587,997 active members*
1,544 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Alternate flank infeed-cutting acme thread with grooving tool
Results 1 to 4 of 4
    Aug 2016
    19
    Hi, We cut a lot of internal acme threads, at the moment on an NEF 520 heidahan control.
    We use a grooving tool, and can define the angle. It then progressively passes up each side of the thread to form it.
    We have tried this on fanuc, but cannot get the code to work. We can get it to go up one side, but in the 'P' value, we cannot get a negative angle.
    Is there any way of doing this, other than doing the maths on the positions that need to be cut?
    (Doosan 400L, fanuc 18it)
    Dec 2008
    29
    Re: Alternate flank infeed-cutting acme thread with grooving tool
    A CAD-CAM software would take care of that.
    Feb 2006
    1792
    Alternate-flank cutting on Fanuc is possible with 1-block G76 format, not with 2-block format.
    Aug 2016
    19
    And would that cut a trap. thread in the way I want?
    - - - Updated - - -
    I can't see any way to do it in fusion, or hsmworks
  1. Replies: 0
    Last Post: 02-03-2017, 11:38 AM
  2. G76 MODIFIED FLANK INFEED
    By jmk021083 in forum Fanuc
    Last Post: 07-14-2016, 09:34 PM
  3. program using g76 alternate flank infeed
    By girishnadkarni in forum Fanuc
    Last Post: 07-01-2008, 12:10 PM
  4. THREADING WITH G76 ALTERNATE FLANK INFEED
    Last Post: 06-03-2008, 06:59 PM
  5. acme with grooving tool 2d or 3d?? help
    By jone in forum Mastercam
    Last Post: 04-16-2007, 12:41 AM
