586,032 active members*
2,847 visitors online*
Results 1 to 6 of 6
    Mar 2019
    4
    Cool Amada PEGA344 Override alarm
    Hi, My Amada M6B punching machine , alarms with "Overide light" Has been tried many ways to reset it, but won't worked.
    Any suggestion would be greatly appreciates.
    PJ.
    07/07/2020
    Jul 2020
    7
    re: Amada PEGA344 Override alarm
    In the middle of the X-axis carriage, the override detection system is assembled and it is related to the Y-axis position. So you have to check both the area. you have to check the input signal in diagnostic no 40.2 & 40.3 for left & right override, 42.7 for override X, 42.4 for override Y external slow down, and according to the electrical schematic you can find the solution.
    Regards,
    Deepak
    Mar 2019
    4
    Dear Deepak,
    Thank you so much for your kind suggestion, will check it out and see what's up.
    One thing , in diagnostic No, 036 parameter 4 (OVC Override cancel) I could not set it to 0.
    Best regards,
    PJ.
    Jul 2020
    7
    Quote Originally Posted by 375jdj View Post
    Dear Deepak,
    Best regards,
    PJ.
    you can not change it because it is getting high and low from the limit switch or proxy operation. You can just see the value of the address and bit and you have to understand accordingly the switch or proxy is operated or not.
    Mar 2019
    4
    Quote Originally Posted by Deepak83 View Post
    Dear Deepak,
    Thanks for clarification. Will go to see the diagnostic no 40, I supposed .2 or .3 is a position of parameter 0~7. Am I right or wrong.
    Thanks,
    Pj.
    Mar 2019
    4
    Dear Deepak,
    Thanks,
    Pj.
    Dear Peepak,
    After checking with the limit switches. I found only diagnostic 42.7 is responds (I-, another number 40.2,40.3,42.4 all are inrespondes. Where should I looking for.
    Tks,
    Pj.
  1. Spindle Speed Alarm Override Needed For Drag Knife Operation. Syntec 6 MD cnc
    By IsaacBuilt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2017, 07:26 PM
  2. AMADA RG-80 NC9-EX II alarm 100
    By Scarecroe in forum Uncategorised MetalWorking Machines
    Last Post: 12-23-2015, 08:50 PM
  3. Replies: 5
    Last Post: 11-02-2012, 03:37 AM
  4. Replies: 1
    Last Post: 01-27-2012, 04:46 PM
  5. Amada Pega344 g-code
    By mnadi121 in forum G-Code Programing
    Last Post: 05-28-2011, 09:17 AM
