I think I'm in way over my head here so I could use some help!
My idea is to build a cnc tool platform for various types of manufacturing and machining jobs.
I want to create a cnc router that can detach from a lower base and mill objects larger than the machine's footprint by simply moving the machine after each job. It would have a detatchable spoilboard and be able to reach below bottom of the upper frame for concrete milling etc.
I also want to use this same platform as a large scale 3d printer.
I have 1 meter ballscrews and fully supported 16mm linear rails and I am hoping to maximise build area using these parts.
I hope to be able to mill .5 inch aluminium plate. 7075 would be nice but I'll settle for 6063-4 (I forget which is which)
To top it off I have already run over my budget so I have to finish it on the cheap.
Yeah, I want it all, I know...
So far my idea is to build a full cnc machine that sits on top of a table with extended range on the z underneath the upper cnc machine. This would mainly be for z height when 3d printing but some of it could be used for milling things that don't fit in the upper part's z build height.
Here is my frame layout so far.https://drive.google.com/open?id=0B9...tnLUxacmM0Q2Y4
So, onto my many questions.
1. Is 20-4040 too flimsy or will the added rigidity of fully supported 16mm rails be ok for milling aluminum?
2. Will those aluminum joining plates do the trick?
3. Are there cnc transmission gearboxes for changing speeds?
4.Can I double up these stepper motors on one of these drivers AND use it with the smoothieboard?
5.That's not helpful Gerry...
6. Where can I get gantry plates cut that wont break the bank?
7. What thickness and material should I use for the gantry plates?
8. Should I scrap the oper box and replace it with welded steel s-3 i beam?
9. How much would it cost (ballpark) to get those ibeams welded into a frame and drilled so I can bolt everything to them?
10. Would that be enough?
11.What kind of speeds should I expect to be able to get out of this?
12, (I'm aiming for 200mm/s under no load for 3d printing applications) What do I need to change to get there?
13. Is there a swwet spot for motors that can run fast under little load but still provide enough torque for what I need to mill?
14. In the current frame design, where should I put all that extra 20-2020 and 20-2040 to stiffen up the frame the best?
16. Is that power supply enough?
17. I currently plan to use the linear rails on x and y axis and the openbuilds linear actuator in the bottom box (attatched to the crossbeams). Is that the best layout or should I consider something else?
18. Are there any other major parts that I need that I haven't already got? (Besides gantry plates)
19. Any parts I should return for something better? (I have about a week left in my return window)
I don't expect anyone to answer all of these questions but if any experienced people could pick one or two to answer that would make my day.
Thanks for any help you guys decide to give me.
My parts list so far.
Stepper Driver:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Stepper:
3 of Nema 23 CNC Stepper Motor 2.8A 178.5oz.in/1.26Nm CNC Stepping Motor DIY CNC Mill
NEMA 23 Stepper Motor - OpenBuilds Part Store
Spindle and Controller
Spindle Power Supply
Linear rails x 4
Linear Bearings x 8
Ballscrews x3
Framing
14x 20-4040 2440mm
6x 20-2040 2440mm
6x 20-2020 2440mm
Hardware:
L Joining Plate x 25
T Joining Plate x 25
Cross Joining plate x5
Tnuts:
M4
M5
M5 Economy
M5 Drop in
M4 Bolts
M5 Bolts
Corner Brackets x 50
Other Corner Brackets x 25
Internal Channel Anchors x20
Interface Board/ Controller Board
GUI Control Panel
Main power Supply
Linear Actuator Bundle
http://openbuildspartstore.com/c-bea...tuator-bundle/
Frame Layout.
Future Planned Addons
Vacuum Forming
4th axis and tailstock
Laser Cutter
3d printer.
