Alarm EX0097 Panel I/O
Control is on a Mori mid to early 80s can't read the data panel well enough to get the details. Boots up as MSC-200 for the control type, but is a Fanuc control.
Alarm is an EX0097 Panel I/O with Japanese characters below that. Don't have this alarm code in the limited books we have for the machine.
Does anyone know where to trace this alarm to?
I'm thinking I have a problem on the DC ground side, but I'm not sure. We've checked all the cable connections in the electrical cabinet and inside to control. When the machine is powered up it is OK. The soft keys, key pad, screen selection keys are OK but if you hit one of the keys to switch from Memory to MDI or the home keys etc it will throw this alarm. Power down and power up clears the alarm. It is intermittent so the keys will work at times. The machine will also throw the alarm if left idle or at the end of a cycle not associated with any input.
Any help or idea would be appreciated.
Scott
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
