N1449 G01 X1.1761 Y1.0937 Z-0.4815
    N1450 G01 X1.1819 Y1.0967 Z-0.4833
    N1451 G01 X1.1871 Y1.1007 Z-0.4902
    N1452 G01 X1.1916 Y1.1055 Z-0.497
    N1453 G01 X1.1952 Y1.111 Z-0.4988
    N1454 G01 X1.1978 Y1.117 Z-0.4994
    N1455 G01 X1.1995 Y1.1233 Z-0.4998
    N1456 G01 X1.2 Y1.1299 Z-0.5
    N1457 G17 G03 X1.1998 Y1.1551 I-0.6238 J0.008
    N1458 G17 G03 X1.1508 Y1.2 I-0.0491 J-0.0044
    N1459 G01 X1.1311
    N1460 G01 X0.5051 Z-0.4803
    N1461 G01 X-0.121
    N1462 G01 X-0.747 Z-0.5
    N1463 G01 X-1.1013
    N1464 G17 G03 X-1.1569 Y1.1802 I0.2015 J-0.6542
    N1465 G01 X-1.1748 Y1.1719
    N1466 G01 X-1.1886 Y1.1579
    N1467 G01 X-1.1966 Y1.1399
    N1468 G01 X-1.2 Y1.1337
    N1469 G01 Y0.8187
    N1470 G01 X-1.1995 Y0.8122 Z-0.4999
    N1471 G01 X-1.1979 Y0.806 Z-0.4998
    N1472 G01 X-1.1953 Y0.8 Z-0.4996
    N1473 G01 X-1.1917 Y0.7946 Z-0.4993
    N1474 G01 X-1.1873 Y0.7898 Z-0.499
    N1475 G01 X-1.1822 Y0.7858 Z-0.4984
    N1476 G01 X-1.1765 Y0.7827 Z-0.4974
    N1477 G01 X-1.1704 Y0.7806 Z-0.4951
    N1478 G01 X-1.164 Y0.7795 Z-0.4902
    N1479 G01 X-1.1575 Z-0.4852
    N1480 G01 X-1.1511 Y0.7805 Z-0.483
    N1481 G01 X-1.145 Y0.7826 Z-0.4819
    N1482 G01 X-1.1392 Y0.7857 Z-0.4813
    N1483 G01 X-1.1341 Y0.7896 Z-0.481
    N1484 G01 X-1.1297 Y0.7944 Z-0.4807
    N1485 G01 X-1.1261 Y0.7998 Z-0.4806
    N1486 G01 X-1.1235 Y0.8057 Z-0.4804
    N1487 G01 X-1.1218 Y0.812 Z-0.4803
    N1488 G01 X-1.0625 Y1.1539
    N1489 G01 X-1.0619 Y1.1607 Z-0.4805
    N1490 G01 X-1.0626 Y1.1676 Z-0.4809
    N1491 G01 X-1.0643 Y1.1742 Z-0.4815
    N1492 G01 X-1.0672 Y1.1804 Z-0.4833
    N1493 G01 X-1.0712 Y1.186 Z-0.4902
    N1494 G01 X-1.076 Y1.1908 Z-0.497
    N1495 G01 X-1.0817 Y1.1947 Z-0.4988
    N1496 G01 X-1.0879 Y1.1976 Z-0.4994
    N1497 G01 X-1.0945 Y1.1994 Z-0.4998
    N1498 G01 X-1.1013 Y1.2 Z-0.5
    N1499 G01 X-1.1508
    N1500 G17 G03 X-1.2 Y1.1508 I0.0001 J-0.0493
    N1501 G01 Y1.1311
    N1502 G01 Y-0.7258
    N1503 G01 Y-1.0998
    N1504 G01 X-1.1868 Y-1.1369
    N1505 G17 G03 X-1.1702 Y-1.1726 I0.3427 J0.1376
    N1506 G01 X-1.157 Y-1.1871
    N1507 G17 G02 X-1.1317 Y-1.2 I-0.2479 J-0.5168
    N1508 G01 X-0.8168
    N1509 G01 X-0.81 Y-1.1994 Z-0.4999
    N1510 G01 X-0.8033 Y-1.1976 Z-0.4997
    N1511 G01 X-0.7971 Y-1.1947 Z-0.4995
    N1512 G01 X-0.7915 Y-1.1908 Z-0.4993
    N1513 G01 X-0.7866 Y-1.1859 Z-0.4988
    N1514 G01 X-0.7827 Y-1.1803 Z-0.4981
    N1515 G01 X-0.7798 Y-1.1741 Z-0.4967
    N1516 G01 X-0.778 Y-1.1675 Z-0.4932
    N1517 G01 X-0.7774 Y-1.1606 Z-0.4872
    N1518 G01 X-0.778 Y-1.1538 Z-0.4837
    N1519 G01 X-0.7798 Y-1.1472 Z-0.4822
    N1520 G01 X-0.7827 Y-1.141 Z-0.4815
    N1521 G01 X-0.7866 Y-1.1353 Z-0.481
    N1522 G01 X-0.7915 Y-1.1305 Z-0.4808
    N1523 G01 X-0.7971 Y-1.1265 Z-0.4806
    N1524 G01 X-0.8033 Y-1.1236 Z-0.4804
    N1525 G01 X-0.8099 Y-1.1219 Z-0.4803
    N1526 G01 X-1.1538 Y-1.061
    N1527 G01 X-1.16 Y-1.0604 Z-0.4805
    N1528 G01 X-1.1662 Y-1.0608 Z-0.4808
    N1529 G01 X-1.1723 Y-1.0622 Z-0.4813
    N1530 G01 X-1.1781 Y-1.0645 Z-0.4824
    N1531 G01 X-1.1835 Y-1.0677 Z-0.4859
    N1532 G01 X-1.1882 Y-1.0717 Z-0.4944
    N1533 G01 X-1.1923 Y-1.0765 Z-0.4979
    N1534 G01 X-1.1956 Y-1.0818 Z-0.499
    N1535 G01 X-1.198 Y-1.0875 Z-0.4995
    N1536 G01 X-1.1995 Y-1.0936 Z-0.4998
    N1537 G01 X-1.2 Y-1.0998 Z-0.5
    N1538 G01 Y-1.1508
    N1539 G17 G03 X-1.1508 Y-1.2 I0.0493 J0.0001
    N1540 G01 X-1.1311
    N1541 G01 X0.7337
    N1542 G01 X1.1077
    N1543 G17 G03 X1.145 Y-1.1874 I-0.2244 J0.7243
    N1544 G01 X1.1631 Y-1.1796
    N1545 G01 X1.1802 Y-1.1699
    N1546 G01 X1.192 Y-1.1542
    N1547 G01 X1.1981 Y-1.1354
    N1548 G01 X1.2 Y-1.1319
    N1549 G01 Y-0.8366
    N1550 G01 X1.1995 Y-0.8302 Z-0.4999
    N1551 G01 X1.1979 Y-0.8238 Z-0.4998
    N1552 G01 X1.1952 Y-0.8179 Z-0.4996
    N1553 G01 X1.1917 Y-0.8124 Z-0.4993
    N1554 G01 X1.1873 Y-0.8077 Z-0.499
    N1555 G01 X1.1821 Y-0.8037 Z-0.4984
    N1556 G01 X1.1764 Y-0.8006 Z-0.4974
    N1557 G01 X1.1702 Y-0.7985 Z-0.4951
    N1558 G01 X1.1638 Y-0.7974 Z-0.4902
    N1559 G01 X1.1573 Z-0.4852
    N1560 G01 X1.1509 Y-0.7985 Z-0.483
    N1561 G01 X1.1447 Y-0.8006 Z-0.4819
    N1562 G01 X1.139 Y-0.8037 Z-0.4813
    N1563 G01 X1.1339 Y-0.8077 Z-0.481
    N1564 G01 X1.1295 Y-0.8125 Z-0.4807
    N1565 G01 X1.1259 Y-0.818 Z-0.4806
    N1566 G01 X1.1234 Y-0.824 Z-0.4804
    N1567 G01 X1.1218 Y-0.8303 Z-0.4803
    N1568 G01 X1.0688 Y-1.1543
    N1569 G01 X1.0683 Y-1.1611 Z-0.4805
    N1570 G01 X1.069 Y-1.1679 Z-0.4809
    N1571 G01 X1.0708 Y-1.1744 Z-0.4815
    N1572 G01 X1.0737 Y-1.1806 Z-0.4833
    N1573 G01 X1.0777 Y-1.1861 Z-0.4902
    N1574 G01 X1.0825 Y-1.1909 Z-0.497
    N1575 G01 X1.0881 Y-1.1948 Z-0.4988
    N1576 G01 X1.0943 Y-1.1977 Z-0.4994
    N1577 G01 X1.1009 Y-1.1994 Z-0.4998
    N1578 G01 X1.1077 Y-1.2 Z-0.5
    N1579 G01 X1.1508
    N1580 G17 G03 X1.2 Y-1.1508 I-0.0001 J0.0493
    N1581 G01 Y-1.1311
    N1582 G17 G03 X1.1885 Y-1.1033 I-0.0397 J-0.0001
    N1583 G00 Z-0.15
    N1584 G00 Z0.1
    N1585 G00 X-0.1183 Y0.0064
    N1586 G00 Z-0.4
    N1587 G01 Z-0.75 F44.6296 <<<<<<<<<<<<<<<<<<<<<<<<  Z Feed Move
    N1588 G17 G03 X0.1132 Y0.0719 I0.125 J0. F89.2592
    N1589 G17 G03 X0.0729 Y0.1226 I-0.2091 J-0.1248
    N1590 G17 G03 X0.0463 Y0.1458 I-0.1884 J-0.1898
    N1591 G17 G03 X0.0277 Y0.1589 I-0.1122 J-0.139
    N1592 G17 G03 X-0.0161 Y0.1798 I-0.1261 J-0.2078
    N1593 G17 G03 X-0.0409 Y0.1869 I-0.059 J-0.1599
    N1594 G17 G03 X-0.0719 Y0.1915 I-0.0385 J-0.1511
    N1595 G17 G03 X-0.1042 Y0.1916 I-0.0162 J-0.1609
    N1596 G17 G03 X-0.1227 Y0.1891 I0.0156 J-0.1907
    N1597 G17 G03 X-0.1886 Y0.1636 I0.0251 J-0.1625
    N1598 G17 G03 X-0.2325 Y0.1267 I0.1375 J-0.2085
    N1599 G01 X-0.2422 Y0.1158
    N1600 G17 G03 X-0.2611 Y0.0876 I0.3169 J-0.2331
    N1601 G17 G03 X-0.2757 Y0.0568 I0.4395 J-0.2281
    N1602 G17 G03 X-0.2848 Y0.0288 I0.4884 J-0.1726
    N1603 G17 G03 X-0.2898 Y0.0046 I6.551 J-1.3943
    N1604 G01 X-0.2921 Y-0.0151
    N1605 G01 X-0.2928 Y-0.0399
    N1606 G01 X-0.2916 Y-0.0598
    N1607 G17 G03 X-0.2869 Y-0.0893 I0.2682 J0.0279
    N1608 G17 G03 X-0.2791 Y-0.1184 I0.1561 J0.0261
    N1609 G17 G03 X-0.2705 Y-0.142 I0.2302 J0.0707
    N1610 G17 G03 X-0.2596 Y-0.1648 I2.6951 J1.2685
    N1611 G01 X-0.2522 Y-0.1781
    N1612 G17 G03 X-0.2151 Y-0.2262 I0.241 J0.1477
    N1613 G17 G03 X-0.1431 Y-0.2824 I0.2491 J0.2448
    N1614 G17 G03 X-0.1253 Y-0.2925 I0.3567 J0.6078
    N1615 G17 G03 X-0.0777 Y-0.3115 I0.2127 J0.463
    N1616 G01 X-0.0528 Y-0.318
    N1617 G17 G02 X-0.0428 Y-0.3202 I-0.0281 J-0.1555
    N1618 G17 G03 X-0.0122 Y-0.3247 I0.5747 J3.8199
    N1619 G01 X0.0136 Y-0.3261
    N1620 G17 G03 X0.0394 Y-0.3253 I-0.0027 J0.5093
    N1621 G01 X0.06 Y-0.3233
    N1622 G01 X0.0855 Y-0.319
    N1623 G17 G02 X0.1056 Y-0.3139 I0.2344 J-0.8799
    N1624 G17 G03 X0.1349 Y-0.3037 I-0.0816 J0.2832
    N1625 G17 G03 X0.154 Y-0.2956 I-0.0804 J0.2154
    N1626 G17 G03 X0.1724 Y-0.286 I-0.121 J0.2553
    N1627 G17 G03 X0.186 Y-0.2784 I-0.0605 J0.1241
    N1628 G17 G03 X0.2034 Y-0.2672 I-0.1073 J0.1851
    N1629 G17 G03 X0.2433 Y-0.2339 I-0.2093 J0.291
    N1630 G17 G03 X0.2544 Y-0.223 I-0.0791 J0.0916
    N1631 G17 G03 X0.2784 Y-0.1957 I-0.1714 J0.1754
    N1632 G17 G03 X0.2936 Y-0.1745 I-0.1201 J0.1024
    N1633 G17 G03 X0.3246 Y-0.1143 I-0.3699 J0.2281
    N1634 G17 G03 X0.3374 Y-0.0746 I-0.5271 J0.1922
    N1635 G17 G03 X0.3457 Y-0.0284 I-0.3439 J0.0858
    N1636 G17 G03 X0.3478 Y-0.0024 I-0.3582 J0.0419
    N1637 G17 G03 X0.3461 Y0.0446 I-0.3421 J0.0107
    N1638 G17 G03 X0.3426 Y0.0705 I-0.194 J-0.013
    N1639 G17 G03 X0.3397 Y0.0859 I-0.1352 J-0.0171
    N1640 G17 G02 X0.3363 Y0.1013 I0.4939 J0.1185
    N1641 G17 G03 X0.3254 Y0.1363 I-0.3981 J-0.1041
    N1642 G17 G03 X0.3179 Y0.156 I-0.1971 J-0.0638
    N1643 G17 G03 X0.3024 Y0.1895 I-0.2174 J-0.0806
    N1644 G01 X0.295 Y0.2036
    N1645 G17 G03 X0.275 Y0.235 I-0.6641 J-0.401
    N1646 G17 G03 X0.2523 Y0.265 I-0.235 J-0.1545
    N1647 G17 G03 X0.2312 Y0.2897 I-0.192 J-0.1423
    N1648 G17 G03 X0.195 Y0.323 I-0.2555 J-0.2419
    N1649 G17 G03 X0.1865 Y0.3302 I-0.0548 J-0.0555
    N1650 G17 G03 X0.169 Y0.3438 I-0.1286 J-0.1479
    N1651 G17 G03 X0.1553 Y0.3537 I-0.087 J-0.1058
    N1652 G17 G03 X0.1364 Y0.3659 I-0.1274 J-0.1764
    N1653 G17 G03 X0.1217 Y0.3745 I-0.0834 J-0.1247
    N1654 G17 G03 X0.1067 Y0.3827 I-0.0719 J-0.1154
    N1655 G17 G03 X0.0859 Y0.3924 I-0.0656 J-0.1128
    N1656 G17 G03 X0.0424 Y0.408 I-0.2621 J-0.6642
    N1657 G17 G02 X0.0199 Y0.4147 I0.1919 J0.6808
    N1658 G17 G03 X-0.0205 Y0.4226 I-0.3014 J-1.4314
    N1659 G17 G03 X-0.0619 Y0.4266 I-0.1514 J-1.3734
    N1660 G17 G03 X-0.0919 Y0.4265 I-0.0145 J-0.5171
    N1661 G17 G03 X-0.1161 Y0.4257 I-0.0065 J-0.1698
    N1662 G17 G03 X-0.1402 Y0.4232 I0.0079 J-0.1918
    N1663 G17 G03 X-0.1702 Y0.4178 I0.0345 J-0.2796
    N1664 G17 G03 X-0.2235 Y0.4029 I0.0884 J-0.4178
    N1665 G17 G03 X-0.2467 Y0.3943 I0.0949 J-0.2912
    N1666 G17 G03 X-0.2807 Y0.3787 I0.0818 J-0.2234
    N1667 G17 G03 X-0.308 Y0.3634 I0.1354 J-0.2747
    N1668 G17 G03 X-0.3241 Y0.3535 I0.0848 J-0.1557
    N1669 G17 G03 X-0.3446 Y0.3388 I0.1529 J-0.234
    N1670 G17 G03 X-0.3549 Y0.3313 I0.0432 J-0.0703
    N1671 G17 G03 X-0.3928 Y0.2975 I0.1827 J-0.2431
    N1672 G17 G02 X-0.4063 Y0.2839 I-4.0757 J4.0233
    N1673 G01 X-0.4192 Y0.2695
    N1674 G17 G03 X-0.4847 Y0.1665 I0.3493 J-0.2944
    N1675 G17 G03 X-0.5024 Y0.1245 I0.5336 J-0.2507
    N1676 G17 G03 X-0.5068 Y0.1122 I0.1478 J-0.0592
    N1677 G17 G03 X-0.513 Y0.0936 I0.1516 J-0.0608
    N1678 G17 G03 X-0.5182 Y0.0746 I0.1267 J-0.0447
    N1679 G17 G03 X-0.5251 Y0.0425 I1.2581 J-0.2883
    N1680 G17 G02 X-0.5274 Y0.0295 I-0.1688 J0.0228
    N1681 G17 G03 X-0.5311 Y-0.0098 I0.6106 J-0.0787
    N1682 G17 G03 X-0.5321 Y-0.0296 I0.1555 J-0.0173
    N1683 G17 G03 X-0.5322 Y-0.0494 I0.3056 J-0.0115
    N1684 G17 G03 X-0.5315 Y-0.0759 I0.17 J-0.0091
    N1685 G17 G03 X-0.5272 Y-0.1155 I0.3394 J0.0175
    N1686 G17 G02 X-0.5253 Y-0.1287 I-0.2199 J-0.0374
    N1687 G17 G02 X-0.5202 Y-0.1548 I-1.3025 J-0.2678
    N1688 G17 G02 X-0.5136 Y-0.1806 I-3.1403 J-0.8169
    N1689 G17 G03 X-0.5036 Y-0.2125 I1.0693 J0.3182
    N1690 G01 X-0.4942 Y-0.2376
    N1691 G17 G02 X-0.4861 Y-0.256 I-0.5356 J-0.245
    N1692 G17 G03 X-0.4642 Y-0.2974 I0.7466 J0.368
    N1693 G17 G02 X-0.4504 Y-0.3205 I-0.6891 J-0.4288
    N1694 G17 G03 X-0.4311 Y-0.3479 I0.5469 J0.3637
    N1695 G17 G03 X-0.4189 Y-0.364 I0.1625 J0.1104
    N1696 G17 G02 X-0.3973 Y-0.3898 I-16.1 J-13.5114
    N1697 G17 G03 X-0.3738 Y-0.414 I0.342 J0.3092
    N1698 G17 G03 X-0.3643 Y-0.4235 I0.0695 J0.0597
    N1699 G17 G03 X-0.3122 Y-0.4664 I0.2784 J0.2849
    N1700 G17 G03 X-0.3013 Y-0.4745 I0.0614 J0.0711
    N1701 G17 G03 X-0.2846 Y-0.4861 I0.1186 J0.1533
    N1702 G17 G03 X-0.2617 Y-0.5006 I0.2095 J0.3071
    N1703 G17 G03 X-0.2258 Y-0.5198 I0.274 J0.4693
    N1704 G17 G03 X-0.1884 Y-0.536 I0.4011 J0.8721
    N1705 G17 G02 X-0.1694 Y-0.5433 I-0.2739 J-0.7399
    N1706 G17 G02 X-0.1501 Y-0.5501 I-0.1452 J-0.4455
    N1707 G17 G02 X-0.1306 Y-0.5563 I-0.0856 J-0.303
    N1708 G17 G03 X-0.0706 Y-0.5689 I0.2752 J1.1604
    N1709 G17 G02 X-0.0504 Y-0.5722 I-0.0423 J-0.3185
    N1710 G17 G03 X-0.0096 Y-0.5757 I0.2447 J2.6537
    N1711 G17 G02 X0.004 Y-0.5764 I-0.0014 J-0.1586
    N1712 G01 X0.0314 Y-0.5763
    N1713 G17 G03 X0.0723 Y-0.5735 I-0.0736 J1.3605
    N1714 G17 G03 X0.0926 Y-0.5711 I-0.014 J0.2102
    N1715 G17 G03 X0.1129 Y-0.5679 I-0.106 J0.722
    N1716 G17 G03 X0.1331 Y-0.5642 I-0.0185 J0.1597
    N1717 G17 G03 X0.1664 Y-0.5565 I-0.0606 J0.337
    N1718 G17 G03 X0.1926 Y-0.5487 I-0.0833 J0.3282
    N1719 G17 G03 X0.2438 Y-0.5293 I-0.1558 J0.4882
    N1720 G17 G03 X0.2687 Y-0.5179 I-0.1452 J0.3488
    N1721 G17 G03 X0.2931 Y-0.5054 I-0.1716 J0.3674
    N1722 G17 G03 X0.317 Y-0.492 I-0.1103 J0.223
    N1723 G17 G03 X0.3345 Y-0.4812 I-0.0968 J0.1776
    N1724 G17 G03 X0.3627 Y-0.4618 I-2.7896 J4.0805
    N1725 G17 G03 X0.3949 Y-0.4361 I-1.0407 J1.3381
    N1726 G17 G03 X0.4201 Y-0.4128 I-0.3849 J0.4413
    N1727 G17 G03 X0.4348 Y-0.3983 I-0.1297 J0.1464
    N1728 G17 G03 X0.4622 Y-0.3676 I-0.3182 J0.3105
    N1729 G17 G03 X0.4753 Y-0.3517 I-0.1333 J0.1234
    N1730 G17 G03 X0.5105 Y-0.3009 I-0.355 J0.2845
    N1731 G01 X0.521 Y-0.2832
    N1732 G17 G03 X0.528 Y-0.2713 I-0.0934 J0.0631
    N1733 G17 G03 X0.538 Y-0.2533 I-0.1717 J0.1069
    N1734 G17 G03 X0.5474 Y-0.2349 I-0.1578 J0.0922
    N1735 G17 G03 X0.5561 Y-0.2161 I-0.1744 J0.0924
    N1736 G17 G03 X0.5641 Y-0.1971 I-0.1796 J0.0871
    N1737 G17 G03 X0.5733 Y-0.1711 I-0.2194 J0.0923
    N1738 G17 G03 X0.5918 Y-0.0976 I-0.7397 J0.2254
    N1739 G17 G03 X0.5944 Y-0.084 I-0.1947 J0.0433
    N1740 G17 G03 X0.5983 Y-0.0567 I-0.2319 J0.0473
    N1741 G01 X0.601 Y-0.0292
    N1742 G17 G02 X0.6021 Y-0.0155 I0.334 J-0.0181
    N1743 G17 G03 X0.6027 Y0.0329 I-2.9941 J0.0622
    N1744 G17 G03 X0.6002 Y0.0673 I-0.6619 J-0.0302
    N1745 G17 G03 X0.5973 Y0.0948 I-0.2746 J-0.0151
    N1746 G17 G03 X0.5953 Y0.1085 I-0.3917 J-0.0508
    N1747 G17 G03 X0.5918 Y0.1289 I-0.1674 J-0.018
    N1748 G01 X0.5877 Y0.1493
    N1749 G17 G03 X0.5728 Y0.2026 I-0.6104 J-0.1425
    N1750 G17 G03 X0.5642 Y0.229 I-0.2246 J-0.058
    N1751 G17 G03 X0.5545 Y0.255 I-0.2562 J-0.0816
    N1752 G17 G03 X0.5436 Y0.2806 I-0.2933 J-0.1097
    N1753 G17 G03 X0.5316 Y0.3057 I-0.2599 J-0.1089
    N1754 G17 G03 X0.5185 Y0.3303 I-0.2406 J-0.1113
    N1755 G17 G03 X0.5009 Y0.3605 I-0.2569 J-0.1302
    N1756 G17 G03 X0.4898 Y0.3783 I-0.1777 J-0.0987
    N1757 G17 G03 X0.4696 Y0.4069 I-8.5775 J-6.0245
    N1758 G17 G02 X0.4569 Y0.4238 I0.2502 J0.2018
    N1759 G17 G03 X0.4342 Y0.4507 I-0.5803 J-0.4653
    N1760 G17 G03 X0.4201 Y0.4665 I-0.1615 J-0.13
    N1761 G17 G03 X0.4052 Y0.4817 I-1.1281 J-1.0914
    N1762 G17 G03 X0.3692 Y0.5158 I-0.2607 J-0.2393
    N1763 G17 G03 X0.3585 Y0.5253 I-0.0806 J-0.0799
    N1764 G17 G03 X0.3248 Y0.5517 I-0.2322 J-0.261
    N1765 G17 G02 X0.3014 Y0.5683 I0.4797 J0.7044
    N1766 G01 X0.2834 Y0.5801
    N1767 G17 G03 X0.2202 Y0.6146 I-0.3235 J-0.5185
    N1768 G17 G03 X0.2072 Y0.6211 I-0.0507 J-0.0844
    N1769 G01 X0.1941 Y0.6277
    N1770 G17 G02 X0.1741 Y0.6366 I0.1482 J0.3558
    N1771 G17 G02 X0.1606 Y0.6421 I0.0781 J0.2123
    N1772 G17 G02 X0.14 Y0.6497 I0.1191 J0.3559
    N1773 G17 G02 X0.1192 Y0.657 I0.097 J0.3102
    N1774 G17 G02 X0.1052 Y0.6614 I0.0403 J0.1544
    N1775 G17 G03 X0.0405 Y0.6755 I-0.2798 J-1.1208
    N1776 G17 G02 X0.0186 Y0.6794 I0.1793 J1.0844
    N1777 G17 G02 X0.0039 Y0.6816 I0.0297 J0.249
    N1778 G17 G03 X-0.0405 Y0.6852 I-0.2664 J-2.9859
    N1779 G17 G02 X-0.0629 Y0.6865 I0.0349 J0.8298
    N1780 G17 G03 X-0.1151 Y0.6854 I-0.011 J-0.7208
    N1781 G17 G03 X-0.1302 Y0.6847 I-0.0028 J-0.107
    N1782 G17 G03 X-0.1526 Y0.6826 I0.032 J-0.4672
    N1783 G01 X-0.1677 Y0.6816
    N1784 G17 G03 X-0.1975 Y0.6769 I0.095 J-0.7029
    N1785 G17 G03 X-0.2198 Y0.6727 I0.0208 J-0.174
    N1786 G17 G03 X-0.2568 Y0.6641 I0.0709 J-0.3886
    N1787 G01 X-0.2714 Y0.66
    N1788 G17 G03 X-0.2933 Y0.6536 I0.0347 J-0.1593
    N1789 G17 G03 X-0.3223 Y0.6439 I0.094 J-0.3287
    N1790 G17 G03 X-0.3508 Y0.6328 I0.1404 J-0.4015
    N1791 G17 G03 X-0.3718 Y0.6234 I0.1153 J-0.2875
    N1792 G17 G03 X-0.4198 Y0.5992 I0.2676 J-0.5892
    N1793 G17 G03 X-0.4465 Y0.5836 I0.1468 J-0.2833
    N1794 G17 G03 X-0.4661 Y0.5712 I0.1201 J-0.2114
    N1795 G17 G02 X-0.4791 Y0.5629 I-0.0804 J0.1106
    N1796 G17 G03 X-0.5042 Y0.5446 I0.3433 J-0.4957
    N1797 G17 G03 X-0.5345 Y0.5203 I0.1932 J-0.2729
    N1798 G01 X-0.5522 Y0.505
    N1799 G17 G03 X-0.5802 Y0.478 I5.9927 J-6.23
    N1800 G17 G03 X-0.6067 Y0.4493 I1.0147 J-0.9628
    N1801 G17 G03 X-0.632 Y0.4193 I0.2831 J-0.2646
    N1802 G01 X-0.6511 Y0.3944
    N1803 G17 G03 X-0.6775 Y0.3553 I0.5063 J-0.3695
    N1804 G01 X-0.6863 Y0.3421
    N1805 G17 G02 X-0.6945 Y0.3286 I-0.4584 J0.2688
    N1806 G17 G03 X-0.7203 Y0.2796 I0.7248 J-0.4133
    N1807 G17 G03 X-0.766 Y0.153 I0.6755 J-0.3156
    N1808 G17 G03 X-0.7821 Y0.083 I0.9882 J-0.2628
    N1809 G17 G02 X-0.7863 Y0.0593 I-0.5844 J0.0936
    N1810 G17 G02 X-0.7888 Y0.0435 I-0.2055 J0.0232
    N1811 G17 G03 X-0.7926 Y-0.0044 I0.8035 J-0.0883
    N1812 G17 G03 X-0.794 Y-0.0285 I0.2479 J-0.0264
    N1813 G17 G03 X-0.7946 Y-0.0446 I0.1163 J-0.0123
    N1814 G17 G03 X-0.7941 Y-0.0687 I0.6285 J0.0004
    N1815 G17 G03 X-0.7928 Y-0.1009 I0.2518 J-0.0064
    N1816 G01 X-0.7908 Y-0.125
    N1817 G17 G02 X-0.7893 Y-0.141 I-0.1636 J-0.0241
    N1818 G17 G02 X-0.7846 Y-0.173 I-3.9309 J-0.5874
    N1819 G17 G02 X-0.7767 Y-0.2126 I-4.2414 J-0.8708
    N1820 G17 G03 X-0.7594 Y-0.2749 I0.6723 J0.1529
    N1821 G17 G03 X-0.7519 Y-0.298 I0.2534 J0.069
    N1822 G17 G03 X-0.7174 Y-0.3801 I0.6339 J0.2183
    N1823 G01 X-0.7102 Y-0.3946
    N1824 G17 G03 X-0.699 Y-0.4163 I0.1661 J0.0715
    N1825 G17 G03 X-0.6914 Y-0.4307 I0.1264 J0.0583
    N1826 G17 G03 X-0.6611 Y-0.4788 I0.6892 J0.3998
    N1827 G17 G03 X-0.6472 Y-0.4989 I0.273 J0.1733
    N1828 G17 G03 X-0.628 Y-0.5252 I0.2639 J0.1738
    N1829 G17 G03 X-0.6181 Y-0.5382 I0.1072 J0.0708
    N1830 G17 G03 X-0.6024 Y-0.5569 I0.4234 J0.3411
    N1831 G17 G03 X-0.575 Y-0.5871 I0.2744 J0.22
    N1832 G17 G03 X-0.5401 Y-0.6214 I0.3926 J0.3651
    N1833 G17 G03 X-0.5095 Y-0.6486 I0.2685 J0.2717
    N1834 G17 G03 X-0.4711 Y-0.679 I0.3004 J0.3395
    N1835 G17 G02 X-0.4446 Y-0.6983 I-1.2124 J-1.6987
    N1836 G17 G03 X-0.403 Y-0.7244 I0.3813 J0.5594
    N1837 G17 G03 X-0.389 Y-0.733 I0.076 J0.1092
    N1838 G17 G03 X-0.3457 Y-0.7563 I0.2685 J0.4451
    N1839 G17 G03 X-0.3084 Y-0.7732 I0.311 J0.6382
    N1840 G17 G03 X-0.2934 Y-0.78 I0.0585 J0.1094
    N1841 G17 G03 X-0.2782 Y-0.7864 I0.0566 J0.1133
    N1842 G17 G03 X-0.2553 Y-0.7955 I0.0911 J0.1942
    N1843 G17 G03 X-0.2398 Y-0.8011 I0.0573 J0.1364
    N1844 G17 G03 X-0.2242 Y-0.8062 I0.0518 J0.131
    N1845 G01 X-0.2086 Y-0.8113
    N1846 G17 G02 X-0.1927 Y-0.8159 I-0.0549 J-0.219
    N1847 G17 G02 X-0.1689 Y-0.8224 I-0.0832 J-0.3501
    N1848 G17 G02 X-0.1529 Y-0.8262 I-0.0322 J-0.1708
    N1849 G17 G03 X-0.0878 Y-0.8366 I0.2605 J1.4224
    N1850 G17 G03 X-0.0468 Y-0.8411 I0.215 J1.7627
    N1851 G17 G03 X0.0108 Y-0.8434 I0.1074 J2.0432
    N1852 G17 G02 X0.0273 Y-0.8436 I0.0048 J-0.2593
    N1853 G17 G03 X0.0603 Y-0.8424 I-0.002 J0.5135
    N1854 G17 G03 X0.085 Y-0.841 I-0.0072 J0.3557
    N1855 G17 G03 X0.1097 Y-0.8389 I-0.0051 J0.2039
    N1856 G17 G03 X0.1425 Y-0.835 I-0.7833 J6.7314
    N1857 G17 G03 X0.175 Y-0.8292 I-0.1712 J1.0458
    N1858 G17 G03 X0.1993 Y-0.8244 I-0.0329 J0.2312
    N1859 G17 G03 X0.2154 Y-0.8206 I-0.2115 J0.9484
    N1860 G17 G03 X0.2395 Y-0.8147 I-0.0421 J0.221
    N1861 G17 G03 X0.2869 Y-0.8001 I-0.1615 J0.6106
    N1862 G17 G03 X0.3103 Y-0.7921 I-0.0578 J0.2076
    N1863 G17 G03 X0.3564 Y-0.7737 I-0.1958 J0.5555
    N1864 G17 G03 X0.4657 Y-0.7152 I-0.3367 J0.7604
    N1865 G17 G03 X0.5138 Y-0.683 I-0.537 J0.8548
    N1866 G17 G03 X0.5337 Y-0.6682 I-0.1838 J0.2692
    N1867 G17 G03 X0.547 Y-0.6583 I-0.0761 J0.1157
    N1868 G17 G03 X0.5788 Y-0.6318 I-1.184 J1.4536
    N1869 G17 G03 X0.6207 Y-0.5918 I-0.6126 J0.6836
    N1870 G17 G03 X0.6325 Y-0.5801 I-0.102 J0.1149
    N1871 G17 G03 X0.6813 Y-0.5238 I-0.5689 J0.5424
    N1872 G17 G03 X0.6919 Y-0.511 I-0.0995 J0.0925
    N1873 G17 G03 X0.721 Y-0.4707 I-0.3984 J0.3186
    N1874 G17 G03 X0.7436 Y-0.4359 I-0.8392 J0.5697
    N1875 G17 G03 X0.7601 Y-0.4072 I-1.2202 J0.7199
    N1876 G17 G03 X0.7722 Y-0.3854 I-0.2088 J0.1306
    N1877 G17 G03 X0.7908 Y-0.3483 I-0.4731 J0.2607
    N1878 G17 G03 X0.8187 Y-0.2791 I-0.7359 J0.3368
    N1879 G17 G03 X0.8276 Y-0.2558 I-0.1825 J0.0834
    N1880 G17 G03 X0.833 Y-0.2401 I-0.1355 J0.0551
    N1881 G17 G03 X0.8381 Y-0.2243 I-0.1416 J0.0539
    N1882 G01 X0.8431 Y-0.2084
    N1883 G17 G02 X0.8476 Y-0.1924 I0.2319 J-0.0557
    N1884 G17 G03 X0.8662 Y-0.086 I-0.945 J0.2198
    N1885 G17 G03 X0.8691 Y-0.0612 I-0.3137 J0.0497
    N1886 G17 G03 X0.8711 Y-0.0363 I-0.2323 J0.0315
    N1887 G17 G03 X0.8728 Y0.0136 I-8.3889 J0.3131
    N1888 G17 G02 X0.873 Y0.0303 I0.2414 J0.0057
    N1889 G17 G03 X0.8705 Y0.0802 I-1.0732 J-0.0286
    N1890 G17 G03 X0.865 Y0.1299 I-1.0809 J-0.0944
    N1891 G17 G03 X0.8615 Y0.1546 I-0.2334 J-0.0202
    N1892 G17 G02 X0.8574 Y0.1793 I1.4974 J0.2644
    N1893 G17 G03 X0.8503 Y0.2118 I-0.9978 J-0.2003
    N1894 G17 G03 X0.8426 Y0.2443 I-0.3308 J-0.0612
    N1895 G17 G03 X0.8382 Y0.2604 I-0.6203 J-0.1615
    N1896 G17 G03 X0.8312 Y0.2844 I-0.2102 J-0.0478
    N1897 G17 G03 X0.8148 Y0.3317 I-0.5842 J-0.1765
    N1898 G17 G03 X0.8059 Y0.3552 I-0.2635 J-0.0871
    N1899 G17 G03 X0.7963 Y0.3783 I-0.2656 J-0.0962
    N1900 G17 G03 X0.7634 Y0.446 I-0.7591 J-0.3275
    N1901 G17 G03 X0.7515 Y0.4682 I-0.1738 J-0.0784
    N1902 G17 G03 X0.7391 Y0.4901 I-0.2192 J-0.1107
    N1903 G17 G02 X0.7305 Y0.5046 I0.2659 J0.1663
    N1904 G01 X0.7214 Y0.5186
    N1905 G17 G03 X0.7124 Y0.5329 I-0.1127 J-0.0609
    N1906 G17 G03 X0.6779 Y0.5806 I-0.9501 J-0.6512
    N1907 G17 G03 X0.6622 Y0.6004 I-0.4089 J-0.308
    N1908 G17 G03 X0.6461 Y0.6199 I-0.206 J-0.1532
    N1909 G17 G03 X0.6179 Y0.6513 I-0.7859 J-0.6767
    N1910 G17 G03 X0.5886 Y0.6818 I-0.289 J-0.2497
    N1911 G17 G03 X0.5512 Y0.7163 I-0.4106 J-0.4066
    N1912 G17 G03 X0.5253 Y0.7382 I-0.2833 J-0.3079
    N1913 G17 G02 X0.5056 Y0.7545 I1.0945 J1.3493
    N1914 G17 G02 X0.4716 Y0.7802 I1.3007 J1.756
    N1915 G17 G03 X0.429 Y0.8085 I-0.4658 J-0.6559
    N1916 G17 G03 X0.4145 Y0.8177 I-0.1059 J-0.1491
    N1917 G17 G03 X0.3775 Y0.8392 I-0.2794 J-0.4402
    N1918 G17 G03 X0.3625 Y0.8476 I-0.0716 J-0.1101
    N1919 G17 G03 X0.3006 Y0.8775 I-0.3019 J-0.5458
    N1920 G17 G03 X0.2686 Y0.8904 I-0.4778 J-1.1409
    N1921 G17 G03 X0.2446 Y0.9002 I-0.1014 J-0.2121
    N1922 G17 G03 X0.2283 Y0.9062 I-0.061 J-0.14
    N1923 G17 G03 X0.212 Y0.9119 I-0.0597 J-0.147
    N1924 G17 G03 X0.1872 Y0.92 I-0.0964 J-0.2533
    N1925 G17 G03 X0.1705 Y0.9248 I-0.0605 J-0.1773
    N1926 G17 G03 X0.1538 Y0.9293 I-0.0564 J-0.177
    N1927 G17 G03 X0.1284 Y0.9357 I-0.0795 J-0.2594
    N1928 G17 G03 X0.1114 Y0.9395 I-0.0472 J-0.1725
    N1929 G17 G03 X0.0943 Y0.943 I-0.0394 J-0.1505
    N1930 G17 G03 X0.0772 Y0.9462 I-0.0344 J-0.1367
    N1931 G17 G02 X0.06 Y0.9492 I0.0235 J0.1838
    N1932 G17 G03 X-0.0183 Y0.957 I-0.238 J-1.9936
    N1933 G17 G02 X-0.0358 Y0.9581 I0.0079 J0.257
    N1934 G17 G03 X-0.0885 Y0.9584 I-0.0332 J-1.1819
    N1935 G17 G03 X-0.1149 Y0.9579 I-0.0048 J-0.4187
    N1936 G17 G03 X-0.1325 Y0.9574 I-0.005 J-0.1385
    N1937 G01 X-0.1677 Y0.9549
    N1938 G17 G02 X-0.1853 Y0.9535 I-0.0258 J0.2102
    N1939 G17 G03 X-0.2203 Y0.9487 I0.209 J-1.6591
    N1940 G17 G03 X-0.2466 Y0.9445 I0.027 J-0.2547
    N1941 G17 G02 X-0.2727 Y0.9397 I-0.3255 J1.6977
    N1942 G17 G02 X-0.316 Y0.9297 I-0.766 J3.22
    N1943 G17 G03 X-0.3502 Y0.9201 I0.6385 J-2.3341
    N1944 G17 G03 X-0.3758 Y0.9125 I0.0628 J-0.2585
    N1945 G17 G03 X-0.3927 Y0.9069 I0.1033 J-0.3402
    N1946 G17 G03 X-0.4098 Y0.9014 I0.0323 J-0.1295
    N1947 G17 G02 X-0.4266 Y0.8954 I-0.1307 J0.3373
    N1948 G17 G03 X-0.4842 Y0.8708 I0.2949 J-0.7707
    N1949 G17 G03 X-0.5085 Y0.8595 I0.076 J-0.1953
    N1950 G17 G03 X-0.5326 Y0.8473 I0.0991 J-0.2258
    N1951 G17 G03 X-0.5642 Y0.8302 I0.1558 J-0.3247
    N1952 G17 G03 X-0.5874 Y0.8164 I0.1548 J-0.2884
    N1953 G17 G03 X-0.6103 Y0.802 I0.1394 J-0.2469
    N1954 G17 G03 X-0.6328 Y0.787 I0.1222 J-0.2082
    N1955 G17 G03 X-0.6478 Y0.7769 I0.0728 J-0.1238
    N1956 G17 G03 X-0.6906 Y0.7437 I0.5697 J-0.7789
    N1957 G17 G03 X-0.7115 Y0.7264 I0.1881 J-0.2481
    N1958 G17 G03 X-0.7254 Y0.7148 I0.0926 J-0.1248
    N1959 G17 G03 X-0.7453 Y0.6963 I0.8718 J-0.9628
    N1960 G17 G03 X-0.765 Y0.6775 I0.231 J-0.2598
    N1961 G17 G03 X-0.7781 Y0.6648 I0.0996 J-0.1163
    N1962 G17 G03 X-0.7967 Y0.645 I0.4501 J-0.4424
    N1963 G17 G03 X-0.8152 Y0.6249 I0.2285 J-0.2283
    N1964 G17 G02 X-0.833 Y0.6042 I-0.4849 J0.4
    N1965 G17 G03 X-0.8556 Y0.5755 I0.7338 J-0.5998
    N1966 G17 G03 X-0.8668 Y0.5611 I0.134 J-0.1162
    N1967 G17 G03 X-0.8877 Y0.5312 I0.4063 J-0.3068
    N1968 G17 G02 X-0.8981 Y0.5162 I-0.8795 J0.5968
    N1969 G17 G03 X-0.9267 Y0.4693 I0.8356 J-0.5407
    N1970 G17 G03 X-0.9359 Y0.4535 I0.172 J-0.1116
    N1971 G17 G03 X-0.9611 Y0.4046 I0.5423 J-0.3095
    N1972 G17 G02 X-0.9693 Y0.3882 I-0.4317 J0.2068
    N1973 G17 G02 X-0.9771 Y0.3715 I-0.9614 J0.4386
    N1974 G17 G03 X-1.0042 Y0.3032 I0.8464 J-0.3758
    N1975 G17 G03 X-1.0108 Y0.286 I0.1227 J-0.057
    N1976 G17 G03 X-1.017 Y0.2686 I0.1335 J-0.0573
    N1977 G17 G03 X-1.0228 Y0.2511 I0.1456 J-0.0578
    N1978 G17 G03 X-1.0282 Y0.2334 I0.155 J-0.0573
    N1979 G17 G03 X-1.036 Y0.2068 I0.27 J-0.0935
    N1980 G17 G03 X-1.0406 Y0.1889 I0.1885 J-0.058
    N1981 G17 G03 X-1.0449 Y0.1709 I0.18 J-0.0521
    N1982 G17 G03 X-1.0489 Y0.1528 I0.1755 J-0.0478
    N1983 G17 G03 X-1.0525 Y0.1347 I0.159 J-0.0412
    N1984 G17 G03 X-1.0558 Y0.1164 I0.144 J-0.0356
    N1985 G01 X-1.0595 Y0.0982
    N1986 G17 G03 X-1.0666 Y0.0244 I1.9968 J-0.2276
    N1987 G17 G02 X-1.0684 Y-0.0035 I-0.8532 J0.0418
    N1988 G17 G02 X-1.0693 Y-0.022 I-0.2034 J0.0011
    N1989 G17 G03 X-1.0688 Y-0.0685 I1.2 J-0.0093
    N1990 G17 G03 X-1.0672 Y-0.1057 I0.392 J-0.0019
    N1991 G17 G02 X-1.0643 Y-0.1428 I-4.2268 J-0.3439
    N1992 G17 G02 X-1.0627 Y-0.1614 I-0.181 J-0.025
    N1993 G17 G03 X-1.0575 Y-0.1983 I1.3074 J0.1648
    N1994 G17 G03 X-1.0548 Y-0.2167 I0.1662 J0.0153
    N1995 G17 G03 X-1.0495 Y-0.2442 I2.1424 J0.3962
    N1996 G17 G03 X-1.0438 Y-0.2716 I0.2852 J0.0456
    N1997 G17 G02 X-1.0373 Y-0.2988 I-4.3123 J-1.0415
    N1998 G17 G02 X-1.0249 Y-0.3439 I-5.9004 J-1.6497
    N1999 G17 G03 X-1.0162 Y-0.3705 I1.2896 J0.405
    N2000 G17 G03 X-1.0105 Y-0.3883 I0.1589 J0.0415
    N2001 G17 G02 X-1.0042 Y-0.406 I-1.1488 J-0.4166
    N2002 G17 G03 X-0.9904 Y-0.4407 I1.318 J0.5054
    N2003 G17 G03 X-0.9835 Y-0.4581 I0.1421 J0.046
    N2004 G17 G02 X-0.9762 Y-0.4754 I-0.3382 J-0.154
    N2005 G17 G02 X-0.9643 Y-0.5008 I-1.5413 J-0.7347
    N2006 G17 G03 X-0.8506 Y-0.6837 I0.9749 J0.479
    N2007 G17 G03 X-0.8334 Y-0.706 I0.5301 J0.3923
    N2008 G17 G03 X-0.8157 Y-0.728 I0.3013 J0.2247
    N2009 G17 G03 X-0.8037 Y-0.7424 I0.1525 J0.1147
    N2010 G17 G03 X-0.7848 Y-0.7633 I0.7543 J0.6635
    N2011 G17 G03 X-0.7654 Y-0.7839 I0.2965 J0.2602
    N2012 G17 G03 X-0.7524 Y-0.7975 I0.1345 J0.1152
    N2013 G01 X-0.7253 Y-0.8236
    N2014 G17 G03 X-0.6828 Y-0.8609 I1.0359 J1.1395
    N2015 G01 X-0.6536 Y-0.8846
    N2016 G17 G03 X-0.6309 Y-0.9015 I11.945 J15.9775
    N2017 G17 G03 X-0.6081 Y-0.9183 I0.2313 J0.292
    N2018 G17 G02 X-0.5849 Y-0.9344 I-0.3085 J-0.4689
    N2019 G17 G03 X-0.5449 Y-0.9595 I0.4576 J0.6844
    N2020 G17 G03 X-0.4875 Y-0.9922 I0.3459 J0.5405
    N2021 G17 G03 X-0.4709 Y-1.0012 I0.0851 J0.1372
    N2022 G17 G03 X-0.4455 Y-1.0139 I0.2137 J0.3966
    N2023 G17 G03 X-0.3935 Y-1.0364 I0.3748 J0.7926
    N2024 G17 G03 X-0.376 Y-1.0438 I0.0718 J0.1463
    N2025 G17 G03 X-0.3584 Y-1.0507 I0.0794 J0.1767
    N2026 G17 G03 X-0.3406 Y-1.0572 I0.0862 J0.2077
    N2027 G17 G03 X-0.2592 Y-1.0822 I0.2752 J0.7519
    N2028 G17 G03 X-0.1385 Y-1.1065 I0.3012 J1.1831
    N2029 G17 G03 X-0.1104 Y-1.1106 I0.2787 J1.8172
    N2030 G17 G02 X-0.0916 Y-1.1129 I-0.0378 J-0.3826
    N2031 G17 G02 X-0.0727 Y-1.115 I-0.0198 J-0.2665
    N2032 G17 G02 X-0.0538 Y-1.1168 I-0.0095 J-0.1973
    N2033 G17 G03 X0.0126 Y-1.1191 I0.1558 J3.5551
    N2034 G17 G02 X0.0316 Y-1.1194 I0.0057 J-0.2918
    N2035 G17 G02 X0.0506 Y-1.1194 I0.0087 J-0.1884
    N2036 G17 G03 X0.098 Y-1.1171 I-0.4767 J10.067
    N2037 G17 G02 X0.1169 Y-1.1158 I0.0369 J-0.407
    N2038 G17 G03 X0.1641 Y-1.1105 I-0.1446 J1.4846
    N2039 G17 G03 X0.1924 Y-1.1067 I-0.022 J0.2736
    N2040 G17 G02 X0.2205 Y-1.1022 I0.2453 J-1.4328
    N2041 G17 G03 X0.2855 Y-1.0879 I-0.2302 J1.202
    N2042 G17 G03 X0.3405 Y-1.0727 I-0.2207 J0.9049
    N2043 G17 G03 X0.3677 Y-1.0642 I-0.0934 J0.3502
    N2044 G01 X0.3857 Y-1.0581
    N2045 G17 G03 X0.4127 Y-1.0487 I-0.077 J0.263
    N2046 G17 G03 X0.4741 Y-1.0232 I-0.2853 J0.7742
    N2047 G17 G03 X0.5425 Y-0.9899 I-0.3269 J0.7588
    N2048 G17 G03 X0.5595 Y-0.9813 I-0.0608 J0.1409
    N2049 G17 G02 X0.5763 Y-0.9723 I0.1334 J-0.2292
    N2050 G17 G02 X0.6011 Y-0.958 I0.3184 J-0.5231
    N2051 G17 G02 X0.6254 Y-0.9431 I0.3769 J-0.5877
    N2052 G17 G02 X0.6494 Y-0.9275 I0.3905 J-0.5763
    N2053 G17 G02 X0.673 Y-0.9114 I0.3681 J-0.5134
    N2054 G17 G03 X0.7478 Y-0.8525 I-0.8515 J1.1586
    N2055 G17 G03 X0.7972 Y-0.8076 I-0.6261 J0.7379
    N2056 G17 G03 X0.8176 Y-0.7877 I-0.3258 J0.3534
    N2057 G17 G03 X0.8377 Y-0.7673 I-0.2072 J0.2247
    N2058 G17 G03 X0.8634 Y-0.7392 I-0.8722 J0.8257
    N2059 G17 G03 X0.9059 Y-0.6877 I-0.8002 J0.7033
    N2060 G17 G03 X0.9289 Y-0.6574 I-0.3947 J0.3232
    N2061 G17 G02 X0.9402 Y-0.642 I0.5891 J-0.4213
    N2062 G17 G03 X0.9819 Y-0.5781 I-1.1109 J0.7705
    N2063 G17 G02 X0.9968 Y-0.5536 I0.456 J-0.2598
    N2064 G17 G03 X1.024 Y-0.5033 I-0.8232 J0.4779
    N2065 G17 G03 X1.0329 Y-0.4864 I-0.1424 J0.086
    N2066 G17 G03 X1.0414 Y-0.4693 I-0.2157 J0.1175
    N2067 G17 G03 X1.0712 Y-0.399 I-0.7781 J0.3717
    N2068 G17 G02 X1.0784 Y-0.3813 I2.9211 J-1.176
    N2069 G17 G02 X1.0851 Y-0.3634 I0.9389 J-0.339
    N2070 G17 G03 X1.1293 Y-0.1974 I-1.01 J0.3578
    N2071 G17 G03 X1.141 Y-0.1219 I-1.1694 J0.2202
    N2072 G17 G03 X1.1433 Y-0.1029 I-0.3497 J0.0517
    N2073 G17 G03 X1.1453 Y-0.0839 I-0.2521 J0.0368
    N2074 G17 G03 X1.1471 Y-0.0649 I-0.204 J0.0291
    N2075 G17 G03 X1.1492 Y-0.0362 I-0.2598 J0.033
    N2076 G17 G03 X1.1503 Y0.0211 I-1.3434 J0.0541
    N2077 G17 G03 X1.1503 Y0.0403 I-0.2298 J0.0097
    N2078 G17 G03 X1.1501 Y0.0594 I-0.1647 J0.0083
    N2079 G17 G03 X1.1471 Y0.1072 I-1.5393 J-0.0734
    N2080 G17 G03 X1.1447 Y0.1358 I-0.3061 J-0.0117
    N2081 G17 G03 X1.1412 Y0.1643 I-1.5065 J-0.1664
    N2082 G17 G03 X1.1374 Y0.1928 I-0.3142 J-0.0282
    N2083 G17 G02 X1.1327 Y0.2211 I2.1437 J0.368
    N2084 G17 G02 X1.1296 Y0.24 I0.2033 J0.0434
    N2085 G17 G03 X1.1194 Y0.2868 I-17.8364 J-3.8449
    N2086 G17 G03 X1.1122 Y0.3146 I-2.5696 J-0.6558
    N2087 G17 G03 X1.1047 Y0.3424 I-0.295 J-0.0645
    N2088 G17 G03 X1.0991 Y0.3608 I-0.6587 J-0.1897
    N2089 G17 G03 X1.0936 Y0.3791 I-0.1566 J-0.0367
    N2090 G17 G03 X1.0776 Y0.4243 I-0.8013 J-0.2594
    N2091 G17 G03 X1.0601 Y0.469 I-0.6206 J-0.2164
    N2092 G17 G03 X1.053 Y0.4868 I-0.1518 J-0.0504
    N2093 G17 G02 X1.0454 Y0.5045 I0.3786 J0.1729
    N2094 G17 G02 X1.0332 Y0.5306 I5.4576 J2.5639
    N2095 G17 G03 X1.002 Y0.5902 I-1.1545 J-0.5679
    N2096 G17 G03 X0.9927 Y0.607 I-0.295 J-0.1521
    N2097 G17 G03 X0.9633 Y0.6567 I-0.7799 J-0.4283
    N2098 G17 G03 X0.9314 Y0.7048 I-0.8662 J-0.5388
    N2099 G17 G03 X0.9146 Y0.7284 I-0.4229 J-0.2835
    N2100 G17 G03 X0.8973 Y0.7516 I-0.3356 J-0.2313
    N2101 G17 G03 X0.8794 Y0.7744 I-0.2425 J-0.1723
    N2102 G17 G03 X0.8674 Y0.7895 I-0.1358 J-0.0953
    N2103 G17 G03 X0.8225 Y0.8402 I-2.0206 J-1.7474
    N2104 G17 G03 X0.7817 Y0.8814 I-0.9536 J-0.9039
    N2105 G17 G03 X0.7607 Y0.9015 I-0.2812 J-0.2722
    N2106 G17 G03 X0.7467 Y0.9149 I-0.1353 J-0.1276
    N2107 G17 G02 X0.7177 Y0.9408 I13.9122 J15.6367
    N2108 G17 G03 X0.6951 Y0.9591 I-12.6165 J-15.4903
    N2109 G17 G03 X0.6723 Y0.9774 I-0.2397 J-0.2759
    N2110 G17 G02 X0.6491 Y0.9951 I0.6453 J0.8707
    N2111 G17 G02 X0.6174 Y1.0177 I1.1446 J1.6385
    N2112 G17 G03 X0.5848 Y1.0391 I-0.7651 J-1.1265
    N2113 G17 G03 X0.5685 Y1.0499 I-0.0982 J-0.1304
    N2114 G17 G03 X0.535 Y1.07 I-0.2973 J-0.4584
    N2115 G17 G03 X0.5181 Y1.0798 I-0.1365 J-0.2161
    N2116 G17 G03 X0.4749 Y1.1028 I-0.3383 J-0.5823
    N2117 G17 G03 X0.4573 Y1.1113 I-0.052 J-0.0854
    N2118 G17 G03 X0.4606 Y1.1099 I-0.4506 J-1.1049
    N2119 G01 X0.4483 Y1.1253
    N2120 G01 X0.4447 Y1.1446
    N2121 G01 X0.4429 Y1.1642
    N2122 G01 X0.4327 Y1.181
    N2123 G01 X0.4167 Y1.1926
    N2124 G01 X0.3979 Y1.1983
    N2125 G01 X0.3948 Y1.2
    N2126 G01 X-0.747
    N2127 G17 G03 X-0.8022 Y1.1791 I0.2837 J-0.8307
    N2128 G01 X-0.8376 Y1.1619
    N2129 G17 G03 X-0.8891 Y1.1329 I0.3099 J-0.6104
    N2130 G17 G03 X-0.9544 Y1.0891 I0.7897 J-1.2484
    N2131 G17 G03 X-0.9857 Y1.0652 I0.4448 J-0.6141
    N2132 G17 G03 X-1.0737 Y0.9864 I0.8716 J-1.0613
    N2133 G01 X-1.1013 Y0.9583
    N2134 G01 X-1.1147 Y0.9439
    N2135 G01 X-1.1534 Y0.8993
    N2136 G01 X-1.1659 Y0.8841
    N2137 G01 X-1.1898 Y0.8528
    N2138 G01 X-1.1972 Y0.8346
    N2139 G01 X-1.2 Y0.8293
    N2140 G01 Y-0.7258
    N2141 G01 X-1.1868 Y-0.7629
    N2142 G17 G03 X-1.1547 Y-0.8347 I0.6131 J0.2305
    N2143 G01 X-1.1359 Y-0.8693
    N2144 G17 G03 X-1.1156 Y-0.903 I0.6587 J0.3755
    N2145 G17 G03 X-1.0707 Y-0.9677 I1.236 J0.809
    N2146 G17 G03 X-1.0203 Y-1.0281 I0.6211 J0.4673
    N2147 G01 X-1.0076 Y-1.0432
    N2148 G01 X-0.9804 Y-1.0717
    N2149 G01 X-0.9664 Y-1.0855
    N2150 G01 X-0.9231 Y-1.1256
    N2151 G01 X-0.9082 Y-1.1386
    N2152 G17 G03 X-0.8465 Y-1.1874 I0.947 J1.1337
    N2153 G17 G02 X-0.8214 Y-1.2 I-0.1923 J-0.4131
    N2154 G01 X0.7337
    N2155 G17 G03 X0.8074 Y-1.1725 I-0.1919 J0.6262
    N2156 G01 X0.8431 Y-1.1559
    N2157 G17 G03 X0.895 Y-1.1277 I-0.3004 J0.6151
    N2158 G01 X0.9283 Y-1.1068
    N2159 G17 G03 X0.9923 Y-1.0609 I-0.6152 J0.9261
    N2160 G01 X1.0076 Y-1.0485
    N2161 G01 X1.0522 Y-1.0098
    N2162 G01 X1.0666 Y-0.9964
    N2163 G17 G03 X1.1482 Y-0.911 I-0.9514 J0.9904
    N2164 G01 X1.1609 Y-0.896
    N2165 G01 X1.1853 Y-0.8651
    N2166 G01 X1.2 Y-0.8386
    N2167 G01 Y0.7559
    N2168 G01 X1.1868 Y0.7929
    N2169 G01 X1.1796 Y0.8113
    N2170 G01 X1.163 Y0.847
    N2171 G17 G03 X1.1448 Y0.8819 I-0.6808 J-0.3338
    N2172 G01 X1.1249 Y0.9159
    N2173 G01 X1.103 Y0.9486
    N2174 G01 X1.0915 Y0.9646
    N2175 G17 G03 X1.0169 Y1.0561 I-1.1007 J-0.8212
    N2176 G17 G03 X0.9617 Y1.1122 I-0.8197 J-0.7512
    N2177 G01 X0.9178 Y1.1516
    N2178 G01 X0.9027 Y1.1643
    N2179 G01 X0.8718 Y1.1887
    N2180 G01 X0.8538 Y1.1967
    N2181 G01 X0.8477 Y1.2
    N2182 G01 X0.3752
    N2183 G01 X0.3687 Y1.1995 Z-0.7499
    N2184 G01 X0.3624 Y1.1978 Z-0.7497
    N2185 G01 X0.3564 Y1.1952 Z-0.7495
    N2186 G01 X0.3509 Y1.1916 Z-0.7492
    N2187 G01 X0.3461 Y1.1871 Z-0.7487
    N2188 G01 X0.3421 Y1.1819 Z-0.7477
    N2189 G01 X0.339 Y1.1761 Z-0.7455
    N2190 G01 X0.337 Y1.1699 Z-0.7402
    N2191 G01 X0.336 Y1.1634 Z-0.7348
    N2192 G01 X0.336 Y1.1569 Z-0.7326
    N2193 G01 X0.3372 Y1.1504 Z-0.7317
    N2194 G01 X0.3394 Y1.1443 Z-0.7311
    N2195 G01 X0.3426 Y1.1386 Z-0.7308
    N2196 G01 X0.3468 Y1.1335 Z-0.7306
    N2197 G01 X0.3517 Y1.1291 Z-0.7304
    N2198 G01 X0.3572 Y1.1256 Z-0.7303
    N2199 G01 X1.1426 Y0.7209
    N2200 G01 X1.1488 Y0.7183 Z-0.7305
    N2201 G01 X1.1553 Y0.7168 Z-0.7307
    N2202 G01 X1.162 Y0.7165 Z-0.7311
    N2203 G01 X1.1687 Y0.7173 Z-0.7319
    N2204 G01 X1.1751 Y0.7192 Z-0.7338
    N2205 G01 X1.1811 Y0.7222 Z-0.7402
    N2206 G01 X1.1865 Y0.7262 Z-0.7465
    N2207 G01 X1.1912 Y0.731 Z-0.7484
    N2208 G01 X1.195 Y0.7366 Z-0.7492
    N2209 G01 X1.1977 Y0.7427 Z-0.7496
    N2210 G01 X1.1994 Y0.7492 Z-0.7498
    N2211 G01 X1.2 Y0.7559 Z-0.75
    N2212 G01 Y1.1299
    N2213 G17 G03 X1.1857 Y1.1665 I-0.3506 J-0.1161
    N2214 G01 X1.1746 Y1.1828
    N2215 G01 X1.1581 Y1.1936
    N2216 G01 X1.1391 Y1.1987
    N2217 G01 X1.1366 Y1.2
    N2218 G01 X0.8413
    N2219 G01 X0.8347 Y1.1994 Z-0.7499
    N2220 G01 X0.8283 Y1.1978 Z-0.7498
    N2221 G01 X0.8222 Y1.195 Z-0.7496
    N2222 G01 X0.8167 Y1.1913 Z-0.7493
    N2223 G01 X0.8119 Y1.1867 Z-0.749
    N2224 G01 X0.8079 Y1.1814 Z-0.7484
    N2225 G01 X0.8049 Y1.1755 Z-0.7474
    N2226 G01 X0.8029 Y1.1691 Z-0.7451
    N2227 G01 X0.802 Y1.1625 Z-0.7402
    N2228 G01 X0.8023 Y1.1559 Z-0.7352
    N2229 G01 X0.8036 Y1.1494 Z-0.733
    N2230 G01 X0.8061 Y1.1432 Z-0.7319
    N2231 G01 X0.8095 Y1.1375 Z-0.7313
    N2232 G01 X0.8139 Y1.1324 Z-0.731
    N2233 G01 X0.819 Y1.1282 Z-0.7307
    N2234 G01 X0.8248 Y1.1249 Z-0.7306
    N2235 G01 X0.831 Y1.1226 Z-0.7304
    N2236 G01 X0.8376 Y1.1214 Z-0.7303
    N2237 G01 X1.1569 Y1.0907
    N2238 G01 X1.1634 Y1.0906 Z-0.7305
    N2239 G01 X1.1699 Y1.0916 Z-0.7309
    N2240 G01 X1.1761 Y1.0937 Z-0.7315
    N2241 G01 X1.1819 Y1.0967 Z-0.7333
    N2242 G01 X1.1871 Y1.1007 Z-0.7402
    N2243 G01 X1.1916 Y1.1055 Z-0.747
    N2244 G01 X1.1952 Y1.111 Z-0.7488
    N2245 G01 X1.1978 Y1.117 Z-0.7494
    N2246 G01 X1.1995 Y1.1233 Z-0.7498
    N2247 G01 X1.2 Y1.1299 Z-0.75
    N2248 G17 G03 X1.1998 Y1.1551 I-0.6238 J0.008
    N2249 G17 G03 X1.1508 Y1.2 I-0.0491 J-0.0044
    N2250 G01 X1.1311
    N2251 G01 X0.5051 Z-0.7303
    N2252 G01 X-0.121
    N2253 G01 X-0.747 Z-0.75
    N2254 G01 X-1.1013
    N2255 G17 G03 X-1.1569 Y1.1802 I0.2015 J-0.6542
    N2256 G01 X-1.1748 Y1.1719
    N2257 G01 X-1.1886 Y1.1579
    N2258 G01 X-1.1966 Y1.1399
    N2259 G01 X-1.2 Y1.1337
    N2260 G01 Y0.8187
    N2261 G01 X-1.1995 Y0.8122 Z-0.7499
    N2262 G01 X-1.1979 Y0.806 Z-0.7498
    N2263 G01 X-1.1953 Y0.8 Z-0.7496
    N2264 G01 X-1.1917 Y0.7946 Z-0.7493
    N2265 G01 X-1.1873 Y0.7898 Z-0.749
    N2266 G01 X-1.1822 Y0.7858 Z-0.7484
    N2267 G01 X-1.1765 Y0.7827 Z-0.7474
    N2268 G01 X-1.1704 Y0.7806 Z-0.7451
    N2269 G01 X-1.164 Y0.7795 Z-0.7402
    N2270 G01 X-1.1575 Z-0.7352
    N2271 G01 X-1.1511 Y0.7805 Z-0.733
    N2272 G01 X-1.145 Y0.7826 Z-0.7319
    N2273 G01 X-1.1392 Y0.7857 Z-0.7313
    N2274 G01 X-1.1341 Y0.7896 Z-0.731
    N2275 G01 X-1.1297 Y0.7944 Z-0.7307
    N2276 G01 X-1.1261 Y0.7998 Z-0.7306
    N2277 G01 X-1.1235 Y0.8057 Z-0.7304
    N2278 G01 X-1.1218 Y0.812 Z-0.7303
    N2279 G01 X-1.0625 Y1.1539
    N2280 G01 X-1.0619 Y1.1607 Z-0.7305
    N2281 G01 X-1.0626 Y1.1676 Z-0.7309
    N2282 G01 X-1.0643 Y1.1742 Z-0.7315
    N2283 G01 X-1.0672 Y1.1804 Z-0.7333
    N2284 G01 X-1.0712 Y1.186 Z-0.7402
    N2285 G01 X-1.076 Y1.1908 Z-0.747
    N2286 G01 X-1.0817 Y1.1947 Z-0.7488
    N2287 G01 X-1.0879 Y1.1976 Z-0.7494
    N2288 G01 X-1.0945 Y1.1994 Z-0.7498
    N2289 G01 X-1.1013 Y1.2 Z-0.75
    N2290 G01 X-1.1508
    N2291 G17 G03 X-1.2 Y1.1508 I0.0001 J-0.0493
    N2292 G01 Y1.1311
    N2293 G01 Y-0.7258
    N2294 G01 Y-1.0998
    N2295 G01 X-1.1868 Y-1.1369
    N2296 G17 G03 X-1.1702 Y-1.1726 I0.3427 J0.1376
    N2297 G01 X-1.157 Y-1.1871
    N2298 G17 G02 X-1.1317 Y-1.2 I-0.2479 J-0.5168
    N2299 G01 X-0.8168
    N2300 G01 X-0.81 Y-1.1994 Z-0.7499
    N2301 G01 X-0.8033 Y-1.1976 Z-0.7497
    N2302 G01 X-0.7971 Y-1.1947 Z-0.7495
    N2303 G01 X-0.7915 Y-1.1908 Z-0.7493
    N2304 G01 X-0.7866 Y-1.1859 Z-0.7488
    N2305 G01 X-0.7827 Y-1.1803 Z-0.7481
    N2306 G01 X-0.7798 Y-1.1741 Z-0.7467
    N2307 G01 X-0.778 Y-1.1675 Z-0.7432
    N2308 G01 X-0.7774 Y-1.1606 Z-0.7372
    N2309 G01 X-0.778 Y-1.1538 Z-0.7337
    N2310 G01 X-0.7798 Y-1.1472 Z-0.7322
    N2311 G01 X-0.7827 Y-1.141 Z-0.7315
    N2312 G01 X-0.7866 Y-1.1353 Z-0.731
    N2313 G01 X-0.7915 Y-1.1305 Z-0.7308
    N2314 G01 X-0.7971 Y-1.1265 Z-0.7306
    N2315 G01 X-0.8033 Y-1.1236 Z-0.7304
    N2316 G01 X-0.8099 Y-1.1219 Z-0.7303
    N2317 G01 X-1.1538 Y-1.061
    N2318 G01 X-1.16 Y-1.0604 Z-0.7305
    N2319 G01 X-1.1662 Y-1.0608 Z-0.7308
    N2320 G01 X-1.1723 Y-1.0622 Z-0.7313
    N2321 G01 X-1.1781 Y-1.0645 Z-0.7324
    N2322 G01 X-1.1835 Y-1.0677 Z-0.7359
    N2323 G01 X-1.1882 Y-1.0717 Z-0.7444
    N2324 G01 X-1.1923 Y-1.0765 Z-0.7479
    N2325 G01 X-1.1956 Y-1.0818 Z-0.749
    N2326 G01 X-1.198 Y-1.0875 Z-0.7495
    N2327 G01 X-1.1995 Y-1.0936 Z-0.7498
    N2328 G01 X-1.2 Y-1.0998 Z-0.75
    N2329 G01 Y-1.1508
    N2330 G17 G03 X-1.1508 Y-1.2 I0.0493 J0.0001
    N2331 G01 X-1.1311
    N2332 G01 X0.7337
    N2333 G01 X1.1077
    N2334 G17 G03 X1.145 Y-1.1874 I-0.2244 J0.7243
    N2335 G01 X1.1631 Y-1.1796
    N2336 G01 X1.1802 Y-1.1699
    N2337 G01 X1.192 Y-1.1542
    N2338 G01 X1.1981 Y-1.1354
    N2339 G01 X1.2 Y-1.1319
    N2340 G01 Y-0.8366
    N2341 G01 X1.1995 Y-0.8302 Z-0.7499
    N2342 G01 X1.1979 Y-0.8238 Z-0.7498
    N2343 G01 X1.1952 Y-0.8179 Z-0.7496
    N2344 G01 X1.1917 Y-0.8124 Z-0.7493
    N2345 G01 X1.1873 Y-0.8077 Z-0.749
    N2346 G01 X1.1821 Y-0.8037 Z-0.7484
    N2347 G01 X1.1764 Y-0.8006 Z-0.7474
    N2348 G01 X1.1702 Y-0.7985 Z-0.7451
    N2349 G01 X1.1638 Y-0.7974 Z-0.7402
    N2350 G01 X1.1573 Z-0.7352
    N2351 G01 X1.1509 Y-0.7985 Z-0.733
    N2352 G01 X1.1447 Y-0.8006 Z-0.7319
    N2353 G01 X1.139 Y-0.8037 Z-0.7313
    N2354 G01 X1.1339 Y-0.8077 Z-0.731
    N2355 G01 X1.1295 Y-0.8125 Z-0.7307
    N2356 G01 X1.1259 Y-0.818 Z-0.7306
    N2357 G01 X1.1234 Y-0.824 Z-0.7304
    N2358 G01 X1.1218 Y-0.8303 Z-0.7303
    N2359 G01 X1.0688 Y-1.1543
    N2360 G01 X1.0683 Y-1.1611 Z-0.7305
    N2361 G01 X1.069 Y-1.1679 Z-0.7309
    N2362 G01 X1.0708 Y-1.1744 Z-0.7315
    N2363 G01 X1.0737 Y-1.1806 Z-0.7333
    N2364 G01 X1.0777 Y-1.1861 Z-0.7402
    N2365 G01 X1.0825 Y-1.1909 Z-0.747
    N2366 G01 X1.0881 Y-1.1948 Z-0.7488
    N2367 G01 X1.0943 Y-1.1977 Z-0.7494
    N2368 G01 X1.1009 Y-1.1994 Z-0.7498
    N2369 G01 X1.1077 Y-1.2 Z-0.75
    N2370 G01 X1.1508
    N2371 G17 G03 X1.2 Y-1.1508 I-0.0001 J0.0493
    N2372 G01 Y-1.1311
    N2373 G17 G03 X1.1885 Y-1.1033 I-0.0397 J-0.0001
    N2374 G00 Z-0.4
    N2375 G00 Z0.1
    N2376 G00 X-0.1183 Y0.0064
    N2377 G00 Z-0.65
    N2378 G01 Z-1. F44.6296 <<<<<<<<<<<<<<<<<<<<<<<< Z Feed Move
    N2379 G17 G03 X0.1132 Y0.0719 I0.125 J0. F89.2592
    N2380 G17 G03 X0.0729 Y0.1226 I-0.2091 J-0.1248
    N2381 G17 G03 X0.0463 Y0.1458 I-0.1884 J-0.1898
    N2382 G17 G03 X0.0277 Y0.1589 I-0.1122 J-0.139
    N2383 G17 G03 X-0.0161 Y0.1798 I-0.1261 J-0.2078
    N2384 G17 G03 X-0.0409 Y0.1869 I-0.059 J-0.1599
    N2385 G17 G03 X-0.0719 Y0.1915 I-0.0385 J-0.1511
    N2386 G17 G03 X-0.1042 Y0.1916 I-0.0162 J-0.1609
    N2387 G17 G03 X-0.1227 Y0.1891 I0.0156 J-0.1907
    N2388 G17 G03 X-0.1886 Y0.1636 I0.0251 J-0.1625
    N2389 G17 G03 X-0.2325 Y0.1267 I0.1375 J-0.2085
    N2390 G01 X-0.2422 Y0.1158
    N2391 G17 G03 X-0.2611 Y0.0876 I0.3169 J-0.2331
    N2392 G17 G03 X-0.2757 Y0.0568 I0.4395 J-0.2281
    N2393 G17 G03 X-0.2848 Y0.0288 I0.4884 J-0.1726
    N2394 G17 G03 X-0.2898 Y0.0046 I6.551 J-1.3943
    N2395 G01 X-0.2921 Y-0.0151
    N2396 G01 X-0.2928 Y-0.0399
    N2397 G01 X-0.2916 Y-0.0598
    N2398 G17 G03 X-0.2869 Y-0.0893 I0.2682 J0.0279
    N2399 G17 G03 X-0.2791 Y-0.1184 I0.1561 J0.0261
    N2400 G17 G03 X-0.2705 Y-0.142 I0.2302 J0.0707
    N2401 G17 G03 X-0.2596 Y-0.1648 I2.6951 J1.2685
    N2402 G01 X-0.2522 Y-0.1781
    N2403 G17 G03 X-0.2151 Y-0.2262 I0.241 J0.1477
    N2404 G17 G03 X-0.1431 Y-0.2824 I0.2491 J0.2448
    N2405 G17 G03 X-0.1253 Y-0.2925 I0.3567 J0.6078
    N2406 G17 G03 X-0.0777 Y-0.3115 I0.2127 J0.463
    N2407 G01 X-0.0528 Y-0.318
    N2408 G17 G02 X-0.0428 Y-0.3202 I-0.0281 J-0.1555
    N2409 G17 G03 X-0.0122 Y-0.3247 I0.5747 J3.8199
    N2410 G01 X0.0136 Y-0.3261
    N2411 G17 G03 X0.0394 Y-0.3253 I-0.0027 J0.5093
    N2412 G01 X0.06 Y-0.3233
    N2413 G01 X0.0855 Y-0.319
    N2414 G17 G02 X0.1056 Y-0.3139 I0.2344 J-0.8799
    N2415 G17 G03 X0.1349 Y-0.3037 I-0.0816 J0.2832
    N2416 G17 G03 X0.154 Y-0.2956 I-0.0804 J0.2154
    N2417 G17 G03 X0.1724 Y-0.286 I-0.121 J0.2553
    N2418 G17 G03 X0.186 Y-0.2784 I-0.0605 J0.1241
    N2419 G17 G03 X0.2034 Y-0.2672 I-0.1073 J0.1851
    N2420 G17 G03 X0.2433 Y-0.2339 I-0.2093 J0.291
    N2421 G17 G03 X0.2544 Y-0.223 I-0.0791 J0.0916
    N2422 G17 G03 X0.2784 Y-0.1957 I-0.1714 J0.1754
    N2423 G17 G03 X0.2936 Y-0.1745 I-0.1201 J0.1024
    N2424 G17 G03 X0.3246 Y-0.1143 I-0.3699 J0.2281
    N2425 G17 G03 X0.3374 Y-0.0746 I-0.5271 J0.1922
    N2426 G17 G03 X0.3457 Y-0.0284 I-0.3439 J0.0858
    N2427 G17 G03 X0.3478 Y-0.0024 I-0.3582 J0.0419
    N2428 G17 G03 X0.3461 Y0.0446 I-0.3421 J0.0107
    N2429 G17 G03 X0.3426 Y0.0705 I-0.194 J-0.013
    N2430 G17 G03 X0.3397 Y0.0859 I-0.1352 J-0.0171
    N2431 G17 G02 X0.3363 Y0.1013 I0.4939 J0.1185
    N2432 G17 G03 X0.3254 Y0.1363 I-0.3981 J-0.1041
    N2433 G17 G03 X0.3179 Y0.156 I-0.1971 J-0.0638
    N2434 G17 G03 X0.3024 Y0.1895 I-0.2174 J-0.0806
    N2435 G01 X0.295 Y0.2036
    N2436 G17 G03 X0.275 Y0.235 I-0.6641 J-0.401
    N2437 G17 G03 X0.2523 Y0.265 I-0.235 J-0.1545
    N2438 G17 G03 X0.2312 Y0.2897 I-0.192 J-0.1423
    N2439 G17 G03 X0.195 Y0.323 I-0.2555 J-0.2419
    N2440 G17 G03 X0.1865 Y0.3302 I-0.0548 J-0.0555
    N2441 G17 G03 X0.169 Y0.3438 I-0.1286 J-0.1479
    N2442 G17 G03 X0.1553 Y0.3537 I-0.087 J-0.1058
    N2443 G17 G03 X0.1364 Y0.3659 I-0.1274 J-0.1764
    N2444 G17 G03 X0.1217 Y0.3745 I-0.0834 J-0.1247
    N2445 G17 G03 X0.1067 Y0.3827 I-0.0719 J-0.1154
    N2446 G17 G03 X0.0859 Y0.3924 I-0.0656 J-0.1128
    N2447 G17 G03 X0.0424 Y0.408 I-0.2621 J-0.6642
    N2448 G17 G02 X0.0199 Y0.4147 I0.1919 J0.6808
    N2449 G17 G03 X-0.0205 Y0.4226 I-0.3014 J-1.4314
    N2450 G17 G03 X-0.0619 Y0.4266 I-0.1514 J-1.3734
    N2451 G17 G03 X-0.0919 Y0.4265 I-0.0145 J-0.5171
    N2452 G17 G03 X-0.1161 Y0.4257 I-0.0065 J-0.1698
    N2453 G17 G03 X-0.1402 Y0.4232 I0.0079 J-0.1918
    N2454 G17 G03 X-0.1702 Y0.4178 I0.0345 J-0.2796
    N2455 G17 G03 X-0.2235 Y0.4029 I0.0884 J-0.4178
    N2456 G17 G03 X-0.2467 Y0.3943 I0.0949 J-0.2912
    N2457 G17 G03 X-0.2807 Y0.3787 I0.0818 J-0.2234
    N2458 G17 G03 X-0.308 Y0.3634 I0.1354 J-0.2747
    N2459 G17 G03 X-0.3241 Y0.3535 I0.0848 J-0.1557
    N2460 G17 G03 X-0.3446 Y0.3388 I0.1529 J-0.234
    N2461 G17 G03 X-0.3549 Y0.3313 I0.0432 J-0.0703
    N2462 G17 G03 X-0.3928 Y0.2975 I0.1827 J-0.2431
    N2463 G17 G02 X-0.4063 Y0.2839 I-4.0757 J4.0233
    N2464 G01 X-0.4192 Y0.2695
    N2465 G17 G03 X-0.4847 Y0.1665 I0.3493 J-0.2944
    N2466 G17 G03 X-0.5024 Y0.1245 I0.5336 J-0.2507
    N2467 G17 G03 X-0.5068 Y0.1122 I0.1478 J-0.0592
    N2468 G17 G03 X-0.513 Y0.0936 I0.1516 J-0.0608
    N2469 G17 G03 X-0.5182 Y0.0746 I0.1267 J-0.0447
    N2470 G17 G03 X-0.5251 Y0.0425 I1.2581 J-0.2883
    N2471 G17 G02 X-0.5274 Y0.0295 I-0.1688 J0.0228
    N2472 G17 G03 X-0.5311 Y-0.0098 I0.6106 J-0.0787
    N2473 G17 G03 X-0.5321 Y-0.0296 I0.1555 J-0.0173
    N2474 G17 G03 X-0.5322 Y-0.0494 I0.3056 J-0.0115
    N2475 G17 G03 X-0.5315 Y-0.0759 I0.17 J-0.0091
    N2476 G17 G03 X-0.5272 Y-0.1155 I0.3394 J0.0175
    N2477 G17 G02 X-0.5253 Y-0.1287 I-0.2199 J-0.0374
    N2478 G17 G02 X-0.5202 Y-0.1548 I-1.3025 J-0.2678
    N2479 G17 G02 X-0.5136 Y-0.1806 I-3.1403 J-0.8169
    N2480 G17 G03 X-0.5036 Y-0.2125 I1.0693 J0.3182
    N2481 G01 X-0.4942 Y-0.2376
    N2482 G17 G02 X-0.4861 Y-0.256 I-0.5356 J-0.245
    N2483 G17 G03 X-0.4642 Y-0.2974 I0.7466 J0.368
    N2484 G17 G02 X-0.4504 Y-0.3205 I-0.6891 J-0.4288
    N2485 G17 G03 X-0.4311 Y-0.3479 I0.5469 J0.3637
    N2486 G17 G03 X-0.4189 Y-0.364 I0.1625 J0.1104
    N2487 G17 G02 X-0.3973 Y-0.3898 I-16.1 J-13.5114
    N2488 G17 G03 X-0.3738 Y-0.414 I0.342 J0.3092
    N2489 G17 G03 X-0.3643 Y-0.4235 I0.0695 J0.0597
    N2490 G17 G03 X-0.3122 Y-0.4664 I0.2784 J0.2849
    N2491 G17 G03 X-0.3013 Y-0.4745 I0.0614 J0.0711
    N2492 G17 G03 X-0.2846 Y-0.4861 I0.1186 J0.1533
    N2493 G17 G03 X-0.2617 Y-0.5006 I0.2095 J0.3071
    N2494 G17 G03 X-0.2258 Y-0.5198 I0.274 J0.4693
    N2495 G17 G03 X-0.1884 Y-0.536 I0.4011 J0.8721
    N2496 G17 G02 X-0.1694 Y-0.5433 I-0.2739 J-0.7399
    N2497 G17 G02 X-0.1501 Y-0.5501 I-0.1452 J-0.4455
    N2498 G17 G02 X-0.1306 Y-0.5563 I-0.0856 J-0.303
    N2499 G17 G03 X-0.0706 Y-0.5689 I0.2752 J1.1604
    N2500 G17 G02 X-0.0504 Y-0.5722 I-0.0423 J-0.3185
    N2501 G17 G03 X-0.0096 Y-0.5757 I0.2447 J2.6537
    N2502 G17 G02 X0.004 Y-0.5764 I-0.0014 J-0.1586
    N2503 G01 X0.0314 Y-0.5763
    N2504 G17 G03 X0.0723 Y-0.5735 I-0.0736 J1.3605
    N2505 G17 G03 X0.0926 Y-0.5711 I-0.014 J0.2102
    N2506 G17 G03 X0.1129 Y-0.5679 I-0.106 J0.722
    N2507 G17 G03 X0.1331 Y-0.5642 I-0.0185 J0.1597
    N2508 G17 G03 X0.1664 Y-0.5565 I-0.0606 J0.337
    N2509 G17 G03 X0.1926 Y-0.5487 I-0.0833 J0.3282
    N2510 G17 G03 X0.2438 Y-0.5293 I-0.1558 J0.4882
    N2511 G17 G03 X0.2687 Y-0.5179 I-0.1452 J0.3488
    N2512 G17 G03 X0.2931 Y-0.5054 I-0.1716 J0.3674
    N2513 G17 G03 X0.317 Y-0.492 I-0.1103 J0.223
    N2514 G17 G03 X0.3345 Y-0.4812 I-0.0968 J0.1776
    N2515 G17 G03 X0.3627 Y-0.4618 I-2.7896 J4.0805
    N2516 G17 G03 X0.3949 Y-0.4361 I-1.0407 J1.3381
    N2517 G17 G03 X0.4201 Y-0.4128 I-0.3849 J0.4413
    N2518 G17 G03 X0.4348 Y-0.3983 I-0.1297 J0.1464
    N2519 G17 G03 X0.4622 Y-0.3676 I-0.3182 J0.3105
    N2520 G17 G03 X0.4753 Y-0.3517 I-0.1333 J0.1234
    N2521 G17 G03 X0.5105 Y-0.3009 I-0.355 J0.2845
    N2522 G01 X0.521 Y-0.2832
    N2523 G17 G03 X0.528 Y-0.2713 I-0.0934 J0.0631
    N2524 G17 G03 X0.538 Y-0.2533 I-0.1717 J0.1069
    N2525 G17 G03 X0.5474 Y-0.2349 I-0.1578 J0.0922
    N2526 G17 G03 X0.5561 Y-0.2161 I-0.1744 J0.0924
    N2527 G17 G03 X0.5641 Y-0.1971 I-0.1796 J0.0871
    N2528 G17 G03 X0.5733 Y-0.1711 I-0.2194 J0.0923
    N2529 G17 G03 X0.5918 Y-0.0976 I-0.7397 J0.2254
    N2530 G17 G03 X0.5944 Y-0.084 I-0.1947 J0.0433
    N2531 G17 G03 X0.5983 Y-0.0567 I-0.2319 J0.0473
    N2532 G01 X0.601 Y-0.0292
    N2533 G17 G02 X0.6021 Y-0.0155 I0.334 J-0.0181
    N2534 G17 G03 X0.6027 Y0.0329 I-2.9941 J0.0622
    N2535 G17 G03 X0.6002 Y0.0673 I-0.6619 J-0.0302
    N2536 G17 G03 X0.5973 Y0.0948 I-0.2746 J-0.0151
    N2537 G17 G03 X0.5953 Y0.1085 I-0.3917 J-0.0508
    N2538 G17 G03 X0.5918 Y0.1289 I-0.1674 J-0.018
    N2539 G01 X0.5877 Y0.1493
    N2540 G17 G03 X0.5728 Y0.2026 I-0.6104 J-0.1425
    N2541 G17 G03 X0.5642 Y0.229 I-0.2246 J-0.058
    N2542 G17 G03 X0.5545 Y0.255 I-0.2562 J-0.0816
    N2543 G17 G03 X0.5436 Y0.2806 I-0.2933 J-0.1097
    N2544 G17 G03 X0.5316 Y0.3057 I-0.2599 J-0.1089
    N2545 G17 G03 X0.5185 Y0.3303 I-0.2406 J-0.1113
    N2546 G17 G03 X0.5009 Y0.3605 I-0.2569 J-0.1302
    N2547 G17 G03 X0.4898 Y0.3783 I-0.1777 J-0.0987
    N2548 G17 G03 X0.4696 Y0.4069 I-8.5775 J-6.0245
    N2549 G17 G02 X0.4569 Y0.4238 I0.2502 J0.2018
    N2550 G17 G03 X0.4342 Y0.4507 I-0.5803 J-0.4653
    N2551 G17 G03 X0.4201 Y0.4665 I-0.1615 J-0.13
    N2552 G17 G03 X0.4052 Y0.4817 I-1.1281 J-1.0914
    N2553 G17 G03 X0.3692 Y0.5158 I-0.2607 J-0.2393
    N2554 G17 G03 X0.3585 Y0.5253 I-0.0806 J-0.0799
    N2555 G17 G03 X0.3248 Y0.5517 I-0.2322 J-0.261
    N2556 G17 G02 X0.3014 Y0.5683 I0.4797 J0.7044
    N2557 G01 X0.2834 Y0.5801
    N2558 G17 G03 X0.2202 Y0.6146 I-0.3235 J-0.5185
    N2559 G17 G03 X0.2072 Y0.6211 I-0.0507 J-0.0844
    N2560 G01 X0.1941 Y0.6277
    N2561 G17 G02 X0.1741 Y0.6366 I0.1482 J0.3558
    N2562 G17 G02 X0.1606 Y0.6421 I0.0781 J0.2123
    N2563 G17 G02 X0.14 Y0.6497 I0.1191 J0.3559
    N2564 G17 G02 X0.1192 Y0.657 I0.097 J0.3102
    N2565 G17 G02 X0.1052 Y0.6614 I0.0403 J0.1544
    N2566 G17 G03 X0.0405 Y0.6755 I-0.2798 J-1.1208
    N2567 G17 G02 X0.0186 Y0.6794 I0.1793 J1.0844
    N2568 G17 G02 X0.0039 Y0.6816 I0.0297 J0.249
    N2569 G17 G03 X-0.0405 Y0.6852 I-0.2664 J-2.9859
    N2570 G17 G02 X-0.0629 Y0.6865 I0.0349 J0.8298
    N2571 G17 G03 X-0.1151 Y0.6854 I-0.011 J-0.7208
    N2572 G17 G03 X-0.1302 Y0.6847 I-0.0028 J-0.107
    N2573 G17 G03 X-0.1526 Y0.6826 I0.032 J-0.4672
    N2574 G01 X-0.1677 Y0.6816
    N2575 G17 G03 X-0.1975 Y0.6769 I0.095 J-0.7029
    N2576 G17 G03 X-0.2198 Y0.6727 I0.0208 J-0.174
    N2577 G17 G03 X-0.2568 Y0.6641 I0.0709 J-0.3886
    N2578 G01 X-0.2714 Y0.66
    N2579 G17 G03 X-0.2933 Y0.6536 I0.0347 J-0.1593
    N2580 G17 G03 X-0.3223 Y0.6439 I0.094 J-0.3287
    N2581 G17 G03 X-0.3508 Y0.6328 I0.1404 J-0.4015
    N2582 G17 G03 X-0.3718 Y0.6234 I0.1153 J-0.2875
    N2583 G17 G03 X-0.4198 Y0.5992 I0.2676 J-0.5892
    N2584 G17 G03 X-0.4465 Y0.5836 I0.1468 J-0.2833
    N2585 G17 G03 X-0.4661 Y0.5712 I0.1201 J-0.2114
    N2586 G17 G02 X-0.4791 Y0.5629 I-0.0804 J0.1106
    N2587 G17 G03 X-0.5042 Y0.5446 I0.3433 J-0.4957
    N2588 G17 G03 X-0.5345 Y0.5203 I0.1932 J-0.2729
    N2589 G01 X-0.5522 Y0.505
    N2590 G17 G03 X-0.5802 Y0.478 I5.9927 J-6.23
    N2591 G17 G03 X-0.6067 Y0.4493 I1.0147 J-0.9628
    N2592 G17 G03 X-0.632 Y0.4193 I0.2831 J-0.2646
    N2593 G01 X-0.6511 Y0.3944
    N2594 G17 G03 X-0.6775 Y0.3553 I0.5063 J-0.3695
    N2595 G01 X-0.6863 Y0.3421
    N2596 G17 G02 X-0.6945 Y0.3286 I-0.4584 J0.2688
    N2597 G17 G03 X-0.7203 Y0.2796 I0.7248 J-0.4133
    N2598 G17 G03 X-0.766 Y0.153 I0.6755 J-0.3156
    N2599 G17 G03 X-0.7821 Y0.083 I0.9882 J-0.2628
    N2600 G17 G02 X-0.7863 Y0.0593 I-0.5844 J0.0936
    N2601 G17 G02 X-0.7888 Y0.0435 I-0.2055 J0.0232
    N2602 G17 G03 X-0.7926 Y-0.0044 I0.8035 J-0.0883
    N2603 G17 G03 X-0.794 Y-0.0285 I0.2479 J-0.0264
    N2604 G17 G03 X-0.7946 Y-0.0446 I0.1163 J-0.0123
    N2605 G17 G03 X-0.7941 Y-0.0687 I0.6285 J0.0004
    N2606 G17 G03 X-0.7928 Y-0.1009 I0.2518 J-0.0064
    N2607 G01 X-0.7908 Y-0.125
    N2608 G17 G02 X-0.7893 Y-0.141 I-0.1636 J-0.0241
    N2609 G17 G02 X-0.7846 Y-0.173 I-3.9309 J-0.5874
    N2610 G17 G02 X-0.7767 Y-0.2126 I-4.2414 J-0.8708
    N2611 G17 G03 X-0.7594 Y-0.2749 I0.6723 J0.1529
    N2612 G17 G03 X-0.7519 Y-0.298 I0.2534 J0.069
    N2613 G17 G03 X-0.7174 Y-0.3801 I0.6339 J0.2183
    N2614 G01 X-0.7102 Y-0.3946
    N2615 G17 G03 X-0.699 Y-0.4163 I0.1661 J0.0715
    N2616 G17 G03 X-0.6914 Y-0.4307 I0.1264 J0.0583
    N2617 G17 G03 X-0.6611 Y-0.4788 I0.6892 J0.3998
    N2618 G17 G03 X-0.6472 Y-0.4989 I0.273 J0.1733
    N2619 G17 G03 X-0.628 Y-0.5252 I0.2639 J0.1738
    N2620 G17 G03 X-0.6181 Y-0.5382 I0.1072 J0.0708
    N2621 G17 G03 X-0.6024 Y-0.5569 I0.4234 J0.3411
    N2622 G17 G03 X-0.575 Y-0.5871 I0.2744 J0.22
    N2623 G17 G03 X-0.5401 Y-0.6214 I0.3926 J0.3651
    N2624 G17 G03 X-0.5095 Y-0.6486 I0.2685 J0.2717
    N2625 G17 G03 X-0.4711 Y-0.679 I0.3004 J0.3395
    N2626 G17 G02 X-0.4446 Y-0.6983 I-1.2124 J-1.6987
    N2627 G17 G03 X-0.403 Y-0.7244 I0.3813 J0.5594
    N2628 G17 G03 X-0.389 Y-0.733 I0.076 J0.1092
    N2629 G17 G03 X-0.3457 Y-0.7563 I0.2685 J0.4451
    N2630 G17 G03 X-0.3084 Y-0.7732 I0.311 J0.6382
    N2631 G17 G03 X-0.2934 Y-0.78 I0.0585 J0.1094
    N2632 G17 G03 X-0.2782 Y-0.7864 I0.0566 J0.1133
    N2633 G17 G03 X-0.2553 Y-0.7955 I0.0911 J0.1942
    N2634 G17 G03 X-0.2398 Y-0.8011 I0.0573 J0.1364
    N2635 G17 G03 X-0.2242 Y-0.8062 I0.0518 J0.131
    N2636 G01 X-0.2086 Y-0.8113
    N2637 G17 G02 X-0.1927 Y-0.8159 I-0.0549 J-0.219
    N2638 G17 G02 X-0.1689 Y-0.8224 I-0.0832 J-0.3501
    N2639 G17 G02 X-0.1529 Y-0.8262 I-0.0322 J-0.1708
    N2640 G17 G03 X-0.0878 Y-0.8366 I0.2605 J1.4224
    N2641 G17 G03 X-0.0468 Y-0.8411 I0.215 J1.7627
    N2642 G17 G03 X0.0108 Y-0.8434 I0.1074 J2.0432
    N2643 G17 G02 X0.0273 Y-0.8436 I0.0048 J-0.2593
    N2644 G17 G03 X0.0603 Y-0.8424 I-0.002 J0.5135
    N2645 G17 G03 X0.085 Y-0.841 I-0.0072 J0.3557
    N2646 G17 G03 X0.1097 Y-0.8389 I-0.0051 J0.2039
    N2647 G17 G03 X0.1425 Y-0.835 I-0.7833 J6.7314
    N2648 G17 G03 X0.175 Y-0.8292 I-0.1712 J1.0458
    N2649 G17 G03 X0.1993 Y-0.8244 I-0.0329 J0.2312
    N2650 G17 G03 X0.2154 Y-0.8206 I-0.2115 J0.9484
    N2651 G17 G03 X0.2395 Y-0.8147 I-0.0421 J0.221
    N2652 G17 G03 X0.2869 Y-0.8001 I-0.1615 J0.6106
    N2653 G17 G03 X0.3103 Y-0.7921 I-0.0578 J0.2076
    N2654 G17 G03 X0.3564 Y-0.7737 I-0.1958 J0.5555
    N2655 G17 G03 X0.4657 Y-0.7152 I-0.3367 J0.7604
    N2656 G17 G03 X0.5138 Y-0.683 I-0.537 J0.8548
    N2657 G17 G03 X0.5337 Y-0.6682 I-0.1838 J0.2692
    N2658 G17 G03 X0.547 Y-0.6583 I-0.0761 J0.1157
    N2659 G17 G03 X0.5788 Y-0.6318 I-1.184 J1.4536
    N2660 G17 G03 X0.6207 Y-0.5918 I-0.6126 J0.6836
    N2661 G17 G03 X0.6325 Y-0.5801 I-0.102 J0.1149
    N2662 G17 G03 X0.6813 Y-0.5238 I-0.5689 J0.5424
    N2663 G17 G03 X0.6919 Y-0.511 I-0.0995 J0.0925
    N2664 G17 G03 X0.721 Y-0.4707 I-0.3984 J0.3186
    N2665 G17 G03 X0.7436 Y-0.4359 I-0.8392 J0.5697
    N2666 G17 G03 X0.7601 Y-0.4072 I-1.2202 J0.7199
    N2667 G17 G03 X0.7722 Y-0.3854 I-0.2088 J0.1306
    N2668 G17 G03 X0.7908 Y-0.3483 I-0.4731 J0.2607
    N2669 G17 G03 X0.8187 Y-0.2791 I-0.7359 J0.3368
    N2670 G17 G03 X0.8276 Y-0.2558 I-0.1825 J0.0834
    N2671 G17 G03 X0.833 Y-0.2401 I-0.1355 J0.0551
    N2672 G17 G03 X0.8381 Y-0.2243 I-0.1416 J0.0539
    N2673 G01 X0.8431 Y-0.2084
    N2674 G17 G02 X0.8476 Y-0.1924 I0.2319 J-0.0557
    N2675 G17 G03 X0.8662 Y-0.086 I-0.945 J0.2198
    N2676 G17 G03 X0.8691 Y-0.0612 I-0.3137 J0.0497
    N2677 G17 G03 X0.8711 Y-0.0363 I-0.2323 J0.0315
    N2678 G17 G03 X0.8728 Y0.0136 I-8.3889 J0.3131
    N2679 G17 G02 X0.873 Y0.0303 I0.2414 J0.0057
    N2680 G17 G03 X0.8705 Y0.0802 I-1.0732 J-0.0286
    N2681 G17 G03 X0.865 Y0.1299 I-1.0809 J-0.0944
    N2682 G17 G03 X0.8615 Y0.1546 I-0.2334 J-0.0202
    N2683 G17 G02 X0.8574 Y0.1793 I1.4974 J0.2644
    N2684 G17 G03 X0.8503 Y0.2118 I-0.9978 J-0.2003
    N2685 G17 G03 X0.8426 Y0.2443 I-0.3308 J-0.0612
    N2686 G17 G03 X0.8382 Y0.2604 I-0.6203 J-0.1615
    N2687 G17 G03 X0.8312 Y0.2844 I-0.2102 J-0.0478
    N2688 G17 G03 X0.8148 Y0.3317 I-0.5842 J-0.1765
    N2689 G17 G03 X0.8059 Y0.3552 I-0.2635 J-0.0871
    N2690 G17 G03 X0.7963 Y0.3783 I-0.2656 J-0.0962
    N2691 G17 G03 X0.7634 Y0.446 I-0.7591 J-0.3275
    N2692 G17 G03 X0.7515 Y0.4682 I-0.1738 J-0.0784
    N2693 G17 G03 X0.7391 Y0.4901 I-0.2192 J-0.1107
    N2694 G17 G02 X0.7305 Y0.5046 I0.2659 J0.1663
    N2695 G01 X0.7214 Y0.5186
    N2696 G17 G03 X0.7124 Y0.5329 I-0.1127 J-0.0609
    N2697 G17 G03 X0.6779 Y0.5806 I-0.9501 J-0.6512
    N2698 G17 G03 X0.6622 Y0.6004 I-0.4089 J-0.308
    N2699 G17 G03 X0.6461 Y0.6199 I-0.206 J-0.1532
    N2700 G17 G03 X0.6179 Y0.6513 I-0.7859 J-0.6767
    N2701 G17 G03 X0.5886 Y0.6818 I-0.289 J-0.2497
    N2702 G17 G03 X0.5512 Y0.7163 I-0.4106 J-0.4066
    N2703 G17 G03 X0.5253 Y0.7382 I-0.2833 J-0.3079
    N2704 G17 G02 X0.5056 Y0.7545 I1.0945 J1.3493
    N2705 G17 G02 X0.4716 Y0.7802 I1.3007 J1.756
    N2706 G17 G03 X0.429 Y0.8085 I-0.4658 J-0.6559
    N2707 G17 G03 X0.4145 Y0.8177 I-0.1059 J-0.1491
    N2708 G17 G03 X0.3775 Y0.8392 I-0.2794 J-0.4402
    N2709 G17 G03 X0.3625 Y0.8476 I-0.0716 J-0.1101
    N2710 G17 G03 X0.3006 Y0.8775 I-0.3019 J-0.5458
    N2711 G17 G03 X0.2686 Y0.8904 I-0.4778 J-1.1409
    N2712 G17 G03 X0.2446 Y0.9002 I-0.1014 J-0.2121
    N2713 G17 G03 X0.2283 Y0.9062 I-0.061 J-0.14
    N2714 G17 G03 X0.212 Y0.9119 I-0.0597 J-0.147
    N2715 G17 G03 X0.1872 Y0.92 I-0.0964 J-0.2533
    N2716 G17 G03 X0.1705 Y0.9248 I-0.0605 J-0.1773
    N2717 G17 G03 X0.1538 Y0.9293 I-0.0564 J-0.177
    N2718 G17 G03 X0.1284 Y0.9357 I-0.0795 J-0.2594
    N2719 G17 G03 X0.1114 Y0.9395 I-0.0472 J-0.1725
    N2720 G17 G03 X0.0943 Y0.943 I-0.0394 J-0.1505
    N2721 G17 G03 X0.0772 Y0.9462 I-0.0344 J-0.1367
    N2722 G17 G02 X0.06 Y0.9492 I0.0235 J0.1838
    N2723 G17 G03 X-0.0183 Y0.957 I-0.238 J-1.9936
    N2724 G17 G02 X-0.0358 Y0.9581 I0.0079 J0.257
    N2725 G17 G03 X-0.0885 Y0.9584 I-0.0332 J-1.1819
    N2726 G17 G03 X-0.1149 Y0.9579 I-0.0048 J-0.4187
    N2727 G17 G03 X-0.1325 Y0.9574 I-0.005 J-0.1385
    N2728 G01 X-0.1677 Y0.9549
    N2729 G17 G02 X-0.1853 Y0.9535 I-0.0258 J0.2102
    N2730 G17 G03 X-0.2203 Y0.9487 I0.209 J-1.6591
    N2731 G17 G03 X-0.2466 Y0.9445 I0.027 J-0.2547
    N2732 G17 G02 X-0.2727 Y0.9397 I-0.3255 J1.6977
    N2733 G17 G02 X-0.316 Y0.9297 I-0.766 J3.22
    N2734 G17 G03 X-0.3502 Y0.9201 I0.6385 J-2.3341
    N2735 G17 G03 X-0.3758 Y0.9125 I0.0628 J-0.2585
    N2736 G17 G03 X-0.3927 Y0.9069 I0.1033 J-0.3402
    N2737 G17 G03 X-0.4098 Y0.9014 I0.0323 J-0.1295
    N2738 G17 G02 X-0.4266 Y0.8954 I-0.1307 J0.3373
    N2739 G17 G03 X-0.4842 Y0.8708 I0.2949 J-0.7707
    N2740 G17 G03 X-0.5085 Y0.8595 I0.076 J-0.1953
    N2741 G17 G03 X-0.5326 Y0.8473 I0.0991 J-0.2258
    N2742 G17 G03 X-0.5642 Y0.8302 I0.1558 J-0.3247
    N2743 G17 G03 X-0.5874 Y0.8164 I0.1548 J-0.2884
    N2744 G17 G03 X-0.6103 Y0.802 I0.1394 J-0.2469
    N2745 G17 G03 X-0.6328 Y0.787 I0.1222 J-0.2082
    N2746 G17 G03 X-0.6478 Y0.7769 I0.0728 J-0.1238
    N2747 G17 G03 X-0.6906 Y0.7437 I0.5697 J-0.7789
    N2748 G17 G03 X-0.7115 Y0.7264 I0.1881 J-0.2481
    N2749 G17 G03 X-0.7254 Y0.7148 I0.0926 J-0.1248
    N2750 G17 G03 X-0.7453 Y0.6963 I0.8718 J-0.9628
    N2751 G17 G03 X-0.765 Y0.6775 I0.231 J-0.2598
    N2752 G17 G03 X-0.7781 Y0.6648 I0.0996 J-0.1163
    N2753 G17 G03 X-0.7967 Y0.645 I0.4501 J-0.4424
    N2754 G17 G03 X-0.8152 Y0.6249 I0.2285 J-0.2283
    N2755 G17 G02 X-0.833 Y0.6042 I-0.4849 J0.4
    N2756 G17 G03 X-0.8556 Y0.5755 I0.7338 J-0.5998
    N2757 G17 G03 X-0.8668 Y0.5611 I0.134 J-0.1162
    N2758 G17 G03 X-0.8877 Y0.5312 I0.4063 J-0.3068
    N2759 G17 G02 X-0.8981 Y0.5162 I-0.8795 J0.5968
    N2760 G17 G03 X-0.9267 Y0.4693 I0.8356 J-0.5407
    N2761 G17 G03 X-0.9359 Y0.4535 I0.172 J-0.1116
    N2762 G17 G03 X-0.9611 Y0.4046 I0.5423 J-0.3095
    N2763 G17 G02 X-0.9693 Y0.3882 I-0.4317 J0.2068
    N2764 G17 G02 X-0.9771 Y0.3715 I-0.9614 J0.4386
    N2765 G17 G03 X-1.0042 Y0.3032 I0.8464 J-0.3758
    N2766 G17 G03 X-1.0108 Y0.286 I0.1227 J-0.057
    N2767 G17 G03 X-1.017 Y0.2686 I0.1335 J-0.0573
    N2768 G17 G03 X-1.0228 Y0.2511 I0.1456 J-0.0578
    N2769 G17 G03 X-1.0282 Y0.2334 I0.155 J-0.0573
    N2770 G17 G03 X-1.036 Y0.2068 I0.27 J-0.0935
    N2771 G17 G03 X-1.0406 Y0.1889 I0.1885 J-0.058
    N2772 G17 G03 X-1.0449 Y0.1709 I0.18 J-0.0521
    N2773 G17 G03 X-1.0489 Y0.1528 I0.1755 J-0.0478
    N2774 G17 G03 X-1.0525 Y0.1347 I0.159 J-0.0412
    N2775 G17 G03 X-1.0558 Y0.1164 I0.144 J-0.0356
    N2776 G01 X-1.0595 Y0.0982
    N2777 G17 G03 X-1.0666 Y0.0244 I1.9968 J-0.2276
    N2778 G17 G02 X-1.0684 Y-0.0035 I-0.8532 J0.0418
    N2779 G17 G02 X-1.0693 Y-0.022 I-0.2034 J0.0011
    N2780 G17 G03 X-1.0688 Y-0.0685 I1.2 J-0.0093
    N2781 G17 G03 X-1.0672 Y-0.1057 I0.392 J-0.0019
    N2782 G17 G02 X-1.0643 Y-0.1428 I-4.2268 J-0.3439
    N2783 G17 G02 X-1.0627 Y-0.1614 I-0.181 J-0.025
    N2784 G17 G03 X-1.0575 Y-0.1983 I1.3074 J0.1648
    N2785 G17 G03 X-1.0548 Y-0.2167 I0.1662 J0.0153
    N2786 G17 G03 X-1.0495 Y-0.2442 I2.1424 J0.3962
    N2787 G17 G03 X-1.0438 Y-0.2716 I0.2852 J0.0456
    N2788 G17 G02 X-1.0373 Y-0.2988 I-4.3123 J-1.0415
    N2789 G17 G02 X-1.0249 Y-0.3439 I-5.9004 J-1.6497
    N2790 G17 G03 X-1.0162 Y-0.3705 I1.2896 J0.405
    N2791 G17 G03 X-1.0105 Y-0.3883 I0.1589 J0.0415
    N2792 G17 G02 X-1.0042 Y-0.406 I-1.1488 J-0.4166
    N2793 G17 G03 X-0.9904 Y-0.4407 I1.318 J0.5054
    N2794 G17 G03 X-0.9835 Y-0.4581 I0.1421 J0.046
    N2795 G17 G02 X-0.9762 Y-0.4754 I-0.3382 J-0.154
    N2796 G17 G02 X-0.9643 Y-0.5008 I-1.5413 J-0.7347
    N2797 G17 G03 X-0.8506 Y-0.6837 I0.9749 J0.479
    N2798 G17 G03 X-0.8334 Y-0.706 I0.5301 J0.3923
    N2799 G17 G03 X-0.8157 Y-0.728 I0.3013 J0.2247
    N2800 G17 G03 X-0.8037 Y-0.7424 I0.1525 J0.1147
    N2801 G17 G03 X-0.7848 Y-0.7633 I0.7543 J0.6635
    N2802 G17 G03 X-0.7654 Y-0.7839 I0.2965 J0.2602
    N2803 G17 G03 X-0.7524 Y-0.7975 I0.1345 J0.1152
    N2804 G01 X-0.7253 Y-0.8236
    N2805 G17 G03 X-0.6828 Y-0.8609 I1.0359 J1.1395
    N2806 G01 X-0.6536 Y-0.8846
    N2807 G17 G03 X-0.6309 Y-0.9015 I11.945 J15.9775
    N2808 G17 G03 X-0.6081 Y-0.9183 I0.2313 J0.292
    N2809 G17 G02 X-0.5849 Y-0.9344 I-0.3085 J-0.4689
    N2810 G17 G03 X-0.5449 Y-0.9595 I0.4576 J0.6844
    N2811 G17 G03 X-0.4875 Y-0.9922 I0.3459 J0.5405
    N2812 G17 G03 X-0.4709 Y-1.0012 I0.0851 J0.1372
    N2813 G17 G03 X-0.4455 Y-1.0139 I0.2137 J0.3966
    N2814 G17 G03 X-0.3935 Y-1.0364 I0.3748 J0.7926
    N2815 G17 G03 X-0.376 Y-1.0438 I0.0718 J0.1463
    N2816 G17 G03 X-0.3584 Y-1.0507 I0.0794 J0.1767
    N2817 G17 G03 X-0.3406 Y-1.0572 I0.0862 J0.2077
    N2818 G17 G03 X-0.2592 Y-1.0822 I0.2752 J0.7519
    N2819 G17 G03 X-0.1385 Y-1.1065 I0.3012 J1.1831
    N2820 G17 G03 X-0.1104 Y-1.1106 I0.2787 J1.8172
    N2821 G17 G02 X-0.0916 Y-1.1129 I-0.0378 J-0.3826
    N2822 G17 G02 X-0.0727 Y-1.115 I-0.0198 J-0.2665
    N2823 G17 G02 X-0.0538 Y-1.1168 I-0.0095 J-0.1973
    N2824 G17 G03 X0.0126 Y-1.1191 I0.1558 J3.5551
    N2825 G17 G02 X0.0316 Y-1.1194 I0.0057 J-0.2918
    N2826 G17 G02 X0.0506 Y-1.1194 I0.0087 J-0.1884
    N2827 G17 G03 X0.098 Y-1.1171 I-0.4767 J10.067
    N2828 G17 G02 X0.1169 Y-1.1158 I0.0369 J-0.407
    N2829 G17 G03 X0.1641 Y-1.1105 I-0.1446 J1.4846
    N2830 G17 G03 X0.1924 Y-1.1067 I-0.022 J0.2736
    N2831 G17 G02 X0.2205 Y-1.1022 I0.2453 J-1.4328
    N2832 G17 G03 X0.2855 Y-1.0879 I-0.2302 J1.202
    N2833 G17 G03 X0.3405 Y-1.0727 I-0.2207 J0.9049
    N2834 G17 G03 X0.3677 Y-1.0642 I-0.0934 J0.3502
    N2835 G01 X0.3857 Y-1.0581
    N2836 G17 G03 X0.4127 Y-1.0487 I-0.077 J0.263
    N2837 G17 G03 X0.4741 Y-1.0232 I-0.2853 J0.7742
    N2838 G17 G03 X0.5425 Y-0.9899 I-0.3269 J0.7588
    N2839 G17 G03 X0.5595 Y-0.9813 I-0.0608 J0.1409
    N2840 G17 G02 X0.5763 Y-0.9723 I0.1334 J-0.2292
    N2841 G17 G02 X0.6011 Y-0.958 I0.3184 J-0.5231
    N2842 G17 G02 X0.6254 Y-0.9431 I0.3769 J-0.5877
    N2843 G17 G02 X0.6494 Y-0.9275 I0.3905 J-0.5763
    N2844 G17 G02 X0.673 Y-0.9114 I0.3681 J-0.5134
    N2845 G17 G03 X0.7478 Y-0.8525 I-0.8515 J1.1586
    N2846 G17 G03 X0.7972 Y-0.8076 I-0.6261 J0.7379
    N2847 G17 G03 X0.8176 Y-0.7877 I-0.3258 J0.3534
    N2848 G17 G03 X0.8377 Y-0.7673 I-0.2072 J0.2247
    N2849 G17 G03 X0.8634 Y-0.7392 I-0.8722 J0.8257
    N2850 G17 G03 X0.9059 Y-0.6877 I-0.8002 J0.7033
    N2851 G17 G03 X0.9289 Y-0.6574 I-0.3947 J0.3232
    N2852 G17 G02 X0.9402 Y-0.642 I0.5891 J-0.4213
    N2853 G17 G03 X0.9819 Y-0.5781 I-1.1109 J0.7705
    N2854 G17 G02 X0.9968 Y-0.5536 I0.456 J-0.2598
    N2855 G17 G03 X1.024 Y-0.5033 I-0.8232 J0.4779
    N2856 G17 G03 X1.0329 Y-0.4864 I-0.1424 J0.086
    N2857 G17 G03 X1.0414 Y-0.4693 I-0.2157 J0.1175
    N2858 G17 G03 X1.0712 Y-0.399 I-0.7781 J0.3717
    N2859 G17 G02 X1.0784 Y-0.3813 I2.9211 J-1.176
    N2860 G17 G02 X1.0851 Y-0.3634 I0.9389 J-0.339
    N2861 G17 G03 X1.1293 Y-0.1974 I-1.01 J0.3578
    N2862 G17 G03 X1.141 Y-0.1219 I-1.1694 J0.2202
    N2863 G17 G03 X1.1433 Y-0.1029 I-0.3497 J0.0517
    N2864 G17 G03 X1.1453 Y-0.0839 I-0.2521 J0.0368
    N2865 G17 G03 X1.1471 Y-0.0649 I-0.204 J0.0291
    N2866 G17 G03 X1.1492 Y-0.0362 I-0.2598 J0.033
    N2867 G17 G03 X1.1503 Y0.0211 I-1.3434 J0.0541
    N2868 G17 G03 X1.1503 Y0.0403 I-0.2298 J0.0097
    N2869 G17 G03 X1.1501 Y0.0594 I-0.1647 J0.0083
    N2870 G17 G03 X1.1471 Y0.1072 I-1.5393 J-0.0734
    N2871 G17 G03 X1.1447 Y0.1358 I-0.3061 J-0.0117
    N2872 G17 G03 X1.1412 Y0.1643 I-1.5065 J-0.1664
    N2873 G17 G03 X1.1374 Y0.1928 I-0.3142 J-0.0282
    N2874 G17 G02 X1.1327 Y0.2211 I2.1437 J0.368
    N2875 G17 G02 X1.1296 Y0.24 I0.2033 J0.0434
    N2876 G17 G03 X1.1194 Y0.2868 I-17.8364 J-3.8449
    N2877 G17 G03 X1.1122 Y0.3146 I-2.5696 J-0.6558
    N2878 G17 G03 X1.1047 Y0.3424 I-0.295 J-0.0645
    N2879 G17 G03 X1.0991 Y0.3608 I-0.6587 J-0.1897
    N2880 G17 G03 X1.0936 Y0.3791 I-0.1566 J-0.0367
    N2881 G17 G03 X1.0776 Y0.4243 I-0.8013 J-0.2594
    N2882 G17 G03 X1.0601 Y0.469 I-0.6206 J-0.2164
    N2883 G17 G03 X1.053 Y0.4868 I-0.1518 J-0.0504
    N2884 G17 G02 X1.0454 Y0.5045 I0.3786 J0.1729
    N2885 G17 G02 X1.0332 Y0.5306 I5.4576 J2.5639
    N2886 G17 G03 X1.002 Y0.5902 I-1.1545 J-0.5679
    N2887 G17 G03 X0.9927 Y0.607 I-0.295 J-0.1521
    N2888 G17 G03 X0.9633 Y0.6567 I-0.7799 J-0.4283
    N2889 G17 G03 X0.9314 Y0.7048 I-0.8662 J-0.5388
    N2890 G17 G03 X0.9146 Y0.7284 I-0.4229 J-0.2835
    N2891 G17 G03 X0.8973 Y0.7516 I-0.3356 J-0.2313
    N2892 G17 G03 X0.8794 Y0.7744 I-0.2425 J-0.1723
    N2893 G17 G03 X0.8674 Y0.7895 I-0.1358 J-0.0953
    N2894 G17 G03 X0.8225 Y0.8402 I-2.0206 J-1.7474
    N2895 G17 G03 X0.7817 Y0.8814 I-0.9536 J-0.9039
    N2896 G17 G03 X0.7607 Y0.9015 I-0.2812 J-0.2722
    N2897 G17 G03 X0.7467 Y0.9149 I-0.1353 J-0.1276
    N2898 G17 G02 X0.7177 Y0.9408 I13.9122 J15.6367
    N2899 G17 G03 X0.6951 Y0.9591 I-12.6165 J-15.4903
    N2900 G17 G03 X0.6723 Y0.9774 I-0.2397 J-0.2759
    N2901 G17 G02 X0.6491 Y0.9951 I0.6453 J0.8707
    N2902 G17 G02 X0.6174 Y1.0177 I1.1446 J1.6385
    N2903 G17 G03 X0.5848 Y1.0391 I-0.7651 J-1.1265
    N2904 G17 G03 X0.5685 Y1.0499 I-0.0982 J-0.1304
    N2905 G17 G03 X0.535 Y1.07 I-0.2973 J-0.4584
    N2906 G17 G03 X0.5181 Y1.0798 I-0.1365 J-0.2161
    N2907 G17 G03 X0.4749 Y1.1028 I-0.3383 J-0.5823
    N2908 G17 G03 X0.4573 Y1.1113 I-0.052 J-0.0854
    N2909 G17 G03 X0.4606 Y1.1099 I-0.4506 J-1.1049
    N2910 G01 X0.4483 Y1.1253
    N2911 G01 X0.4447 Y1.1446
    N2912 G01 X0.4429 Y1.1642
    N2913 G01 X0.4327 Y1.181
    N2914 G01 X0.4167 Y1.1926
    N2915 G01 X0.3979 Y1.1983
    N2916 G01 X0.3948 Y1.2
    N2917 G01 X-0.747
    N2918 G17 G03 X-0.8022 Y1.1791 I0.2837 J-0.8307
    N2919 G01 X-0.8376 Y1.1619
    N2920 G17 G03 X-0.8891 Y1.1329 I0.3099 J-0.6104
    N2921 G17 G03 X-0.9544 Y1.0891 I0.7897 J-1.2484
    N2922 G17 G03 X-0.9857 Y1.0652 I0.4448 J-0.6141
    N2923 G17 G03 X-1.0737 Y0.9864 I0.8716 J-1.0613
    N2924 G01 X-1.1013 Y0.9583
    N2925 G01 X-1.1147 Y0.9439
    N2926 G01 X-1.1534 Y0.8993
    N2927 G01 X-1.1659 Y0.8841
    N2928 G01 X-1.1898 Y0.8528
    N2929 G01 X-1.1972 Y0.8346
    N2930 G01 X-1.2 Y0.8293
    N2931 G01 Y-0.7258
    N2932 G01 X-1.1868 Y-0.7629
    N2933 G17 G03 X-1.1547 Y-0.8347 I0.6131 J0.2305
    N2934 G01 X-1.1359 Y-0.8693
    N2935 G17 G03 X-1.1156 Y-0.903 I0.6587 J0.3755
    N2936 G17 G03 X-1.0707 Y-0.9677 I1.236 J0.809
    N2937 G17 G03 X-1.0203 Y-1.0281 I0.6211 J0.4673
    N2938 G01 X-1.0076 Y-1.0432
    N2939 G01 X-0.9804 Y-1.0717
    N2940 G01 X-0.9664 Y-1.0855
    N2941 G01 X-0.9231 Y-1.1256
    N2942 G01 X-0.9082 Y-1.1386
    N2943 G17 G03 X-0.8465 Y-1.1874 I0.947 J1.1337
    N2944 G17 G02 X-0.8214 Y-1.2 I-0.1923 J-0.4131
    N2945 G01 X0.7337
    N2946 G17 G03 X0.8074 Y-1.1725 I-0.1919 J0.6262
    N2947 G01 X0.8431 Y-1.1559
    N2948 G17 G03 X0.895 Y-1.1277 I-0.3004 J0.6151
    N2949 G01 X0.9283 Y-1.1068
    N2950 G17 G03 X0.9923 Y-1.0609 I-0.6152 J0.9261
    N2951 G01 X1.0076 Y-1.0485
    N2952 G01 X1.0522 Y-1.0098
    N2953 G01 X1.0666 Y-0.9964
    N2954 G17 G03 X1.1482 Y-0.911 I-0.9514 J0.9904
    N2955 G01 X1.1609 Y-0.896
    N2956 G01 X1.1853 Y-0.8651
    N2957 G01 X1.2 Y-0.8386
    N2958 G01 Y0.7559
    N2959 G01 X1.1868 Y0.7929
    N2960 G01 X1.1796 Y0.8113
    N2961 G01 X1.163 Y0.847
    N2962 G17 G03 X1.1448 Y0.8819 I-0.6808 J-0.3338
    N2963 G01 X1.1249 Y0.9159
    N2964 G01 X1.103 Y0.9486
    N2965 G01 X1.0915 Y0.9646
    N2966 G17 G03 X1.0169 Y1.0561 I-1.1007 J-0.8212
    N2967 G17 G03 X0.9617 Y1.1122 I-0.8197 J-0.7512
    N2968 G01 X0.9178 Y1.1516
    N2969 G01 X0.9027 Y1.1643
    N2970 G01 X0.8718 Y1.1887
    N2971 G01 X0.8538 Y1.1967
    N2972 G01 X0.8477 Y1.2
    N2973 G01 X0.3752
    N2974 G01 X0.3687 Y1.1995 Z-0.9999
    N2975 G01 X0.3624 Y1.1978 Z-0.9997
    N2976 G01 X0.3564 Y1.1952 Z-0.9995
    N2977 G01 X0.3509 Y1.1916 Z-0.9992
    N2978 G01 X0.3461 Y1.1871 Z-0.9987
    N2979 G01 X0.3421 Y1.1819 Z-0.9977
    N2980 G01 X0.339 Y1.1761 Z-0.9955
    N2981 G01 X0.337 Y1.1699 Z-0.9902
    N2982 G01 X0.336 Y1.1634 Z-0.9848
    N2983 G01 X0.336 Y1.1569 Z-0.9826
    N2984 G01 X0.3372 Y1.1504 Z-0.9817
    N2985 G01 X0.3394 Y1.1443 Z-0.9811
    N2986 G01 X0.3426 Y1.1386 Z-0.9808
    N2987 G01 X0.3468 Y1.1335 Z-0.9806
    N2988 G01 X0.3517 Y1.1291 Z-0.9804
    N2989 G01 X0.3572 Y1.1256 Z-0.9803
    N2990 G01 X1.1426 Y0.7209
    N2991 G01 X1.1488 Y0.7183 Z-0.9805
    N2992 G01 X1.1553 Y0.7168 Z-0.9807
    N2993 G01 X1.162 Y0.7165 Z-0.9811
    N2994 G01 X1.1687 Y0.7173 Z-0.9819
    N2995 G01 X1.1751 Y0.7192 Z-0.9838
    N2996 G01 X1.1811 Y0.7222 Z-0.9902
    N2997 G01 X1.1865 Y0.7262 Z-0.9965
    N2998 G01 X1.1912 Y0.731 Z-0.9984
    N2999 G01 X1.195 Y0.7366 Z-0.9992
    N3000 G01 X1.1977 Y0.7427 Z-0.9996
    N3001 G01 X1.1994 Y0.7492 Z-0.9998
    N3002 G01 X1.2 Y0.7559 Z-1.
    N3003 G01 Y1.1299
    N3004 G17 G03 X1.1857 Y1.1665 I-0.3506 J-0.1161
    N3005 G01 X1.1746 Y1.1828
    N3006 G01 X1.1581 Y1.1936
    N3007 G01 X1.1391 Y1.1987
    N3008 G01 X1.1366 Y1.2
    N3009 G01 X0.8413
    N3010 G01 X0.8347 Y1.1994 Z-0.9999
    N3011 G01 X0.8283 Y1.1978 Z-0.9998
    N3012 G01 X0.8222 Y1.195 Z-0.9996
    N3013 G01 X0.8167 Y1.1913 Z-0.9993
    N3014 G01 X0.8119 Y1.1867 Z-0.999
    N3015 G01 X0.8079 Y1.1814 Z-0.9984
    N3016 G01 X0.8049 Y1.1755 Z-0.9974
    N3017 G01 X0.8029 Y1.1691 Z-0.9951
    N3018 G01 X0.802 Y1.1625 Z-0.9902
    N3019 G01 X0.8023 Y1.1559 Z-0.9852
    N3020 G01 X0.8036 Y1.1494 Z-0.983
    N3021 G01 X0.8061 Y1.1432 Z-0.9819
    N3022 G01 X0.8095 Y1.1375 Z-0.9813
    N3023 G01 X0.8139 Y1.1324 Z-0.981
    N3024 G01 X0.819 Y1.1282 Z-0.9807
    N3025 G01 X0.8248 Y1.1249 Z-0.9806
    N3026 G01 X0.831 Y1.1226 Z-0.9804
    N3027 G01 X0.8376 Y1.1214 Z-0.9803
    N3028 G01 X1.1569 Y1.0907
    N3029 G01 X1.1634 Y1.0906 Z-0.9805
    N3030 G01 X1.1699 Y1.0916 Z-0.9809
    N3031 G01 X1.1761 Y1.0937 Z-0.9815
    N3032 G01 X1.1819 Y1.0967 Z-0.9833
    N3033 G01 X1.1871 Y1.1007 Z-0.9902
    N3034 G01 X1.1916 Y1.1055 Z-0.997
    N3035 G01 X1.1952 Y1.111 Z-0.9988
    N3036 G01 X1.1978 Y1.117 Z-0.9994
    N3037 G01 X1.1995 Y1.1233 Z-0.9998
    N3038 G01 X1.2 Y1.1299 Z-1.
    N3039 G17 G03 X1.1998 Y1.1551 I-0.6238 J0.008
    N3040 G17 G03 X1.1508 Y1.2 I-0.0491 J-0.0044
    N3041 G01 X1.1311
    N3042 G01 X0.5051 Z-0.9803
    N3043 G01 X-0.121
    N3044 G01 X-0.747 Z-1.
    N3045 G01 X-1.1013
    N3046 G17 G03 X-1.1569 Y1.1802 I0.2015 J-0.6542
    N3047 G01 X-1.1748 Y1.1719
    N3048 G01 X-1.1886 Y1.1579
    N3049 G01 X-1.1966 Y1.1399
    N3050 G01 X-1.2 Y1.1337
    N3051 G01 Y0.8187
    N3052 G01 X-1.1995 Y0.8122 Z-0.9999
    N3053 G01 X-1.1979 Y0.806 Z-0.9998
    N3054 G01 X-1.1953 Y0.8 Z-0.9996
    N3055 G01 X-1.1917 Y0.7946 Z-0.9993
    N3056 G01 X-1.1873 Y0.7898 Z-0.999
    N3057 G01 X-1.1822 Y0.7858 Z-0.9984
    N3058 G01 X-1.1765 Y0.7827 Z-0.9974
    N3059 G01 X-1.1704 Y0.7806 Z-0.9951
    N3060 G01 X-1.164 Y0.7795 Z-0.9902
    N3061 G01 X-1.1575 Z-0.9852
    N3062 G01 X-1.1511 Y0.7805 Z-0.983
    N3063 G01 X-1.145 Y0.7826 Z-0.9819
    N3064 G01 X-1.1392 Y0.7857 Z-0.9813
    N3065 G01 X-1.1341 Y0.7896 Z-0.981
    N3066 G01 X-1.1297 Y0.7944 Z-0.9807
    N3067 G01 X-1.1261 Y0.7998 Z-0.9806
    N3068 G01 X-1.1235 Y0.8057 Z-0.9804
    N3069 G01 X-1.1218 Y0.812 Z-0.9803
    N3070 G01 X-1.0625 Y1.1539
    N3071 G01 X-1.0619 Y1.1607 Z-0.9805
    N3072 G01 X-1.0626 Y1.1676 Z-0.9809
    N3073 G01 X-1.0643 Y1.1742 Z-0.9815
    N3074 G01 X-1.0672 Y1.1804 Z-0.9833
    N3075 G01 X-1.0712 Y1.186 Z-0.9902
    N3076 G01 X-1.076 Y1.1908 Z-0.997
    N3077 G01 X-1.0817 Y1.1947 Z-0.9988
    N3078 G01 X-1.0879 Y1.1976 Z-0.9994
    N3079 G01 X-1.0945 Y1.1994 Z-0.9998
    N3080 G01 X-1.1013 Y1.2 Z-1.
    N3081 G01 X-1.1508
    N3082 G17 G03 X-1.2 Y1.1508 I0.0001 J-0.0493
    N3083 G01 Y1.1311
    N3084 G01 Y-0.7258
    N3085 G01 Y-1.0998
    N3086 G01 X-1.1868 Y-1.1369
    N3087 G17 G03 X-1.1702 Y-1.1726 I0.3427 J0.1376
    N3088 G01 X-1.157 Y-1.1871
    N3089 G17 G02 X-1.1317 Y-1.2 I-0.2479 J-0.5168
    N3090 G01 X-0.8168
    N3091 G01 X-0.81 Y-1.1994 Z-0.9999
    N3092 G01 X-0.8033 Y-1.1976 Z-0.9997
    N3093 G01 X-0.7971 Y-1.1947 Z-0.9995
    N3094 G01 X-0.7915 Y-1.1908 Z-0.9993
    N3095 G01 X-0.7866 Y-1.1859 Z-0.9988
    N3096 G01 X-0.7827 Y-1.1803 Z-0.9981
    N3097 G01 X-0.7798 Y-1.1741 Z-0.9967
    N3098 G01 X-0.778 Y-1.1675 Z-0.9932
    N3099 G01 X-0.7774 Y-1.1606 Z-0.9872
    N3100 G01 X-0.778 Y-1.1538 Z-0.9837
    N3101 G01 X-0.7798 Y-1.1472 Z-0.9822
    N3102 G01 X-0.7827 Y-1.141 Z-0.9815
    N3103 G01 X-0.7866 Y-1.1353 Z-0.981
    N3104 G01 X-0.7915 Y-1.1305 Z-0.9808
    N3105 G01 X-0.7971 Y-1.1265 Z-0.9806
    N3106 G01 X-0.8033 Y-1.1236 Z-0.9804
    N3107 G01 X-0.8099 Y-1.1219 Z-0.9803
    N3108 G01 X-1.1538 Y-1.061
    N3109 G01 X-1.16 Y-1.0604 Z-0.9805
    N3110 G01 X-1.1662 Y-1.0608 Z-0.9808
    N3111 G01 X-1.1723 Y-1.0622 Z-0.9813
    N3112 G01 X-1.1781 Y-1.0645 Z-0.9824
    N3113 G01 X-1.1835 Y-1.0677 Z-0.9859
    N3114 G01 X-1.1882 Y-1.0717 Z-0.9944
    N3115 G01 X-1.1923 Y-1.0765 Z-0.9979
    N3116 G01 X-1.1956 Y-1.0818 Z-0.999
    N3117 G01 X-1.198 Y-1.0875 Z-0.9995
    N3118 G01 X-1.1995 Y-1.0936 Z-0.9998
    N3119 G01 X-1.2 Y-1.0998 Z-1.
    N3120 G01 Y-1.1508
    N3121 G17 G03 X-1.1508 Y-1.2 I0.0493 J0.0001
    N3122 G01 X-1.1311
    N3123 G01 X0.7337
    N3124 G01 X1.1077
    N3125 G17 G03 X1.145 Y-1.1874 I-0.2244 J0.7243
    N3126 G01 X1.1631 Y-1.1796
    N3127 G01 X1.1802 Y-1.1699
    N3128 G01 X1.192 Y-1.1542
    N3129 G01 X1.1981 Y-1.1354
    N3130 G01 X1.2 Y-1.1319
    N3131 G01 Y-0.8366
    N3132 G01 X1.1995 Y-0.8302 Z-0.9999
    N3133 G01 X1.1979 Y-0.8238 Z-0.9998
    N3134 G01 X1.1952 Y-0.8179 Z-0.9996
    N3135 G01 X1.1917 Y-0.8124 Z-0.9993
    N3136 G01 X1.1873 Y-0.8077 Z-0.999
    N3137 G01 X1.1821 Y-0.8037 Z-0.9984
    N3138 G01 X1.1764 Y-0.8006 Z-0.9974
    N3139 G01 X1.1702 Y-0.7985 Z-0.9951
    N3140 G01 X1.1638 Y-0.7974 Z-0.9902
    N3141 G01 X1.1573 Z-0.9852
    N3142 G01 X1.1509 Y-0.7985 Z-0.983
    N3143 G01 X1.1447 Y-0.8006 Z-0.9819
    N3144 G01 X1.139 Y-0.8037 Z-0.9813
    N3145 G01 X1.1339 Y-0.8077 Z-0.981
    N3146 G01 X1.1295 Y-0.8125 Z-0.9807
    N3147 G01 X1.1259 Y-0.818 Z-0.9806
    N3148 G01 X1.1234 Y-0.824 Z-0.9804
    N3149 G01 X1.1218 Y-0.8303 Z-0.9803
    N3150 G01 X1.0688 Y-1.1543
    N3151 G01 X1.0683 Y-1.1611 Z-0.9805
    N3152 G01 X1.069 Y-1.1679 Z-0.9809
    N3153 G01 X1.0708 Y-1.1744 Z-0.9815
    N3154 G01 X1.0737 Y-1.1806 Z-0.9833
    N3155 G01 X1.0777 Y-1.1861 Z-0.9902
    N3156 G01 X1.0825 Y-1.1909 Z-0.997
    N3157 G01 X1.0881 Y-1.1948 Z-0.9988
    N3158 G01 X1.0943 Y-1.1977 Z-0.9994
    N3159 G01 X1.1009 Y-1.1994 Z-0.9998
    N3160 G01 X1.1077 Y-1.2 Z-1.
    N3161 G01 X1.1508
    N3162 G17 G03 X1.2 Y-1.1508 I-0.0001 J0.0493
    N3163 G01 Y-1.1311
    N3164 G17 G03 X1.1885 Y-1.1033 I-0.0397 J-0.0001
    N3165 G00 Z-0.65
    N3166 G00 Z0.1
    N3167 M09
    N3168 M05
    N3169 G00 G91 G28 Z0.
    N3170 G00 G91 G28 Y0.
    N3171 G90
    N3172 T1 M06
    N3173 M02
    (END OF FILE)
    (END OF PROGRAM)
    N3174 M30
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    I check the code for the 3D tool path, advance rough : Same thing, rapid down to feed plane, feed move to depth of cut.
    Can you post a sample file or you code so we can see what settings you are using and why this is happening in your code.
    Al DePoalo
    bobcad guy Guest
    Quote Originally Posted by aldepoalo View Post
    I am trying to reproduce this issue with no luck. Here is the code I get doing a pocket that have 4 step to get to the bottom. I am using a pocket feature with advance pocket pattern.
    Code:
    (FIRST MACHINE SETUP - Machine Setup - 1)
    (PROGRAM NAME - BOBCAD1.NC)
    (POST -  BC_3X_MILL 3-AXIS GENERIC FANUC)
    (DATE - TUE. 05/07/2013)
    (TIME - 02:15PM)
    N01 G00 G17 G40 G49 G80 G20 G90
    (FIRST CUT - FIRST TOOL)
    (JOB 1  POCKET)
    (FEATURE POCKET)
    (TOOL #1 0.5 ENDMILL ROUGH)
    N02 T1 M06
    N03 G00 G90 G54 X0.2 Y0.2 S3880 M03
    N04 G00 G43 H1 D1 Z0.1 M08
    N05 G00
    N06 G01 Z-0.25 F44.6296 <<<<<<<<<<<  Feed move to Z
    N07 G01 X-0.2 F89.2592
    N08 G01 Y-0.2
    N09 G01 X0.2
    N10 G01 Y0.2
    N11 G01 Y0.45
    N12 G01 X-0.45
    N13 G01 Y-0.45
    N14 G01 X0.45
    N15 G01 Y0.45
    N16 G01 X0.2
    N17 G01 Y0.7
    N18 G01 X-0.7
    N19 G01 Y-0.7
    N20 G01 X0.7
    N21 G01 Y0.7
    N22 G01 X0.2
    N23 G01 Y0.95
    N24 G01 X-0.95
    N25 G01 Y-0.95
    N26 G01 X0.95
    N27 G01 Y0.95
    N28 G01 X0.2
    N29 G01 Y1.2
    N30 G01 X-1.2
    N31 G01 Y-1.2
    N32 G01 X1.2
    N33 G01 Y1.2
    N34 G01 X0.2
    N35 G00 Z0.1
    N36 G00 Y0.2
    N37 G00 Z-0.15
    N38 G01 Z-0.5 F44.6296 <<<<<<<<<<<<<<  Feed move to Z
    N39 G01 X-0.2 F89.2592
    N40 G01 Y-0.2
    N41 G01 X0.2
    N42 G01 Y0.2
    N43 G01 Y0.45
    N44 G01 X-0.45
    N45 G01 Y-0.45
    N46 G01 X0.45
    N47 G01 Y0.45
    N48 G01 X0.2
    N49 G01 Y0.7
    N50 G01 X-0.7
    N51 G01 Y-0.7
    N52 G01 X0.7
    N53 G01 Y0.7
    N54 G01 X0.2
    N55 G01 Y0.95
    N56 G01 X-0.95
    N57 G01 Y-0.95
    N58 G01 X0.95
    N59 G01 Y0.95
    N60 G01 X0.2
    N61 G01 Y1.2
    N62 G01 X-1.2
    N63 G01 Y-1.2
    N64 G01 X1.2
    N65 G01 Y1.2
    N66 G01 X0.2
    N67 G00 Z-0.15
    N68 G00 Z0.1
    N69 G00 Y0.2
    N70 G00 Z-0.4
    N71 G01 Z-0.75 F44.6296 <<<<<<<<<<<<<  Feed move to Z
    N72 G01 X-0.2 F89.2592
    N73 G01 Y-0.2
    N74 G01 X0.2
    N75 G01 Y0.2
    N76 G01 Y0.45
    N77 G01 X-0.45
    N78 G01 Y-0.45
    N79 G01 X0.45
    N80 G01 Y0.45
    N81 G01 X0.2
    N82 G01 Y0.7
    N83 G01 X-0.7
    N84 G01 Y-0.7
    N85 G01 X0.7
    N86 G01 Y0.7
    N87 G01 X0.2
    N88 G01 Y0.95
    N89 G01 X-0.95
    N90 G01 Y-0.95
    N91 G01 X0.95
    N92 G01 Y0.95
    N93 G01 X0.2
    N94 G01 Y1.2
    N95 G01 X-1.2
    N96 G01 Y-1.2
    N97 G01 X1.2
    N98 G01 Y1.2
    N99 G01 X0.2
    N100 G00 Z-0.4
    N101 G00 Z0.1
    N102 G00 Y0.2
    N103 G00 Z-0.65
    N104 G01 Z-1. F44.6296 <<<<<<<<<<<<<<<  Feed move to Z
    N105 G01 X-0.2 F89.2592
    N106 G01 Y-0.2
    N107 G01 X0.2
    N108 G01 Y0.2
    N109 G01 Y0.45
    N110 G01 X-0.45
    N111 G01 Y-0.45
    N112 G01 X0.45
    N113 G01 Y0.45
    N114 G01 X0.2
    N115 G01 Y0.7
    N116 G01 X-0.7
    N117 G01 Y-0.7
    N118 G01 X0.7
    N119 G01 Y0.7
    N120 G01 X0.2
    N121 G01 Y0.95
    N122 G01 X-0.95
    N123 G01 Y-0.95
    N124 G01 X0.95
    N125 G01 Y0.95
    N126 G01 X0.2
    N127 G01 Y1.2
    N128 G01 X-1.2
    N129 G01 Y-1.2
    N130 G01 X1.2
    N131 G01 Y1.2
    N132 G01 X0.2
    N133 G00 Z-0.65
    N134 G00 Z0.1
    N135 M09
    N136 M05
    N137 G00 G91 G28 Z0.
    N138 G00 G91 G28 Y0.
    N139 G90
    N140 T1 M06
    N141 M02
    (END OF FILE)
    (END OF PROGRAM)
    N142 M30
    al, i not only can show you several programs i have with the issue, i spent an hour on the phone telling sean daughrety that this is nonsense, and you cant rapid feed right to the floor, he after trying to tyr every trick he could think of to prove me wrong, finally agreed that i was right, then called me back later that day and said there was nothing wrong, and i should use a different feature. he said that feature was designed to keep the tool as quickly as it can. i will upload some text tonight, and sean did have the actual file too. advanced pocket is a nice feature, it just doesnt work. i sent you a file at bobcad today, may 7, that had a bad toolpath, not the rapid into the z axis problem, an even worse problem. i really want to see you guys sucessfully make this stuff better, but ya cant blow us off when we have issues, not you, but support in general, anytime someone tells me rapiding to within .0001 tenth at 1300 inches a minute is the way they meant it to be, i know i cant trust them. i truly believe you care al, you put alot into this, and i will not lie to you, its a problem. i WILL post the code tonight. and I DO NOT EVER!!! edit code that bobcad puts out, i swear, its genuine. plus, my boss forbids me from hand editing programs, way less chances of crashes, mistakes.
    Mar 2012
    1570
    BobCAD Guy,
    In no way do I think you are lying to me. From what was in the thread I tried to reproduce the issue you were having. I wasn't able to do so and I just want to help. I think one of the biggest issue any support member deals with is really understand what the problem is. It's not always clear and believe it or not even after talking about the issue for a long time. I've done a ton of support and still at times find it hard to understand what the "problem" is. I feel there should be a simple solution to what's going on....
    Al DePoalo
    bobcad guy Guest
    heres one thing, I cant seem to get the actual files I want to post, whats the trick to putting .bbcd files on
    bobcad guy Guest
    and this is the rapid onto the surface part. I wish I could send the file, so much better to see, al, if you want file, I will send to bobcad.com
    Dec 2008
    4548
    You right clcik the bbcd file and choose "send to-compressed zip" then attach that.
    Apr 2009
    3376
    Right click on your file,scroll down,pick send to compressed folder(zip)
    On forum page,look for "go advance",click that
    look for "manage attachments"click that
    click browse,look for the folder you compressed(zip)
    click that,then click upload.
    close that window and post
    Burr types faster
    Mar 2012
    1570
    Just based on the screen shot it is clear the tool path is cutting through the part. My first thought is there is something wrong with the geometry. Double lines not trimmed not tangent something like that.
    Please upload the file so we can sort you out.
    Al DePoalo
  17. #17
    Dec 2008
    4548
    Quote Originally Posted by jrmach View Post
    Burr types faster
    Give me 5. Up high. Now down low? Too slow.
    Although your detail is impressive, and most desirable.
  18. #18
    Mar 2012
    1570
    ... I can't seem to respond
    Al DePoalo
  19. #19
    Mar 2012
    1570
    Again,
    Based on the image that you have provided it looks like there is some bad geometry. Please post your file here by zipping it and attaching the file. If the file is too big you can always create a drop box account ( free ) and post a link for us to download the file.
    We want to help and once we have the file we can sort out the issue.
    Al DePoalo
  20. #20
    Mar 2012
    1570
    Hemingway test test
    Al DePoalo
Page 1 of 2 12
  1. One of the most advanced
    By jjacoby in forum Uncategorised CAM Discussion
    Last Post: 06-10-2012, 02:52 AM
  2. Advanced Rough Needs a Drill feature?
    By tlharris in forum BobCad-Cam
    Last Post: 05-21-2012, 05:49 PM
  3. Feature Advanced Rough-generate toolpath SLOW
    By L.Kiefer in forum BobCad-Cam
    Last Post: 12-19-2011, 02:45 PM
  4. Advanced rough
    By Koblenzer in forum BobCad-Cam
    Last Post: 09-30-2011, 09:41 PM
  5. Z Level rough with multipule rough tools
    By mbi in forum FeatureCAM CAD/CAM
    Last Post: 02-26-2010, 05:45 AM
