603,914 active members*
2,939 visitors online*
    Jun 2015
    Advice for a Cartesian Robot
    Hello all,
    I have been tasked with building a 1 meter X 1 meter Cartesian bot. I already have some experience in building 3D Printers, so I had assumed that I can just use 1 meter lead screws and smooth rods and be done with it. But I was so wrong. Soon I discovered that lead screws are not fast enough and smooth rods(10 mm) might sag.
    I have already spent few hours reading many posts on the forum and learned a lot regarding ball screws, R&P, linear guides etc. I am confused between what to choose. I will list out the specs of my future machine:
    X-Y axes length - 1 meter (Z axis not required for now)
    Payload - 1 to 5 kgs(2 to 11 pounds)
    Accuracy/Resolution desired - 30-50 micron(0.001' inch) [I arrived at this figure by taking average of accuracies offered by a Rolled C7 Ball Screw and a industrial Cartesian robot)
    Speed - 1000-1500 ipm [ This is the speeds what a Industrial Cartesian robot offers]
    There will be no forces acting on as it does nothing heavy and will be used for glue dispensing.
    I am torn between ball screw and Rack & pinion. Does the price of a Ball Screw justify in a machine with no heavy loads? I am leaning towards R&P but still haven't found anywhere in the forum what is the actual accuracy offered by it. And then I also discovered that you can't drive the pinion directly and need a 3:1 reduction.
    Second doubt is of linear motion. Will 16mm linear rods with bearing blocks suffice or linear guides are necessary?
    For driving both the axis I will be using NEMA23 motors having 19 kg-cm torque.
    Jun 2010
    4260
    Re: Advice for a Cartesian Robot
    1 m x 1 m?
    Try 50 mm ground hardened steel rods with linear bearings, or 75 x 75 mm box frame with linear guide rails glued and bolted on top.
    Accuracy for a gluing machine: be reasonable!! 0.5 mm will probably do!!!
    Either 20 mm dia ball screws, or very possibly open toothed belt drive, using GT2 belts 10 - 16 mm wide.
    Rack and pinion over 1 m - maybe 1 mm accuracy. OK, maybe 0.5 mm. NOT good enough. (Others WILL disagree.)
    Cost of materials: $N
    Cost of labour: $10N
    Cost of time spent trying to do it on the cheap (and failing): $100N
    Cheers
    Roger
  1. Cartesian Robot CNC Build Ideas
    By KickFarter in forum DIY CNC Router Table Machines
    Last Post: 04-27-2015, 08:12 PM
  2. Need Advice on coverting a xyz robot to Plasma CNC
    By tprothma in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-27-2014, 09:02 AM
  3. new to forum need advice on Robot Tending
    By mrmachinst in forum Okuma
    Last Post: 03-06-2011, 07:57 PM
