603,380 active members*
3,762 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Any Cheap and reliable design for a CNC machine!!!!!!
Results 1 to 4 of 4
    Dec 2011
    17
    Hi everybody,
    FIRST METHOD: I have made a cnc machine using MDF and the aluminum rail ball bearing linear system. It is very hard to put together a machine using this method.
    SECOUND METHOD: the linear rail system which very expensive
    THIRD METHOD: linear rail system with aluminum rods and Pillow Bearing also expensive
    Q- DO you have any other thoughts perhaps link of other linear systems for cnc?
    Have a wonderful day
    Attached Thumbnails Attached Thumbnails CNC-Linear-Motion-Slide-System-XYZ-XY-Shaft-Rail-Truck.jpg   linearbearing1.jpg   0323121147-00.jpg
    Jan 2005
    2010
    You do realize that cheap and reliable are polar opposites?
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
    Nov 2004
    245
    V rails like the ones used on the Mechmate.
    EzRouter uses the v rail method too.
    If I make a large anything its going to be with v rails
    Sep 2011
    38
    Re: Any Cheap and reliable design for a CNC machine!!!!!!
    Your options are:
    -Good
    -Cheap
    -Fast
    Pick two
  1. Replies: 3
    Last Post: 02-14-2013, 05:09 PM
  2. SigmaNest _ Reliable for machine plasma
    By quochungcadcam in forum Waterjet General Topics
    Last Post: 12-09-2009, 03:49 AM
  3. New Machine Design book from Alexander Slocum (of Precision Machine Design)
    By toastydeath in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2009, 05:37 PM
  4. Replies: 0
    Last Post: 08-31-2009, 02:38 PM
