587,207 active members*
3,056 visitors online*
Results 1 to 10 of 10
    Jul 2008
    27
    Alarm 233 on Haas VF-1
    hi all,
    I got a problem with VF-1. Alarm 233 "Jog handle Cable Fault" appear, the spindle stop. If press Reset button, the machine will normal running, but get alarm again.
    How can i fix it? I need change the new Jog Handle Knob? Pls advice.
    Thanks!
    Jan 2007
    107
    That is going to be one of two things. The handle (pulse generator) Or your RJH cable
    Jul 2008
    27
    thanks Bryan33,
    Can you help me how check cable is good or fault?
    Feb 2010
    1184
    Are you referring to the remote jog handle or the Jog handle at the control?
    Apr 2010
    200
    The VF-1 doesn't have a remote, does it?
    Apparently I don't know anything, so please verify my suggestions with my wife.
    Jan 2007
    107
    You can get a RJH on any VF machine
    Jul 2008
    27
    I just have Jog Handle at Control Panel. Is it get some problems?
    @Bryan,
    I will try replace a new cable, feedback later.
    Thanks all!
    Jan 2005
    122
    Any update on this? I intermittently get the 233 alarm. It only happens when the mill is sitting idle.
    Jan 2007
    107
    email me at [email protected]
    I need the sn so I can pull up the cable and get you the info on it.
    Jan 2005
    122
    Brian,
    Did you get my email?
  1. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  2. Alarm 157 Haas VF3-SS
    By rshields21 in forum Haas Mills
    Last Post: 12-09-2011, 09:03 AM
  3. HAAS VF8 ALARM 971
    By Supafly in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-08-2010, 12:02 AM
  4. Haas VF2 ALARM 127 &115
    By grease in forum Haas Mills
    Last Post: 10-18-2007, 09:31 PM
  5. Haas alarm 165?
    By UBRacing in forum Haas Mills
    Last Post: 07-08-2007, 05:43 PM
