Hello!
I've been building my own laser engraver and it works! :cheers:
But alignment of the mirrors is troublesome. The first lens in front of the laser is aligned, machine in Y=0 gives exactly the same mark as machine in Y=650 (millimeters) on the second mirror.
So the first mirror should be fine!
Now to get the second mirror hitting the laserhead:
Y=300 (middle of the Y axis)
put the laser head in x=0, burn, put the head on X850, ajust and there you go, mirrors aligned.
But now it gets weird:
machine Y=0 X=0 burn 1
machine Y=300 x=0 burn 2
machine y=650 x=0 burn 3
Al the 3 markings (on the laserhead!) are in the same location. So thats good.
Here it goes wrong:
machine Y=0 X=800 burn 4
machine Y=300 x=800 burn 5
machine y=650 x=800 burn 6
now the markings on the laserhead are way of, 5 mm each.
Burn 4 is way to the left.
burn 5 is "center" and good to work with.
Burn 6 is way to the right.
You can understand that I'm losing lots of power and I can not find the problem!
Can you guys give any sugestions?
Jacala,
The Netherlands.
