587,833 active members*
3,334 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > anyone knows about Mazak Vertical Center?
Results 1 to 4 of 4
    Jul 2005
    6
    Smile anyone knows about Mazak Vertical Center?
    hi. i have a mazak vtc41m vertical center. it is from 1994.
    i have bought it second hand and trying to set it up. we had some problem with tool changer. we fixed it. now, there is a error msg in Mazatrol controller. it says "Tool select miss operation"
    i suspect that since we have been working on tool changer, we need to reset it. anyone has any idea, how and where i can reset the tool changer? thanks.
    Feb 2005
    35
    I have a Mazak lathe (SQT-15M) and I know that Mazaks are high maintenance!
    This is my first and probably last Mazak. Did you know that MAZAK got its name from KAZAM spelled backwards? If that isn't cheesey, I don't know what is. Just my 2 cents.
    Feb 2005
    376
    Call up tech support, I've had really good success with them. As far as high maintainance goes, I would have to disagree, we're running two mazaks and a fadal, and I'll take the Mazaks hands down.
    Mar 2004
    54
    interesting about the KAZAM remark
    I thought it was because they're made by the Yamazaki machine tool co. ?
  1. Vertical/Horizontal Bandsaw purchase
    By ChrisJ in forum MetalWork Discussion
    Last Post: 07-21-2007, 02:30 PM
  2. Best Vertical Mill?
    By bvandenb in forum Haas Mills
    Last Post: 04-20-2005, 11:47 AM
  3. Cheap vertical mill
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 01-21-2004, 11:50 PM
  4. Vertical Mounted Home CNC
    By Jmtwo in forum DIY CNC Router Table Machines
    Last Post: 07-18-2003, 03:03 PM
  5. Sherline CNC vertical mills
    By cncman2 in forum Benchtop Machines
    Last Post: 04-03-2003, 11:55 PM
