I'm just getting acquainted with my new CHNC-I and am having a bit of an issue with the hydraulic pump sucking so much air. My relatively small compressor (5.1SCFM) cannot keep up unless I disconnect the solenoid that engages the hydraulic pump.
Is there a control to turn off the hydraulic pump in software/configuration rather than having to disconnect the solenoid? The hydraulic system and cross-slide are an optional feature, so it stands to reason that there'd be a bit somewhere to turn it off.
And what is the rated air consumption for this machine? I've searched the manuals and cannot find a rating (in SCFM), and it is important to know so I can size my new compressor accordingly.
Torin...
