588,666 active members*
6,776 visitors online*
Hybrid View
    Dec 2005
    7
    alarm! spindle overcurrent
    a bridgeport with funac control, open the panel, turn on the power, no2 contactor trigger then release, no.1 and no.3 no action(no.1 low speed , no.2 high speed, no.3 switch). can not eliminate the alarm, anybody can help me out. do i need to take the motor out and check it since i cant run it, cant check the current.
    Dec 2003
    24222
    Not enough information!!
    What Fanuc control? is it DC or AC spindle? is it a Fanuc spindle? If so there should be a LED readout on the Spindle controller which will indicate fault.
    What is the alarm on the screen?
    Al.
    Albert E.
    Nov 2004
    3028
    Is the spindle drive Fanuc or Yaskawa?
    Is it a Fanuc 0M control or a 21iM control?
    George
