603,365 active members*
3,612 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > AMADA LC2415 A3 3KW NEED PARAMETERS
    Jun 2018
    3
    Hi! Can someone send me all parameters for this machine, what need to know, CNC Fanuc 160i-L, resonator 3kw, year 1999, model LC2415 alpha3. Issue is my power lost suddenly and cnc only stays at start point when it says GRAPHIC IS READY BOOT START. When that text came i cant do nothing, not even backup, so i have to took all cables and cards off and put back, but i lost everything. Now when its cleaned it sometime stays on boot text and in good luck i can manage to get boot menu, but i dont have nothing to put in it.. little bit ****ty situation i think. What can cause this problem?
    edit-- Problem starts when machine shut down resonator and operating keys not responce nothing. Monitor stays on but all other was tilted.. I managed get machine starting and think that it was only electric spike, but it stays running couple minutes and again shut down.. i tryied couple times waking up it but then i have to drop my gloves cause nothing cant do anymore..
    Jan 2005
    15362
    Re: AMADA LC2415 A3 3KW NEED PARAMETERS
    Quote Originally Posted by Henkkali View Post
    You need a Line Reactor and or EMI Power Filter to protect your machine, it sounds like it has been damaged from the power cut / loss, check the machine Grounding / Earth connections are in place also
    Mactec54
  1. Amada LC2415 Alpha 2 Ladder Password
    By SDesigns in forum Fanuc
    Last Post: 03-30-2018, 07:14 PM
  2. Replies: 0
    Last Post: 03-15-2018, 01:58 PM
  3. Post Processor Files FOR AMADA LC2415 A2 1998
    By Karimtn in forum Post Processor Files
    Last Post: 12-03-2017, 09:48 AM
  4. Document for Amada LC2415 Alpha II
    By Karimtn in forum Machinery Manuals / Brochures
    Last Post: 12-28-2016, 08:46 PM
