Thanks to help from this forum I’m getting closer to having our SL20 up but I’m still having a problem with this and have a couple of questions about the instructions on the following page from the Service Manual:
Turret Motor Coupling Adjustment
1) Remove the sliding tool changer cover.
2) Go to Setting 7 and turn off the Parameter Lock. Go to Parameter 43, change
“Z CH ONLY” to “1”.
3) Loosen the turret motor coupling clamp screw closest to the motor.
4) Press the ZERO RET key, then the A key, and the ZERO SINGL AXIS key. This will cause the motor to go to the first encoder Z pulse.
5) With the servos on, move the turret motor coupling back and forth to find the center of its backlash, and torque the clamp screw as close to the center of the backlash as possible.
6) Change Parameter 43, “Z CH ONLY” back to “0” (zero).
7) Press the ZERO RET key, A key, and ZERO SINGL AXIS key. This will home the turret at tool #1.
8) Press the EMERGENCY STOP button and turn the turret motor coupling back and forth to verify that the backlash is centered.
9) Go to Setting 7 and turn on the Parameter Lock.
10) Replace the sliding tool changer cover.
For Step 2, I have to turn off the servo motors with the e-stop before I can change Parameter 43. For Step 4, do I turn the servos back on?
If I do then the servo motor just spins because the coupler is loose. If I leave the e-stop on I get an "e-stop pressed" error. The manual was probably written with a certain amount of assumption that the factory trained tech guy would know some of this, but I don’t. Thanks for your help.
