I hope you can give me some advice on the following G-Code problems.
I have a Kent JM-450 small VMC with Anilam 6000 M Controller which I bought new.
When I test run my program I get: "G52 is an invalid G- code" It only appears in first block N15G0G40G52G70G80G90 Should I substitute another G-code for G52?
When I change G52 to G53 then I get the message: "Missing 0o! from Error [Block 15]" I’m not familiar with "0o" ...can you tell me what it does? Where do I place it on N15?
What other G and M codes does the Anilam 6000 M have issues with and what should I replace them with?
Thank you in advance for any guidance you can share with me. I will work on converting the file from a G-Code file to a .TXT file so I can attach it.
Jim in NH
website: HOT GRIPS-heated grips, hand warmers, grip warmers
