As we have established b4, I have the same servos as you. I drive mine at 3;1 ratio and it works fine. The only reason you would want to reduce that further is to get more torque and greater resolution.
If you are new to this, you may be thinking, as I did, that the gearing down factor was a crucial part of the project. The software you use will play a part in terms of setting the maximun speed. Esentially any reduction between 3;1 and 9;1 should be fine. The main aspect of knowing if you have a good reduction is the size of your router, and its ability to cut at the desired rate. Once you play with the software configurations and understand what every thing does, and how it all interelates, the penny will drop and you will understand that the gear ratio is not as crucial as you might have first thought. I know you want to be told a definate number, but trust me if you go for anything between 3:1 and 9;1 you will be right
Being outside the square !!!
