603,884 active members*
5,001 visitors online*
    Aug 2004
    20
    advice on a particular cutting operation
    As you will quickly see, I'm very new to machining and cnc operations. I am trying to do a certain cutting operation, and wondering the best route to go (be it extensive math (please, no), or some appropriate cam software).
    Here's a simple picture...
    The plan is to set it up in a rotary table at the proper angle, so at least that way I can keep the z-axis on the same plane on each pass.
    What I need help with, is the best way to get the g-code to make all those cuts.
    I thought about doing some self-abusive spreadsheet that will give me the coordinates by moving every couple thou.. But for one, I'm no math guru, and secondly, I'd rather learn how to use the proper cam software to help make life easier
    BTW - I'm using a sherline mill, and have their basic my t'mill software for sending the gcode to the mill... I am downloading some evals of some cam software, but having a rough time finding the best one to get the best g-code.. I am using solidworks for my 3d modeling.
    Sep 2003
    1113
    Save/export the file as an stl from Solidworks. Download and try the STLWorks from Imserve, they advertize on the site here. Use it to generate your G-Code. You can get it as an eval for free and see if that does the trick for you. There are other CAM programs out there - but I've found STLWork fairly easy to use - mind you ya gotta spend a few moments on the help files!
    Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  1. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
  2. Cutting metal
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 02-20-2005, 06:14 AM
  3. Operation Data - At Op End
    By wjbzone in forum GibbsCAM
    Last Post: 09-24-2004, 01:30 PM
  4. CNC router deflection calcs and cutting loads?
    By Linus in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 04:08 PM
  5. Do you account for climb cutting in G code?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 11-07-2003, 02:21 AM
