587,989 active members*
4,910 visitors online*
    Jun 2010
    Anilam 1400M contoller
    Hi All,
    I am trying to get an Anilam 1400M controller working on an Ajax Premier 1300 CNC milling machine, although 15 years old it has very little work done, it has not been used for 5 years. The problem is that when the machine is powered up the the 'control s/w' frame appears, with 'halted' displayed on the frame and 'servo disabled' lit on the button panel. Pressing 'servo reset' does not work in fact nothing works. The 'figures / numbers' for the encoders all zeros, moving the X,Y or Z tables manually, the ' figures / numbers' do not change, I checked the outputs from the encoders as far as the DSP card, they are ok. I have sent a 'dump' of the s/w to Anilam, who say it looks ok. It appears as if the DSP card may be faulty.
    Any help would very much appreciated.
    Thank you,
    Sean.
    Jun 2010
    hello wes sorry I can't help but I have a problem with my control which is the same of yours
    I have missing the autoexec.bat and config.sys and i was wondering if you can send me those
    thanks
    regards
  1. Anilam 1400m
    By quadbob in forum Controller & Computer Solutions
    Last Post: 01-08-2013, 11:32 PM
  2. Contoller PC
    By oknups in forum Tormach Personal CNC Mill
    Last Post: 02-03-2012, 11:45 PM
  3. Anyone know Anilam 1400m very well?
    By Mikey69 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-03-2009, 03:53 PM
  4. Networking an Anilam 1400M
    By iiweeldman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-18-2009, 03:22 AM
  5. anilam contoller
    By barnesy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-29-2006, 10:30 PM
