588,202 active members*
4,441 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Any Experience with Tapmatic Tapping Heads?
Results 1 to 5 of 5
    Dec 2006
    222
    Hi all; I was just wondering if anyone has any experience using any of the Tapmatic tapping heads on an X2 or other small machines. You can see an example of them here:
    http://shop.ebay.com/i.html?_nkw=tap...=p3286.c0.m301
    I'm looking to do lots of 4-40 tapping in aluminum and these heads seem pretty solid. Any thoughts or experiences? Thanks!
    Mike
    Mar 2007
    51
    I have a small 30x tapping head. It's working ok on the X2, up to 6mm in Al, a little bit less is steel (about 5mm) due to low torque.
    You will end up with limited space under the tap, so beware of big vices or rotary setup. But for small taps this is a very handy addition.
    Dec 2006
    222
    Thanks, thats good info!
    Jul 2008
    922
    if you buy it used and take care of it, you can tap all your holes and re-sell it for about what you paid for it.
    Oct 2006
    975
    I like the Procunier tapping heads much better than the Tapmatic head. I have seen the Procunier head with collets fairly cheap on eBay. I think there is a better feel for the tapping with the Procunier head than with the Tapmatic.
    Regards,
    Wes
  1. Tormach Tapping Heads Advice
    By cgroves in forum Tormach Personal CNC Mill
    Last Post: 12-22-2009, 01:20 AM
  2. Taps & Dies - Geometric Threading - Tapping Heads - Gages
    By widgitmaster in forum MetalWork Discussion
    Last Post: 01-06-2007, 02:34 AM
  3. How to use this Tapping Head (Tapmatic?)
    By saris in forum MetalWork Discussion
    Last Post: 11-21-2006, 04:08 AM
  4. Tapping heads
    By l u k e in forum MetalWork Discussion
    Last Post: 05-11-2006, 05:00 PM
  5. Tapping heads.
    By Halfnutz in forum Uncategorised MetalWorking Machines
    Last Post: 06-03-2005, 04:27 AM
