I'm interested in making an air engraver to work on my plasma table. Anyone done this and want to share their experiences?
Our shop has an air engraver. Probably wouldn't be too hard to attach one to your table. Most important would be a way of turning it on and off.
Basically the pin is held up in a cylinder with a spring until air is entered. The air pushes the pin down maybe 1/4" until it passes an "exhaust" port and the air pressure is lost and the spring pushes it back up. 50 PSI max will easily mark any type of metal.
Check out this guys build...
http://www.pirate4x4.com/forum/showthread.php?t=887894
Plain of Bill,
I am little puzzled. What is the function of air engraver?
Marking on metal plate ??? Pls advise.
Mongkol
Some folks call it a metal marker and others call it an engraver. I want to use one in making some custom trophies for car shows.
I did find a build on here that has made one folks. I need to get in there and closely read and look at the pictures before starting to make one for myself. The build I found it on is http://www.cnczone.com/forums/showthread.php?t=104978
