586,058 active members*
4,019 visitors online*
Thread: am fred
    Sep 2018
    am fred
    Hello, i have been using a chinese laser machine for a while but suddenly after connecting the rottary axis, the it stopped moving along the y-axis, i have checked all the connections are fine, when i move it home manually after powering it of it accepts, when i drive it with the x & y controls using the soft ware it accepts. what is puzzling me is thwt it doesn't home along the y-axis instead it makes noise,what could be the problem and its solution. thx
    Sep 2018
    36
    Re: am fred
    Hi Fred, I think I can help you with this problem. However, can you provide a better explanation? It's not exactly clear what your problem is with the rotary device. Also, have you ever used the rotary device in this laser before or is it the first time?
    Danny
    Engraving Machines Plus, Corp.
    (321) 821-7774
    Melbourne, FL
    Engraving Machines Plus Logo
    Jan 2008
    940
    Re: am fred
    Is this a Rudia controller if it is go into the laserworks software and in the box on the right go to user and scroll down to rotary see if it is yes or no it should be no
  1. Georgia Fred Signs in !
    By wwdusty in forum Joes CNC Model 2006
    Last Post: 11-26-2007, 07:31 PM
