603,979 active members*
1,365 visitors online*
Thread: Alarm code
    Jan 2009
    4
    Post Alarm code
    I need help with a 2000 supermax rebel 1 w/Fanuc O-M control. I get a alarm code 1024 and 1015 when i try to do a tool change the machine is new to us and have no books. the changer moves the pot drops down but the arm does not move. the z is in home pos. and spindle is inline. Any help would be great. thanks
    Oct 2008
    106
    ATC Problem
    1. You may need to call G91 G30 Z0; before you call M6
    2. Is it a M19 LED on the panel you can see its finish.
    3. if the G30 position and the M19 OK then you need to check the pocket up & down proximity switch.
    Ahn Vuong
    Jan 2009
    4
    alarm code
    I have called out call G91 G30 Z0 and m19 I will have to check the pocket up & down proximity switch and get back to you on that. Thanks for the help Ahn Vuong.
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Alarm code 123 VF-3
    By Nova in forum Haas Mills
    Last Post: 06-16-2010, 08:48 PM
  3. Alarm code 203-6
    By meszarosg in forum Okuma
    Last Post: 10-11-2008, 09:17 PM
  4. Mori sl-15 with a new code 100 p/s alarm
    By bob1112 in forum Fanuc
    Last Post: 07-10-2007, 05:32 AM
  5. Alarm Code 3058
    By AdamK in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-27-2007, 04:58 AM
