Hi All,
well I have read hundreds of post and looked at many pictures and I still cannot figure out how to mount angular contact bearigs. So, I made up a drawing of what I am confused about. I hope it is clear, A and B version. On A, I have seen shims that are placed between the two AC bearings and a thrust washer to squeeze everthing only on the inside races? The bearings are recessed into the mount.
On B, there is no shims, the bearing mate against each other. The bearing portrude out of the mount and a big thrush washer squeezes the entir bearing surface.
Does this make sense?
Do I have it right?
How much torque for the preload?
Does anyone have good detailed schematics or pictures to add to help me?
Does the nut and thrush washer rotate with the shaft?
Thanks for the help
Rene
