587,188 active members*
4,262 visitors online*
Results 1 to 6 of 6
    Sep 2006
    10
    aluminum shape cut 0.05" thick
    I need this shape and another one slightly smaller cut out of 6061-t6 aluminum.
    .05" thick. Two of each.
    I will supply a dfx file in the units of your choice.
    ---The dimensions are shown to the 4th decimal place but the closest 0.000" is fine-----
    Apr 2006
    76
    All you need is a printer, some tape and a pair of snips.
    Sep 2006
    10
    The parts need to be made by machine. The parts are incorporated into the construction of skis with tight tolerances.
    Sep 2012
    24
    what is this used for? what tolerance do you require?
    Sep 2006
    10
    They are for the base of skis, at the tips
    Here is a picture of what the part will look like.
    The tolerance is .005" I guess.
    Sep 2006
    10
    Thanks to all who replied and Pm'd but the part has been put on hold.
  1. My 1/2" Thick Aluminum Build
    By kolias in forum Open Source CNC Machine Designs
    Last Post: 12-10-2012, 06:58 AM
  2. Replies: 5
    Last Post: 09-12-2012, 03:09 PM
  3. RFQ - Aluminum 0.090" thick fins, Water or Laser cut
    By jhuebbe in forum RFQ (Request for Quote)
    Last Post: 05-14-2011, 07:51 PM
  4. Looking for thin aluminum, 0.020" thick, sheet
    By laka in forum MetalWork Discussion
    Last Post: 06-26-2009, 06:32 PM
  5. Best Mill for 1" thick Aluminum?
    By gtslabs in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2004, 04:37 AM
