603,348 active members*
3,410 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Angle Iron Vs. Angle Aluminum for V Bearings
    Feb 2013
    27
    For V bearings, I would have assumed that angle iron would be better but in all the build videos and pictures I see, everyone seems to be using aluminum.
    Can someone please explain the reason?
    Thanx, Alan
    Jun 2010
    4259
    Re: Angle Iron Vs. Angle Aluminum for V Bearings
    I've seen smooth aluminium angle, but I am not sure I have EVER seen sufficiently smooth steel angle.
    Cheers
    Roger
  1. Angle Iron and Tubing
    By rodder in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-28-2012, 12:48 PM
  2. Angle iron
    By kadamsflk in forum Mechanical Calculations/Engineering Design
    Last Post: 11-09-2009, 01:27 PM
  3. Angle Iron Deflection ?
    By Gads in forum Mechanical Calculations/Engineering Design
    Last Post: 04-26-2009, 09:15 AM
  4. Aluminum angle and bearings
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 03-30-2009, 08:52 PM
  5. New Truck Design - Angle Iron & Skate Bearings
    By datacop in forum Open Source CNC Machine Designs
    Last Post: 07-12-2006, 04:24 PM
