I'm using BobCad V23. Been trying to figure out how to center a letter on a 3 1/2" x 3 1/2" block. The BobCad demos show that in the text mode if you don't use the drag option the text will automatically dead center on XY. This isn't happening. The text dead centers above XY which won't work as well for me. I'm trying to use scraps up to make these blocks rather than starting with a full sheet. Should I not use the text option to create this? Trying to make childrens blocks with the alphabet centered on it.
