603,848 active members*
4,480 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Advice Using Tiny End Mills
    Jul 2010
    79
    Hi Guys,
    I'm using a CNC'd X3 mill and I need to machine some tiny features. I'll be using a 20mil and a 7mil carbide tools which I originally bought for some PCB milling.
    So two questions:
    Can I use my Shar's Z-Setter tool with these end mills or will they just snap off?
    shars.com - Electronic Magnetic Z Axis Setter 2quot Height
    Second, the features need to be 10mils deep. What feed rate and DOC should I use? My mill only goes up to about 2k rpm.
    Thanks.
    Jan 2011
    11
    Hi TaK,
    First, could you tell us what tiny materials you need processing, plastics, wood, stone, or…?
    What’s the feed rate you set before?
    And how about the spindle of your CNC machine? 1.5kw, 3kw, 4.5kw…?
    If any questions, you could visit http://www.astech-cnctools.com/, you may also find some Stronger PCD router bits for your CNC router with beautiful artworks, or just email me directly.
    Hope ASTECH can help! :idea:
    Best regards,
    Alice
    ASTECH Tools -Professional Router Bits, Diamond Tools, CNC Tools Manufacturer.
    Website: http://www.astech-cnctools.com/
    Email: [email protected]
    Tel: 0086-531-89006595
  1. Newbie advice for gunsmithing mills and etc.
    By coolboy499 in forum Uncategorised MetalWorking Machines
    Last Post: 05-31-2009, 12:08 PM
  2. Chinese mills and parachutes (need advice)
    By IQChallenged in forum Linear and Rotary Motion
    Last Post: 04-10-2009, 12:46 AM
  3. RFQ: A tiny job in Europe
    By dosign in forum Employment Opportunity
    Last Post: 01-28-2008, 01:42 PM
  4. wee tiny endmills
    By project5k in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-26-2007, 02:13 AM
  5. Face Mills intstead of end mills
    By balal in forum MetalWork Discussion
    Last Post: 07-01-2006, 06:35 AM
