Hi everyone, I have a ALPHA Harrison 1550s lathe that I am having a few issues with at the moment. The Lathe seems to have an issue with the Fanuc controller and will automatically move itself in the x axis and you cannot stop it unless you hit the emergency button. The coolant pump will also turn itself on and you cannot turn it of. The feed percentage dial is not working and lastly the most worrying issue is that the cycle stop button doesn't work anymore, I am having to stop the machine with the emergency stop button. All of these problems have appeared at the same time after starting the machine this morning. Does anyone have any idea of what could be causing these issues? Help would be greatly appreciated.
