I have a alliant mill with a 3hp motor. When i pulled it apart because of a noise, i found the key was bad in the motor shaft and the key in the spring loades or moving shiv. There were not any plastic sleeves between the shiv and the shaft or the key. does anyone know if there is supose to be a sleeve or something between the two so it can slide on without wearing out the shaft or key.
