587,698 active members*
3,252 visitors online*
Results 1 to 5 of 5
    Sep 2010
    Amada PRESS BRAKE HFT 220-3
    Machine no longer working and when i click on any button nothing happens
    Thank you in advance for any advice or information
    sorry for my English
    Aug 2010
    hello,
    first of all, what cnc is built on the machine ?
    well, you get started the main pump ?
    have you check the emergency buttons, maybe one is pressed...
    check also the fuses in the control cabinet...
    if you have a cnc on the machine, you get any error message or any other warning message ?
    thats all for now...
    regards
    Sep 2009
    7
    it can also be the small KEY on the monitor (keyboard protect ON / OFF)
    or simular...
    Dec 2011
    Ok, we have an Amass at work just the same prob happens all the time. With ours we discovered there was a short in the wires from control box to circuit board. As the control box can be adjusted to the ops needs it develops short in wires due to movement. Check there. If not then check your files through bendcad if you have it, files can cause errors unknown if written wrong or have incorrect punch and die info.
    Dec 2011
    Amada, sorry. Auto correct is on.
  1. Amada Press Brake Controller problem
    By jamesbond007 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2018, 03:38 AM
  2. Need Advice on Purchasing Amada Punch Press
    By robd19 in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2010, 05:28 PM
  3. Amada brake press controller nc9 r
    By maplesiport in forum Controller & Computer Solutions
    Last Post: 07-15-2010, 11:32 PM
  4. Selecting Press for home shop press brake
    By tikka308 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2009, 05:51 AM
  5. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
