Hello fellow machinists!
I've recently been trying to machine a multi-surface feature in camworks. The surface I'm machining is a slightly concave dome shaped surface. I have been using a ball nose cutter but I am having to use very very small step-overs (0.5mm) otherwise my scallop heights are too big and I want as smooth surface finish as possible, instead of a "ripple effect". As you can imagine a step over of 0.5mm-1mm on my hobby CNC takes forever.
My idea (which I hoping will work, please let my know if I'm just being stupid) is to use this type of tool (see link below), I am not sure what the tool is called, if somebody could tell me that would be much appreciated. Tool>>> WEI GUAN-Products R-Type Surface Milling Cutter > RAM(R4)(R5)(R6) R Type Surface Milling Cutter
If I used this type of tool could I increase the size of my stepovers, reduce the scallop/ripple heights and improve the surface finish and machining time?
Also I cannot seem to find that type of tool in camworks, probably doesn't help that I have no idea what its called or much about these types of tools, does it actually exist in camworks and also can this method be done with camworks?
Many many thanks in advance.
John.
