587,999 active members*
2,544 visitors online*
Results 1 to 6 of 6
    Jul 2010
    159
    anyone using everlast 60c w/ DTHC?
    HI
    Just trying to gather info on a DTHC to work with the everlast 60c, i email CandcNC but they didnt seem to have any confidence in the combination of there products and the plasma cutter, what are other guys using or have success with.
    Dec 2011
    I'm using a everlast with my build, candcnc told me the same. From the looks of the Pinout of the cnc port on the plasma cutter it doesnt look that hard.
    Should be doing the wiring in a few weeks, let me know if you need any help we can figure this out.
    --John
    Jul 2010
    159
    Thanks for the reply, i am just in the process of finishing my cnc router then will be moving onto the plasma, keep me posted when you get yours going, are you using the 60c?
    Dec 2011
    I'm using the powerplasma 50. It has a cnc port on the rear of the machine. It came with a mating connector and a Pinout. Looks pretty straight forward once I looked at the candcnc docs.
    You do need the little connector that is supplied with the mic-1 cable from candcnc to connect to the board but it's just a standard set screw style board connector, you can find them anywhere.
    I'm almost ready to order my candcnc so I'll know what's up when I get it and start wiring. Unfortunately I'm only going to be at my ny shop for a few more weeks so I'll just have to hope I can get it done while I'm here.
    --John
    Mar 2011
    Hey I have the Everlast Power 60c. I am not sure what to do a a thc. You guys have any luck yet?
    Feb 2012
    21
    I using this one with my PP60C. I have not had time to finish yet. I need to check the full arc voltage wiring between the plasma cutter and THC. There are several videos on youtube with thc and china made cutters.
  1. $100 dthc
    By matttargett4 in forum Waterjet General Topics
    Last Post: 03-14-2012, 03:47 PM
  2. Everlast powerplasma 50 wiring to candcnc
    By johndjmix in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 12-20-2011, 07:32 AM
  3. DTHC
    By MAS in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-19-2011, 11:40 PM
  4. CNC table with High Frequency Everlast plasma cutter.
    By rchavez101 in forum Waterjet General Topics
    Last Post: 10-14-2010, 09:17 PM
  5. plasmacam ~ Everlast plasmacutter/mig/tig
    By RustyRooster in forum PlasmaCam
    Last Post: 11-18-2008, 08:41 PM
