Came across this while searching for Micro PIC's, looks like Hyperterminal is used to output a plotter file to a PIC.
I though it might be of interest to someone.
http://cstep.luberth.com/PStep.html
Al.
Al.
Albert E.
This is an attempt to create a serial stepper driver. This guy created a program that breaks down a hpgl file into commands that are sent to the pic which in turn creates a PWM signal for the steppers. This way you are not limited by the max troughput of the parallel port.
EJK
What goes down, should come up.
