588,453 active members*
5,033 visitors online*
    May 2010
    63
    Alignment or What?
    I notice this only when I do a pocket or facing the table, but it seems like some type of alignment is slightly off. I'm also thinking it could just be a result of the way end mills are made.
    It's only a slight very thin line but I'm wondering why it's only on the top of the cut, even smaller on the bottom, and not on the left, only a shadow on the right(means I can't feel it )
    Any Idea's?? I'm pretty sure the routers very level and this was a real soft cut into a cutting board to test and put a picture here.
    This was a 3/8ths end mill but it happens with the 1" for the table facing also.
    Thanks in advance.
    Chris.....Everyday is a Good day.....if you wake up breathing!
    Joe's 2006, Mach3, Vectric software.
    Dec 2008
    292
    I would start by making sure the end mill/bit is perpendicular to the table. If it isn't, one side of the cut is higher than the other depending on which way the end mill is tipped.
    Don
    May 2010
    63
    Thanks Don, I was looking at that a little last night and I think some adjustments are in order.
  1. Alignment of castings
    By Ashish B in forum CNC Machining Centers
    Last Post: 04-13-2017, 05:25 PM
  2. Red dot alignment
    By Magritte in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-08-2011, 09:29 AM
  3. turret alignment on sl 40
    By cherokeechief79 in forum Haas Lathes
    Last Post: 03-23-2010, 11:56 PM
  4. VF2 Tool Alignment - HELP!
    By Dennis Fletcher in forum Haas Mills
    Last Post: 03-15-2010, 07:10 AM
  5. Alignment
    By Megaplow in forum Syil Products
    Last Post: 03-20-2008, 06:58 PM
