![Quote](images/misc/quote_icon.png)
Originally Posted by
metalmayhem
The mill seems to be running well and holding position , the only exception other than my spindle issue is that the mill is picking up noise and tripping the reset mid run . The status doesn't show anything as tripped or any info as to what happens , so I'm assuming it's picking up noise from somewhere . The mesa card was a bit of a tight fit , and after swapping into another slot I hoped that it was an issue of the card not being seated fully . Even in the other slot it is doing the same thing at random times . I'll do a bit of tweaking and I should be able to eliminate the problem .
It would be nice if novakon was to take the time on the few machines they have and offer up configs for linuxcnc . I've always been a big fan of mach 3 but newer and better software's are going to be the death of it . The conversion to uccnc was nearly flawless aside from a few tweaks , and I had it running parts within 1/2 hour . Uccnc ran the mill well but there were a number of things I didn't like , it's not to knock it , it's just not for me . I'd have kept running it except for the fact i have other machines running pathpilot and i love that setup for the most part . The only complaint I have about pathpilot is the inability to change offsets in between cycles , unless I hit the stop button
