603,767 active members*
3,869 visitors online*
Results 1 to 4 of 4
    Advise on PVC vacuum table
    hi all,
    its my first post, just found this awesome forum today. i notice it covers every topic a workshop needs to know, great stuff.
    i have just received my cnc with vacuum table and to my horrible the vacuum bed has been weight down by the vacuum pump that was placed on top of it, can anyone advise how to go about to correct the table?
    i've contacted china to asked for a solution, they suggest to skim down the surface which i think its too much to be skimmed.
    would appreciate if anyone could provide me a solution.
    thank you all.
    Aug 2005
    206
    Re: Advise on PVC vacuum table
    That looks pretty bad. I would be concerned about how much support structure there is under the phenolic top. Were the CNC mine, I would look to supplement what structure is already there. If you machine it as is, you might not have enough gasket groove depth to allow the gasket to fully compress under vacuum in certain areas. See if the company would send a replacement top. I wouldn't trust the one you have.
    Quote Originally Posted by MARV View Post
    They won't replace, that's for sure.
    Under the PVC are cross section supports.
    Was hoping for a solid base support..
    Mar 2003
    35494
    You need to remove the PVC and make the sub structure more rigid.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. advise on a vacuum pump
    By bcer960 in forum Avid CNC
    Last Post: 07-12-2017, 01:16 AM
  2. 2.2 KW Vacuum pump advise
    By KurtRosenzweig in forum Chinese Machines
    Last Post: 01-21-2017, 07:33 PM
  3. Vacuum table help. Custom table for small acrylic parts.
    By czwalga in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2014, 03:06 PM
  4. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  5. need advise on building my own table or just buy one.
    By HMD in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-18-2007, 10:25 PM
