603,965 active members*
3,351 visitors online*
    Jan 2012
    AMC B30A40 Interface Card
    I have an AMC B30A40 drive that I just got from their wonderful university outreach program. I am trying to figure out the easiest way to run it in constant torque mode. I am currently using LinuxCNC, but I'm a little unsure of what hardware I need to interface the PC to the drive. I know that the drive uses a +/- 10v control signal, is there a cheap solution to just running a single drive in current mode? I really don't need anything fancy, just my servo maintaining a constant torque.
    Jul 2003
    1766
    Short of making something your self - I would look at the mesa 5i25. The 5i25 + 7i77 that would be $239ish for the kit.
    http://mesanet.com/
    That gives you
    PCI Anything I/O – 34/ I/O bits LX9 Spartan6 FPGA
    6 axis analog servo interface - 48 isolated I/O for 25 pin Anything I/O
    And that is expandable.
    I don't know if you can get much cheaper than that. (but may be overkill for what you are doing)
    You could do a 7I43-P with a 7i33 which gives you 4 analog servo interface and some unisolated i/o for $79+$69 but that is a parallel port interface instead of pci.
    Other supported hardware
    http://wiki.linuxcnc.org/cgi-bin/wik...orted_Hardware
    sam
    Jan 2012
    I can use a parallel port, serial port or pci. I could also possibly build something myself if it wasn't too complicated. I read something about using a DAC with some solid state relays on this forum, but I'm not sure where to find a cheap DAC or how to know if it would be appropriate. That Mesa 7i43-p and 7i33 solution sounds very promising. Honestly, if I could just set the current/torque, I don't even need to interface to the computer if there is some standalone hardware that will do it, I just assumed it would be easier/cheaper.
  1. C10 interface card PS
    By Vatorman in forum CNC Machine Related Electronics
    Last Post: 05-29-2011, 04:41 PM
  2. Lpt interface card
    By abbe in forum Open Source Controller Boards
    Last Post: 05-18-2011, 09:38 PM
  3. C10 interface card to g540
    By Vatorman in forum Gecko Drives
    Last Post: 05-08-2011, 07:11 PM
  4. Fanuc 11M serial interface card
    By greenery_fr in forum Fanuc
    Last Post: 03-23-2009, 02:57 PM
  5. New Port Interface (Breakout) Card
    By Torchhead in forum News Announcements
    Last Post: 10-27-2006, 09:59 PM
