588,227 active members*
4,063 visitors online*
    Oct 2006
    735
    Another Variable speed question
    My R2V3 has the air speed adjust on a Boss 10 display.
    the increase and decreas properly activate the adjuster how ever the F speed prompt on the display does not update during the process.
    only time it updates is between deactivation of the spindle motor, jog Z a bit and start spindle motor again and the number changes (assuming while the spindle motor was moving you hit increase or decrease)..
    Just looking for some things to check. Already verified continuity between the pot on the front of the machine head and the connector.
    Any other ideas?
    b.
    Oct 2006
    735
    After playing more with the boss 10 display it seems that pattern is true and that section of the screen with the S: spindle and the F: for current feed speed only update/refresh after an axis move. Call me crazy for thinking it would update after hitting the increase/decrease buttons..hehe
    b.
  1. variable speed motor
    By Astroguy in forum Benchtop Machines
    Last Post: 05-25-2007, 11:13 PM
  2. Add variable speed to router?
    By andy_ck87028 in forum DIY CNC Router Table Machines
    Last Post: 04-16-2006, 08:42 AM
  3. variable speed drive is it to big
    By 69owb in forum Servo Motors / Drives
    Last Post: 01-02-2006, 11:44 PM
  4. variable speed dc drive
    By DragnsBane in forum CNC Machine Related Electronics
    Last Post: 02-09-2005, 03:07 AM
  5. variable speed???
    By turmite in forum CNC Machine Related Electronics
    Last Post: 03-27-2004, 08:26 PM
