587,999 active members*
1,358 visitors online*
Thread: air wall
    May 2011
    3
    air wall
    I have been using gibbs for many years. One thing I have never been able to figure out is when cutting a slot with air wall at both ends and using cutter comp is to get the cutter to cut off the far edge of the part. I will cut down one edge move over and cut back on the other edge But the cutter never clears the the part completely on the far side. I either have to cheat and make the slot longer than needed or edit the far move.
    Mike
    Apr 2010
    200
    On the "open sides" tab, did you increase the overhang?
    That should do it, but I usually just extend the geometry like you have been doing.
    Apparently I don't know anything, so please verify my suggestions with my wife.
  1. Hitting the wall in XP
    By Brakeman Bob in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-05-2010, 09:12 AM
  2. Jurassic Wall
    By ydeardorff in forum Machine Created Art
    Last Post: 11-27-2009, 06:30 PM
  3. Removable Wall Decals
    By Luke Lockridge in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 11-30-2008, 05:50 PM
  4. Off-the-wall cold-air gun question...
    By MauserBob in forum MetalWork Discussion
    Last Post: 10-18-2008, 04:12 PM
  5. Off the wall... down and dirty...
    By Dave's_Not_Here in forum MetalWork Discussion
    Last Post: 12-05-2006, 11:55 PM
