603,546 active members*
2,885 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CamSoft Products > Anyone got any basic examples of a program using a subroutine/program?
Results 1 to 12 of 12
    Oct 2004
    198
    I just need to know the correct format to enter.
    Mar 2003
    4826
    Here's the logic I use, take it for what its worth. Its been so long since I wrote it, I forget how to interpret it
    ISTHERE L;\198;\199
    IF\198<1THEN LABEL2 STARTING LINE FOR SUBROUTINE NOT COMMANDED! :[CYCLEBUTT] :EXIT
    ISTHERE R;\198;\199
    IF\198=<1THENr=1 :LABEL2 NUMBER OF REPEATS "R" HAS DEFAULTED TO ONLY 1;14'defaults to one time through the subroutine
    \36=\199 ISPLAY6 \36
    GOSUB Ol;r 'subroutine must be lettered with an "O" firstly, lower case "L" is "O"subroutine number, repeated for "R" number of times
    -----M98
    LOADING \55
    IF\55<1THENEXIT
    REFRESH
    'next code for incrementing the part counter as a repeat counter for subroutines
    \36={\36-1}
    DISPLAY6 \36
    RETURN
    -----M99
    First you get good, then you get fast. Then grouchiness sets in.
    Oct 2004
    198
    Well I gotta say that's way over my head.
    I was hoping like a fanuc ar a fagor where you can have a subroutine inside a normal program, I think I'm a bit set in my ways with subroutines.
    On our Fagor lathe you enter G22 N06.4 (G22 call the subroutine No. 06 and repeats it 4 times) and a bit lower in the program have G20 (start of sub routine) and at the bottom G24 (end of subroutine).
    Sep 2003
    552
    N0001 G90 G80 G40
    N0005 M6T1
    N0010 G43 H1 Z1.0
    N0015 S500 M3
    N0020 G00 X0 Y0
    N0030 M98 P1010 L10
    N0130 G93 M30
    N1010 G01 Z-0.5 F25
    N1020 X2
    N1030 Y2
    N1040 X0
    N1050 Y0
    N1060 G0 Z1
    N1070 X3
    N1080 G92 X0 Y0
    N1160 M99
    Mill example.
    Jun 2004
    487
    Hey,
    This is the simplified version. There are other options you can research later on.
    1. Start by entering the "M98" command, followed by "P" and a label number and then "L" and the number of loops you want to repeat.
    ie: M98 P1234 L5
    This says that you want to run Program 1234, 5 times
    2. On the subroutine, start by entering "O" followed by the label number
    ie: O1234
    3. When you're done with the subroutine, return to the main program by entering "M99"
    4. Tell the main program to stop at the end so it doesn't run the subroutine again.
    ie: M2 or M30
    Here's how it all looks together
    .....regular program
    M98 P1234 L5 (go to sub labeled 1234 and loop 5 times)
    .....more regular program
    M30 (end of main program, don't execute beyond here)
    O1234 (start of sub)
    .... do something
    M99 (return)
    L8er,
    Julio
    Mar 2003
    4826
    In CAmsoft, you can set the function up to emulate any controller synatax you like. But, you have to have some logic in M98 and M99 or calling them won't do anything.
    Sep 2004
    77
    I do my loops using M98 like you showed.
    One thing I would love to do, but havne't figured out, is how to call a subroutine from WITHIN a subroutine. It just doesn't work on CutViewer anyway. Not sure if it works on Mach2 or not.
    Is this disallowed?
    Swami
    Apr 2003
    332
    Hello people,
    Some new faces we see.
    We believe we could help on this one and set a precedent to show you how to help yourself, regarding this topic as well as others.
    Perhaps the best two pieces of advice to handle any topic are:
    (1) In almost every question posed here in CNCZONE the answer is that you can have it any way you want. There is no single way to handle subroutines or almost any question posed for any topic about CamSoft, at least the CNC Professional version. Every one posting their methods for M98,M99 are correct. Simply because it depends on how the system logic is set up by the installer in the G&M code tables. For example, an installer may just not want to bother and use the default industry standard G&M code set, which includes M98,M99 logic already or they can opt to rearrange things to meet their customers needs by customizing the logic for any G and M code. Some customers want backwards compatibility to older formats. Sometimes we think we have seen everything and can't be surprised, but a make or break request comes in time to time that makes us and our dealers thankful for the flexibility of CNC Professional.
    (2) To get the fastest answers use the Search for Solutions button on CNCSETUP. Here you can search for answer like a web-browser, through 130+ megabytes of electronic text, photos and charts even movies. A search on M98 pops up 21 occurrences of page documentation for this topic.
    Some information you'll find is:
    The logic in M98 can be set up for the letters O, P or N or any letter to call the subroutine. Also the number of loops are usually denoted as L but can be P in some cases. There are even pure jumps to other line numbers instead of subroutines that return.
    QUESTION 169
    Can we call a Macro from within another Macro?
    QUESTION 209
    How do we call and loop subroutines in the G code program?
    Below are some examples:
    (Call a simple subroutine and repeat the subroutine 3 times.)
    N1 G0 X0 Y0 Z0
    N2 M98 P1234 L3
    N3 M30
    O1234
    N4 G1 Z-.5 F25
    N5 G0 Z.1
    N6 M99
    (Use a subroutine to loop the entire program 100 times.)
    N1 M98 P1234 L100
    N2 M30
    O1234
    N4 G0 X0 Y0 Z0
    N5 G1 Z-.5 F25
    N6 G0 Z.1
    N7 M99
    (Nested Subroutines)
    N1 G0 X0 Y0 Z0
    N2 M98 P1234 L1
    N3 M30
    O1234
    N4 G0 X1 Y1 Z1
    N5 M98 P5678 L1
    N6 M99
    O5678
    N7 G1 Z-.5 F25
    N8 G0 Z.1
    N9 M99
    Tech Support
    CamSoft Corp.
    (951) 674-8100
    support@camsoftcorp.com
    www.cnccontrols.com
    Oct 2004
    198
    Got a couple more question for you guys (surprise surprise).
    What's the difference between a stepper motor and an active low pulse stepper motor? (how do I tell which I have?)
    Also after I home the machine then move the axes to where I want the home light stays on, what's the best way to ensure when I move from machine 0;0;0;0;0;0 the light will go out?
    Mar 2003
    4826
    I haven't seen your logic of course, but you'll simply have to write logic to turn the light off when the sequence is completed. I'm assuming you are talking about a Camsoft gui "light".
    Sep 2003
    552
    Active high or low stepper is drive dependant (high=motor winding on or low=motor winding on.).
    If your home is actually on the switch you can put the logic in the LIMITS.FIL.
    Anytime a limit or home switch is triggered the LIMITS.FIL is ran.
    If your home is not on the switch you can use ISTHERE logic in the commands G00, G01, JOG.FIL, ect...
    Darek
    Oct 2005
    24
    Thanks this helped me alot with my MillMaster Pro program!
    -truline
  1. Learning to Program CNC Turning Center
    By Farmer in forum G-Code Programing
    Last Post: 09-12-2005, 06:03 AM
  2. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  3. How to cut multiple parts (loop a program)
    By Bird_E in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2005, 09:16 PM
  4. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
  5. G-Code Cutter Comp Program
    By jcc3inc in forum DIY CNC Router Table Machines
    Last Post: 02-27-2004, 05:29 PM
