587,791 active members*
3,421 visitors online*
Results 1 to 5 of 5
    May 2019
    Anodised aluminium and 3W laser
    Hi
    I have recently acquired a 3w 450nm blue laser engraver with the hope of using it to engrave pet tags. I have tried engraving a couple of anodised aluminium tags and the laser seems to successfully burn the anodised layer, however the result is very dull. Was I wrong to expect it to show the metal underneath and if not how can I make this happen. Do I need a different tag material? Thanks. Rob
    May 2018
    35
    Re: Anodised aluminium and 3W laser
    Hi Rob,
    It's better to fabricate the metal with a fiber laser with 1064nm wavelength.
    https://youtu.be/KFacSJsvgS4
    Mar 2003
    35538
    Yes
    This is about all you can expect.
    https://jtechphotonics.com/?p=2687
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2019
    Thanks for the replies guys, I have had a re-think on the whole laser thing and will look at a more powerful at a later date when I have the funds.
    Nov 2010
    787
    Quote Originally Posted by robdl1981 View Post
    Hi
    3w 450nm blue laser is a toy, not a tool for job.
    CNC lasers, constructions, service
