Re: Air Cooled Spindle what Hp for the Saturn 2 4x4 ?
Gary , A ground could be as simple as a stranded #12 or #14 wire connected to the motor and run back to the machine ground. It does not need to be In the plug to be a legal / safe ground. GFI's and welders, VFD's and other RFI generators do not play well. Your ground is all need to be safe. Before GFI's, as long as the User did not cut off the grounding prong or plug you were protected. I am guessing and have not tried, there is enough metal connected between the motor clamp and the router metal frame to act as a backup ground. I might take an ohm meter this morning to see.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
