588,377 active members*
8,237 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Anyone using 203V's with Acorn board from Centroid?
Results 1 to 6 of 6
    May 2022
    4
    I have a 4'x4' gantry, 220VAC spindle at 2.2KW with VFD, 4 Gecko 203V's, 60VDC 10 amp drives power, Nema 23 400 oz/in steppers @ 3mh. I have a 10:1 gear reduction for the Z axis. And run the Y with one motor slaved to the other.
    The controller is an Acorn CNC, and I use Vectric Desktop.
    Anyone else have a similar set up?
    Jan 2008
    940
    Re: Anyone using 203V's with Acorn board from Centroid?
    I tried but blew my geckos out using the Acorn schmetics. I found out you haave to use a breakout board that supplies the corect voltage. Gecko did repair the drivers for free just had to pay for shipping.
    Jan 2005
    15362
    Quote Originally Posted by thomasks View Post
    This would be a standard setup for most people the Acorn only uses 5v/24vDC and they supply you with the power supply,
    Mactec54
    Jan 2005
    15362
    Quote Originally Posted by fixtureman1 View Post
    The Acorn supplies the correct voltage you don't need any other Breakout Board
    Mactec54
    Aug 2022
    5
    My geckos died when I used Acorn schmetics. It turns out you'll need a breakout board that delivers the proper voltage to get the job done. For free, Gecko repaired the drivers and just charged for delivery.
    redactle
    Nov 2022
    3
    This would be a standard setup.
    Candy Crush
    Jan 2008
    940
    I know this is an old thread but here is what I did. I got the db25 board and hooked it up and everything runs fine Gecko told me that the schematic that is on the Acorn instructions is wrong and use the DB25 to get the proper voltage. My machine runs real smooth now
    May 2024
    Giving me a bit more information will help me try to understand and respond to your question more effectively
    quordle
  1. Centroid Acorn Board Paired W/ a Old MicroProto Systems Driver Box
    By killacamm in forum DeskCNC Controller Board
    Last Post: 03-18-2023, 03:13 PM
  2. Centroid Acorn experiences?
    By steve_p in forum Centroid CNC Control Products
    Last Post: 07-15-2020, 12:49 AM
  3. Centroid Acorn on Plasma
    By Nucla in forum Centroid CNC Control Products
    Last Post: 06-03-2019, 03:04 PM
  4. My Experience with Centroid Acorn
    By SCzEngrgGroup in forum Centroid CNC Control Products
    Last Post: 05-04-2018, 02:15 AM
  5. Centroid Acorn interview
    By bgriggs in forum Centroid CNC Control Products
    Last Post: 01-18-2018, 08:19 PM
