587,691 active members*
3,681 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > angular contact bearings face to face??
    Dec 2004
    37
    Hi there...I was hoping someone could direct me in the proper way to pair the angular contact bearings. I have read about face to face and back to back. I have attached a pic of the bearings I have. At the risk of sounding dumb, how does one determine which is the face and which is the back. I have paired them both ways and one way allows the bearings to roll independently of each other while the other forces the bearings to roll together. Any help would be greatly appreciated.
    Thanks...
    Mar 2003
    4826
    One edge of each race is thin, the other is thick. The thick side is the load-bearing side of the race. You will notice that the thick side of the inner and outer races of one bearing oppose each other.
    Of course, you always want to orient the races so that you have "thick facing thick" or "thin facing thin" in order to obtain any kind of factory preload on the bearing pair.
    As to how you should pair them, it really depends on how you plan on retaining them in the housing or on the shaft. If the retainer is a nut on the shaft, then you want the outer races to be "captive" to the inner races, so this means that you orient the pair with the thick side of the inner races facing out, one against the shaft shoulder, and the other against the nut.
    If the retainer is a nut in the housing, pressing the outer races together, then the opposite orientation would apply.
    First you get good, then you get fast. Then grouchiness sets in.
    Dec 2004
    37
    I understand...Thank you so much......In my application the bearings will be retained by a nut, so thick side of the inner races facing out trapped between the shoulder of the screw and the nut. Thank you so much for quick and thorough explanation......
    Sincerely,
    Chris
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. New Spindle Design, feedback plz!
    By h3ndrix in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2014, 09:37 AM
  3. Ball screws and angular contact bearings?
    By dowling177 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-10-2013, 10:25 PM
  4. Taper Roller Bearings VS Angular Contact
    By mxtras in forum Linear and Rotary Motion
    Last Post: 10-12-2007, 05:32 PM
  5. Ball screw angular contact bearing block
    By dowling177 in forum DIY CNC Router Table Machines
    Last Post: 03-15-2005, 09:03 AM
