603,963 active members*
3,275 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Anyone using xylotex stepper kit for a cnc plasma or router table?
    Dec 2004
    9
    I am in the learning stage of developing a plasma cutting table and was wondering if anyone has used the xylotex.com power supply, (4) 269 oz steppers and xylotex drives and board for there projects. It seems like a better deal than super-tech price wise. I was wanting to hear from someone that has used relays to turn on/off there plasma cutter, router, coolant, ect. How easy was it to install? Will campbelldesigns.com mach 2 breakout board work with this package? I think he sells it for 130.00 and it works with the THC (torch height control) he sells for 375.00. Which I think is a hell of a deal! I was wanting to use xylotex steppers and power supply and then campbelldesigns for the break out board and relays. Will this work? Thanks guys for all you help!
    Chris
    Mar 2004
    169
    Talking
    Im not sure about your first few questions but as far as your torch control goes check out Paul Jones website "CNC on a budget." he makes some beautifully machined parts,Instant Z axis for $130.00 with stepper motor. And a real ingenius torch control. No price listed,but if you email him he will quote you one.
    May 2005
    160
    did you ever decide to get the xylotec did the relays work for shutting your torch on and off and are you happy with it
  1. Need help finalizing plan for CNC Plasma table
    By David Bord in forum Waterjet General Topics
    Last Post: 05-26-2005, 01:16 AM
  2. CNC Plasma table plans
    By krazycnc in forum Waterjet General Topics
    Last Post: 05-06-2005, 03:51 AM
  3. CNC Retrofit - Kit verses turn on and go
    By MetDetect in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2004, 04:06 AM
  4. Where to buy complete cnc plasma table ready to go?
    By Apples in forum Waterjet General Topics
    Last Post: 05-27-2004, 11:34 AM
  5. Starting out building a cnc table for plasma
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 05:36 PM
