I think you have to decide if you want any servo actuated devices? via either servo, stepper motors or servo valve?
So far the devices you have linked to appear to be simple on/off not requiring any servo action, If so I don't think you need the complexity of a numerical controlled system.
A PLC would probabally do all you want to do, most even have a simple servo or stepper option anyway.
If an operator interface is needed, there are several simple two or three line displays with keypad that offer simple input to the PLC.
A closed loop servo system, whether motor or valve operated, implies feedback, PID loop for e.g., which again PLC can do.
There are many PLC options available and probably much depends on your present level of expertise and the requirement of the application?
Al.
Albert E.
